Question about Gaggia Syncrony Compact Coffee Maker/Espresso Machine
I have a Gaggia syncrony compact coffee machine and the coffee grinder has jammed for the second time. The repair agent employed by Gaggia inform me that they have been waiting for spare parts from Gaggia in some cases for months. Can you help or advise inorder to minimise the delay?
    President:
  • 1,618 Answers
If the grinder jammed it might have been because the grind was too fine, try adjusting coarser then using the + or - lever to add more coffee for proper extraction. To clear jam remove brew unit and locate door to grinder chamber on left, vac out grounds, also beans in hopper. When clean run grinder and set to coarser, then add small amount of beans and test.
Posted on Aug 26, 2010
How do I remove the coffee grinder from a Gaggia Titanium?
Please use the link for the illustrated guide. This guide is good for several identical models (Saeco Incznto line, Easy, Vspresso; Starbucks Italia, Italia Digital, Gaggia Titanium, Syncrony Compact and Compact digital models). These instructions are for models with Conical burr grinders (not for models with Ceramic burr grinders.
Use it carefully. Make your own notes and take pictures as well.
Services Unlimited Inc Parts Guru
Oct 17, 2014 | Gaggia Titanium Espresso Machine
Gaggia platinum vision grinder not working
The grinder is faulty,take the unit to a service agent for repair
Dec 29, 2009 | Gaggia Platinum Swing 2-Cup Coffee Maker
Brand new Gaggia Syncrony Compact will not pump water. Red light no. 27 flashes, and machine makes sounds as if trying to pump.
Open the hot water valve, if it flows for a second and stops, then pusi in on the knob if that works, call up support and ask for a new stainless steel valve for your machine.
Aug 01, 2009 | Gaggia Syncrony Compact Coffee...
Red lignt is flashing - advice on how to unclog coffee grinder?
Hi If you have not pushed the coffee button since this happened you can turn the big knob in the bean hopper to the largest # and then turn the small knob to the minus, and try again. If it clears do a second coffee. If it doesn't your going to have to clean the grinder.
Jun 07, 2009 | Gaggia Syncrony Compact Coffee...
GAGGIA syncrony compact coffee grinder motor is
Remove the brew unit and to the left of that is the the discharge area for the grinder, make sure that hole is clear, then adjust grind 1 number coarser, and check machine.
Hi! Can you help me with a Gaggia Syncrony Compact Digital please?
gaggia syncrony ,The unit that goes into the side of the machine is jammed , can you help ?
Jan 17, 2009 | Gaggia Syncrony Compact Digital Espresso...
Gaggia Syncrony does not get past the grind cycle
Water has probably been spilt in the beans area. The grinder needs cleaning out along with the chute
Feb 24, 2008 | Gaggia Syncrony Compact Coffee...
Gaggia Syncrony Compact Coffee Maker/Espresso Machine Logo
213 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
