Question about Frigidaire Freezer Refrigeration White Upright Large Manual Defrost Freezer Model FFU2124DW
Frigidaire 20.5 Cu Ft upright Freezer Model LFFH21F7HW will not freeze. Is there a trick to setting the thermastat on the outside of the door? It says -F-. This freezer is only a few months old.
  • 97 Answers
SOURCE: won't freeze
Is the compressor running the whole time? If so may have a problem with a refridgerant leak....check the compressor in the rear of unit, feel if its hot....may be as simple as a relay.
Posted on Jun 17, 2009
fridgetech
  • 473 Answers
SOURCE: Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first.  1.  Is there a thick frost buildup on the back panel at the bottom half of the freezer?  2.  Do you hear the fan running inside the freezer?  Let me know what you find.
Posted on Oct 12, 2007
  • 311 Answers
SOURCE: Freezer not Freezing
If unit is running then it is not worth fixing. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
peyton32034
  • 410 Answers
SOURCE: water in the floor
there is a drain hose that comes out of the bottom of the cabinet into a drain pan underneath your freezer take a look and see if that got pulled loose during your move. if it is in place then you most likely have a plugged drain. this can be cleaned fromt he inside at the botom. reomve the bottom basket and the shelf right above it. you will see ice build up on the floor of the freezer and and behind the cover. just defrost the ice you will uncover the drain hole flush warm water thru the line till it runs clear. good luck peyton
Posted on Jan 30, 2009
Maytag317
  • 1136 Answers
SOURCE: Freezer outside walls are very hot. Not maintaining temp
Hi, The walls are getting hot because that is where the condesor coils are. The condensor coils are where the heat is disperst that is trap as the coolant pumps through the evaporator coils inside. The fact that it is holding 0 degrees is a good sign. Is this freezer in a garage?
Check the door seals to make sure no heat is getting into the freezer other then when the door is opened.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 24, 2009
Freezer door has mosture on the outside
You need to order and replace the door gasket. Also check and be sure there the hight adjustment is correct, meaning the door is centered on the opening and not off set to where it can seal.hope this helps
Aug 10, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Maytag upright freezer will not drain and water will freeze in bottom. How do you repair Model CFU2046ARW
Check your door/'s are sealing if they leak u will get freezing occurring in the bottom and around the door will have allot of condensation.
good luck all the best . P's always lay liquid bottle on their side as they will cool quicker and be better on electricity.
Apr 04, 2014 | Frigidaire 20.6 cu. ft. / 583 liter...
I have a frigidaire stand up freezer model #lffh21f7hw, and the door isn't vacumn sealing the door, why?
If you have too much weight in the door or someone pulled down in the door, it gets twisted. Try lifting up on the bottom outside corner of the door to straighten it up. You might have to loosen the top hinge to reseat it.
Jan 17, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
We accidentally left our upright 20 cf frigidaire freezer door open for 24 hrs, all the food spoiled and now the freezer is not freezing and only cooling. Any ideas of what is wrong? thanks
THE UINT IS FROZE UP, YOU WILL NEED TO DEFROST IT. USE A FAN TO BLOW INTO THE FREEZER PORTION , AND HAVE LOTS OF BIG THIRSTY TOWELS HANDY .. THIS WILL TAKE ABOUT 2 HOURS TO DEFROST, WIPE EVERY THING INSIDE THE UNIT DRY !... JAY THE POOL PUMP MOTOR REPAIR GUY FLORIDA
Jul 28, 2011 | Frigidaire 20 cu. ft. / 566 liter Upright...
20.3 cu. ft. Upright Freezer GLFU2067F: We have an upright frigidaire 20 cu feet that is a...
Sounds like frost bulidup from door being left open warm air gets in making frost and ice. Need to turn off for 24hrs or so to let all the ice melt compleatey then turn back on keep door closed run for 24hrs check Temp. shoud be about 0 to -5 Deg. if good start using.
May 17, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Does the light on the outside of freezer stay on . I bought a used freezer. It is a frigidaire commercial upright (frost free) Does the light on outside of freezer stay on all the time? I have no manual....
Normally there is a Green light showing that power is on
A Yellow one for fast freeze and a Red one for under temperature
The outer casing is well insulated from the inside otherwise the freezer motor would run none stop without cooling the contents so the temperature of the outside casing will reflect the room temperature not the intenal
Aug 21, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
Freezers Logo
423 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
