Question about Old Forge Tools Hammering
Need to get cylinder type lock off of my gas meter. Gas got locked out forgot about the bill. Paid the bill they say they cant come to remove the lock for six days. Its a cylinder type lock with a round keyhole at one end?
  • 2,176 Answers
I would wait for them to remove. you could possibly be cited for removing this lock yourself.
Posted on Aug 26, 2010
Pull start on a 5700 watt generator is locked up. Tech left the fuel shut off ON over night. It filled my oil up with gas. I drained all the old gas and oil out. Refilled it with 37 ounces of 5w30
Did you remove the spark plugs and drain the fuel from the cylinders? The gas in the oil was definitely a sign that the oil needed draining and replacement, but the pull start may be hydro-locked in the cylinders are full of fuel.
Dec 06, 2015 | McCulloch Electrical Supplies
Removing tank filler cap
buy the bulldog door lock kit. this kit has all items to unlock automotive doors of all types. the kits also come with a key for locking gas caps. it works on all types of locking gas caps, even the locking gas cap on a motorcycle tank. i have used this key on honda, yamaha, kawasaki, and suzuki.
Jul 28, 2012 | kawasaki Ninja Zx7r Zx9r '94 To '04
I turn on the gas from the cylinder and open the grill to start and press the starter but nothing happens. It is a Q grill and I have never had this problem
Either the cylinder is out of gas or the gas regulator is locked up. Turn the gas valve OFF and remove the cylinder. By shaking it, you can tell if there's gas in the cylinder. If there is, reattach the cylinder to the gas valve and open the valve VERY, VERY SLOWLY (Slow motion, slow). Once it's fully open, light one burner and turn it to HIGH. Did the burner light & does the flame height lok correct? If so, light the remaining burner the same way. Now, does' everything look correct? If so, you solved the problem.
If not, you will need to replace the gas valve, as it permanently locked up. Weber should be able to help you with that.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!!
Jul 12, 2011 | Weber Q Grill
How to remove the fuel filler neck on my 1999 Dodge Grand Caravan 3.8 ltr. engine
OPEN GAS CAP FLAP THEN YOU NEED TO DRAIN GAS BELOW FILLER NECK.THEN LOOSEN REMOVE SCREWS IN THE GAS CAP FLAP AREA WHERE FILLER TUBE CONNECTS THEN GO UNDERNEATH VAN LOOSEN REMOVE HOSE CLAMPS AND REMOVE THE HOSE AT THE FILLER NECK BELOW THE GAS TANK.SPRAY WD40 AROUND HOSE AREA AT METAL FILLER TUBE STICK OUT GAS TANK.CAREFULLY USE LARGE PAIR OF CHANNEL LOCK PLIERS TO REMOVE WORK HOSE OFF METAL TUBE FROM GAS TANK. IF YOU CANT REMOVE HOSE WITH HANDS.BECAREFUL NOT TO MAKE ANY SPARKS.PLACE RAGS AROUND ANY METAL PARTS TO KEEP CHANNEL LOCKS FROM HITTING METAL MAKING SPARKS.
Jun 23, 2011 | 1999 Dodge Grand Caravan
Our Bosch 2400E NG tankless water heater is displaying the EC code. I've checked the ionization electrode (rubbed it with a pencil eraser as instructed once before when we had this problem) and I also made...
Had same problem on my five year old water heater (ec error). Didn't figure it was a gas supply problem after five years but double checked to see if the gas bill was paid. It was.
Cleaned the contacts on the two sensors that are clamped to copper pipes inside. Still had error after powering up. Held the error button in for about five seconds, and the blinking EC code went away.
May 21, 2010 | Bosch AquaStar 2400ES-NG
Source of water in natural gas line?
shut off the gas at the suppliers meter and remove the moisture trap in the house and drain any moisture,then turn on gas and do this over again,if you cant get rid of the water call the gas supplier and explain the water in the meter,its their meter and they wont charge you for anything up to the meter from their line,you dont need a plumber
Dec 30, 2009 | Dryers
Cant watch any channel's
Is your cable bill paid, I know that some cable companies could lock your tv if you are in arrears. I hope this is not it...
May 28, 2009 | JVC AV-32F475 32" TV
Forgot phone lock password
What company. If it's your provider tell them to suspend your billing cycle until it's fixed. If you tried 3X to unlock, it will totally Lock. You will have to send it to Samsung for unlocking/
May 16, 2009 | Samsung Propel A767 Cell Phone
I HAVE A 2 YR OLD STIHL 460 CHAIN SAW THAT QUIT IDELING WHILE CUTTING FIRE WOOD. I HAD RUN THE SAW APPROX 1/2 HR BEFORE THIS HAPPENED. I REFUELED, BUT THE SAW WOULDN'T START OR EVEN FIRE. I PUT A NEW PLUG...
The damage may have been done before this tank, or can of gas, Does anyone else have access to saw?
Only about 3 things can cause damage,
1, dirt or foreign object entering cylinder.
2. Unmixed gas or old gas the will cause gumming of rings.
3. overheating of cylinder due to clogged air fins.
Ok there probably a couple more but that is main things.
Put a new Kit in it and keep it away from everyone else. Or have your friend replace only what is needed if the cyl cant be saved.
Saws should have a trigger lock so no-one can borrow them.
Bill Czerkie
Feb 03, 2009 | Garden
Won't Heat -Maytag Gas Dryer Model MD-4 Intellidryer
Once I paid my gas bill--mine started working normally again.
Jan 30, 2008 | Dryers
Hammering Logo
109 people viewed this question
Top Old Forge Tools Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you an Old Forge Tools Hammering Expert? Answer questions, earn points and help others
