TV CON CHASIS KS9A CON INTEGRADO TDA9377PS/N3/A/1604. NO IMAGEN, NO SONIDO.
  • 140 Answers
SOURCE: PROBLEM CON SOUND AND TV
Parece que su problema es solamente de configuracion fisica and programacion. Empesando conecte su cable al televisor y programe por el menu los canales que se van a recibir por el cable y no por una antena exterior. Sin el cable puesto y el televisor prendido y el volumen alta debes de poder escuchar sonido rasposo porque no hay imagen. Si acaso hace eso entonces tu televisor no tiene problem electronica y es como dije anteriormente. Buena suerte y dejame saber algo. Que Dios lo bendiga.
Posted on Jan 08, 2009
welcomejee
  • 10594 Answers
SOURCE: mi televisor comenso con
Your tv got leaky capacitors problem in Hyper Module / Board, since tv is an old model so new hyper module would not be available any more.
Only option left is to replace all bad capacitors in hyper module that requires good soldering skills and proper tools, it is not user level repair and should be done by tv repairman, check with your local tv repair shop if they agree to repair it.
As I explain, tv is an old model so may be repair/ labor cost got more than tv worth so ask repair estimate before handing it over for repair.
Hope these info will help you.
Thanks.
Posted on Aug 11, 2011
  • 11800 Answers
A wavy line and a partial image are a sign that at least the convergence board has failed. The fact that now the entire image has failed means that the video board has failed also. This signals a very severe failure in the tv, most likely it all started with the failure of the power source.
Open the tv and first check that the capacitors on the power source are intact - follow this
http://www.youtube.com/watch?v=YCSNWi3UHf4
Then check that the voltages that should be delivered by the power source are there - measure them. Then repair the convergence board with this kit
http://www.tvrepairkits.com/xcart/product.php?productid=21850&cat=2749&page=1
and then test the rest of the tv with the repaired board in place to determine what else has failed : check the video final board and the tubes - measure the voltages on the tubes and the final video transistors.
Posted on Aug 12, 2011
  • 302 Answers
SOURCE: problemas con el audio
Most likelly your signal board is going out. Since you have video but no audio.
You can get parts for this tv at www.interliquidparts.com
Posted on Dec 19, 2011
LCD 26 A3, TENGO UNA PANTALLA MARCA SANYO, PERO NO TENGO NADA DE SONIDO, CONECTO MI DVD, Y ESTA SUPER BIEN LA IMAGEN, PERO EL SONIDO NADA, SERA EL CABLE HDMGRACIAS POR SU AYUDARICARDO
Posted on Jan 10, 2012
Eliminar mensaje de sonido
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 19, 2014 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
TENGO PROBLEMA CON UNA PLASMA HITACHI 42HDT79 SOLO SE VEN RAYAS DE COLORES VERTICALES SI HAY SONIDO Y ABAJO DE LAS RAYAS SE VE LA IMAGEN
Hola que tal oye porque cuando prendo mi tele Hitachi 42hdt79 se pone en standby se escucha todo pero no se mira nada ni le puedo cambiar de canal ni subir volumen
Aug 30, 2012 | Hitachi 42HDT79 42 in. Plasma Television
Tv lg 32ld330 enciende con sonido y sin brillo
Mi tv lcd es marca LG modelo 32LD330, al encenderlo se escucha y cambia de canal pero el video lo emite a mitad no da la imagen completa que puede ser?
Aug 18, 2012 | Televison & Video
Problemas con el audio
Dec 17, 2011 | Fujitsu Plasmavision P42HHA30WS Television
Prende y apaga la pantalla el sonido si es continuo
¡Hola
Hay alg?n contacto flojo en su televisor. Por lo general, este tipo de contactos sueltos est?n relacionados con el tablero base del tubo del cuadro y sus componentes. S?lo tienes que abrir tu TV, y examinar si existe cualquiera de los puntos flojos de soldadura en la tarjeta base del tubo de imagen. Puede que Pulli desde el tubo de imagen y examinar. Es muy dif?cil detectar los contactos sueltos. Por lo tanto lo que hacemos es, la soldadura de los puntos flojos sospecha mediante la aplicaci?n de soldadura de un poco m?s. alos que hacer esto. Esto va a resolver su problema de los televisores. Aceptar
Jun 18, 2011 | Sony KV-27FS16 27" TV
Hola. No se si sirva el Circuito integrado de sonido de mi TV ya que no tiene sonido, pero conectandole un DVD en el auxiliar el sonido es perfecto. Tv broksonic modelo ctgv-4563tct ...
Hola, posiblemente el circuito integrado donde se realiza la seleccion de audio sea el problema y no el amplificador de audio ya que funciona con el DVD, habria que determinar cual IC realiza esta funcion tomando como referencia la salida demodulada de audio desde la etapa de frecuencia intermedia o adonde convergen todas las entradas de audio del TV.
Feb 26, 2011 | Broksonic Televison & Video
Hola amigos tengo un problema con un Tv Sony wega modelo kv-29fa515 chassis BA6/9 el tv me enciende osea arranca bien imagen, color y sonido pero alcabo de cinco segundos se me cae la imagen osea queda la...
por favor si alguien tiene informacion que me sirva para arreglar esta falla,le agradesco de corazon.el tv enciende y la pantalla queda oscura,el filamento enciende y los voltages de catodo estan elevados(192v) si aumento el escren, aparece imagen muy al fondo,la pantalla tiene lineas de retorno y cambia de azul a verde.
Jan 12, 2011 | Televison & Video
Tv emerson 14" no tengo dato del modelo tiene los siguientes circuitos LA7671S---TA8782N---STR30110 ---LA7837, sintoma: le doy la orden de encendido, y primero le viene el sonido, luego se ve un...
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
May 21, 2017 | Emerson ET-14J2 13" TV
Televisor
Decime el modelo de televisor (numero)
Un detalle tonto no pero Fijate que los parlantes no esten en MUTE
Acordate que el TV debe ir en canal 3 (ponelo a mano desde el TV)
Cuando tengas imagen, TODO A MANO prende y apaga la caja digital
Tambien apreta en el DVD o VCR la tecla TV/Video
Prende y Apaga tu DVD/VCR en esa misma operacion
Que pasa si pones una pelicula? No se escucha pero se ve?
Chequea el sonido desde el menu de tu tv, fijate sino hay un boton que dice MUTE
Oct 19, 2008 | Car Audio & Video
Sep 07, 2007 | Apex Digital AVL2776 27 in. HD-Ready LCD...
Televison & Video Logo
225 people viewed this question
Top Televison & Video Experts
Electro Med Services...
