Question about Kenmore 60721 Refrigerator
Model 60721 fridge is not getting cold,fan is running, no leaks
  • Kenmore Master
  • 43,501 Answers
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,</span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"><br />Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling<br /><br />Refrigerator not Cooling or Fridge not Cooling<br /><a rel='nofollow' href="http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not" target="_blank">http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not</a><br /><br />How to Defrost Refrigerator Defrost Timer Problem <br /><a rel='nofollow' href="http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer" target="_blank">http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer</a><br /><br /><br />Water Running in efrigerator from Freezer<br /><a rel='nofollow' href="http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from" target="_blank">http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from</a><br /><br />heatman101</span><br />
Posted on Aug 25, 2010
Water leaking into the refrigerator
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 06, 2010 | Kenmore 60721 Refrigerator
GE fridge does not get cold, 60 deg in freezer 70 deg in fridge, compressor is running condensor fan is running and fan inside of fridge is working
You have either a bad compressor or a refrigerant leak.Some times a compressor runs but doesn't compress the gas.It is more likely the unit has a sealed system leak which would have to be located,repaired,and evacuated,then recharged.(not a simple task).
Jun 01, 2010 | GE Refrigerators
Fridge and freezer not getting cold.
Is the yellow substance oil? I need the sears model number also for example 312.65989 That way I can picture just what you have on this end. Sea Breeze
Feb 21, 2010 | Kenmore Refrigerators
I want to know about refrigerater but without compressor ,How it run ,Which technology use it
A refrig doesn't cool . It removes heat which is why the coils get hot . With the condensor mounted on the back of the fridge , air curculation dissipates the heat from the coils . Remember , this heat , is the heat being removed from the inside , by the refrigerant being pumped by the compressor . Some fridges , have a condensor fan to remove the heat from the bottom coils , and to keep the compressor cool . The thermostat , tells the compressor to cut off , when so much heat is removed from inside the ref . The property of refrigerants , is to attract heat , and since aluminum is a good conductor , the evaporator coils inside the freezer are made of aluminum . As the coils get colder , the fan inside the freezer , blows into the refrigerator , and returns to the freezer in a circular motion , thereby cooling the refrigerator . During defrost , wheather it be adaptive or mechanical , is to melt the frost accumulated on the aluminum freezer coils . If too much frost accumulation , the frost will act as an insulation , like the insulation on wire , then the ref. will not get cold .
Aug 28, 2009 | Kenmore 60721 Refrigerator
Leaking into the fridge
on the back or underneath it should go into a pan under the fridge
Aug 08, 2009 | Kenmore 60721 Refrigerator
Fridge not cooling
Is there any frost buld up in freezer compartment?Is your freezer fan running?Need more info You may have a freezing issue you will need to leave doors open over night to make sure it is free of ice .Plug it in in the am and see if it works if it does then it froze up.And will need to replace part .Need more info to let you know what it may be Good luck:)
May 10, 2009 | Kenmore 60721 Refrigerator
Fan in fridge works but the fridge doesn't get cold. It's a small sunbeam fridge.
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks
May 08, 2009 | Refrigerators
Fridgidare, freezer cold fridge warm
sounds like you may have gotten a refridgerant leak causing a low charge condition. some refridgerators have a evaporator fan if this quit working it will cause it to freeze up .thus the freezer does not use a fan and it will still get cold
Jan 05, 2009 | Frigidaire FRS26ZSG
Ge side by side not cold enough in fridge or freezer
if there is no frost build up in freezer section sounds like a refrigerant leak
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmor frig not getting cold
same problem then suddenly would not shut off, kept running. found out it was the thermo couple as well as the timer.
Mar 16, 2008 | Kenmore 60721 Refrigerator
Kenmore 60721 Refrigerator Logo
13 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
