To Set the Temperature
The reason the stat is coming on during the night/ always being on is setting number 5, there are 5 settings on the Salus
1 is the time you want heating on eg, 07.00 and set the temp (20)
2 is the time you want it to go off eg, 10.00 and set the temp (10 this will turn it off)
3 is the time to come on an evening eg. 17.00 and set the temp (20)
4 is the time you want it to go off eg, 23.00 and set the temp (10 this will turn it off)
5 the problem many people have is that they do not set number 5 correctly, this is a night/ frost stat and if you don't set the time and temperature same as 4 ie, 23.00 and 10*c then the heating will stay on.
How do I set the time and date on my Salus programmer?
· Press the Set and Select buttons simultaneously to enter the clock setting mode.
· By using the "UP" and "DOWN" arrow you can select between 12Hr or 24Hr clock. Once selected press "SELECT".
· The "HOUR" will now be flashing. Adjust with the "UP" and "DOWN" arrow keys to the desired time. Press "SELECT".
· With the "MINUTES" now flashing adjust with the arrow keys to the correct minutes. Press "SELECT".
· Now the "YEAR" will need adjusting. Again use the arrow keys to change and press "SELECT".
· Now adjust the "MONTH" with the arrow keys and press "SELECT"
· Next to change will be the "DAY OF THE MONTH" again with the arrow keys change and press "SELECT"
· "dLS" will now appear. This is the "DAY LIGHT SAVING" mode to turn "ON" or "OFF" use the "UP" and "DOWN" arrow keys. Now press "SELECT"
