I have a optimus stav3370 when i turn on the power it says overload and turns off
The overload warning appears when there's a short detected in one of the speakers. either you have a blown speaker or the wires are touching
Posted on Apr 26, 2012
Mine did the same thing at first. I had an exposed speaker wire...when I attached it properly the problem was fixed
Posted on Dec 02, 2008
My optimus receiver is getting power but won't turn on
Glad you have made it!! , thanks for choosing Fixya for assistance.
Aug 30, 2012 | Audio Players & Recorders
When I turn on my receiver the "overload comes on ant it cuts off!
You were lucky the overload protection circuit kicked in, congradulation on finding it.
Mar 14, 2012 | Optimus STAV-3770 Receiver
SXG490 displays
if overload warning displays only when you activate speakers "a",,, please check your wiring and speakers
for that channel, first remove both A speakers turn it on, if its okey plug one speaker and try again if okey remove it and try the other one, when you see which one is it check the wire and the speaker ( every time you hook the speaker turn it off before that) overload means something is shorting and that protects the unit to prevent furter damage
Dec 19, 2009 | Audio Players & Recorders
''Power off ''flashes ten times after the receiver is turned on.
Most often it will require an output IC, but I have seen it be a bad ground or a transistor in the protect circuit.
Oct 16, 2009 | Optimus Audio Players & Recorders
Overload issue
There is a problem in the front end that is allowing some DC curent to flow to the output section. This is detected and the amp goes into protect mode to prevent further damage to either the output section or the speakers. This is likely to be defective coupling capacitors and not an expensive repair. Figure on less than $20 for parts for this repair.
Dan
Oct 14, 2009 | Optimus STAV-3770 Receiver
Receiver says power overload, turn system off
It probably needs soldering of the voltage regulators and/or output IC.
I think that model has an access panel on the bottom (it may need to be cut out then rotated and screwed back on when done).
If it doesn't have the panel the main circuit board needs to be taken out to access them.
The regulators and output IC are mounted on the main heat sink. a little soldering and it should be good as new.
Feb 16, 2009 | Technics Audio Players & Recorders
Turns off when i turn it up
Does it power back up after it shuts down, if it does power back up it is unlikely it is an internal fuse, you would need to replace the fuse if that was the issue, could be an amplifier overload, check the demand your speakers require in watts, and be sure the right ohm speakers are being used, many receiver will display "overload protection"and shut down, and some just un-power to prevent a electical short from occuring.
Feb 02, 2009 | KLH R3100 Receiver
SA HE200 ~ Overload at power up
First of, be sure volume is turned all the way down before or as you are powering it it.
Second if that does not work disconnect all speaker, and input/outputs.  Power the device on and see if it says overload.
If it does skip the rest of these steps, your capacitors are bad or the power supply is no longer functioning correctly.
If it doesnt, start with testing each speaker at power up.  Match the speaker to the output it goes on, power the device see if it says it.
If it does on any speaker test it is a speaker issue or a terminal issue.  To test for terminal or speaker issue plug a different/ known to work speaker in that same terminal, if it doesnt say overload it is a speaker issue, if it does say overload it is a terminal issue.
Once you have made sure all speakers and terminals work correctly start plugging input and outputs in and test individually.
Jan 09, 2009 | Panasonic SA-HE200 Receiver
Overload on Technics SA-AX710 Receiver
u can measure the speakers impedance, if is ok. I think this can be a problem, when is speakers with 4ohm conected.
Dec 21, 2008 | Audio Players & Recorders
135 people viewed this question
 Grubhead
Grubhead
