Question about Sport & Outdoor - Others
My Kohler engine (ch20gst) when it'scold starts & runs good turn it off it will not restart, untill it kools off .I have replaced coils it still does the samething. HELP.
  • cl_cannon Aug 25, 2010
    could heat break down the oil sending unit
    after it gets hot there is no spark
  • 10,865 Answers
Hi. There are several possible issues here.
  • Overheated - clogged cooling fins
  • Overheated - blocked shrouding
  • Closed choke flooding engine
  • Throttle not in midway position
  • Throttle left in stop position
  • Carburetor solenoid malfunctioning
  • Fouled spark plug
  • Kill lead shorting out
  • Ran out of fuel
  • Lost compression
  • LPG regulator not functioning
  • Vacuum too low to open LPG regulator
                If you can not identify the cause from this list call Kohler directly at
                KOHLER Engines Customer Service at 1-800-544-2444.. J.
              Posted on Aug 25, 2010
              • Sport & Outd... Master
              • 43,501 Answers
              The engine is will not start becuae it needs a higher octane gas when it is hot to start... replace the gas with premium gas 93 octane and you will have no problems...
              heatman101
              • D. Floyd Kolb
                D. Floyd Kolb Aug 26, 2010
                Yes, I have had oil sending units that quit when hot...
                Just that you had not mentioned the no spark so my first thought was the gas....
                heatman101
              I have a walker 18hp with kohler engine. Started it up and it ran for about a minute and cut off. turn the ignition and it won't make a sound. cleaned battery terminals and changed spark plug.
              Running for about a minute sounds like fuel starvation. There could be an obstruction in the fuel tank, which allows the engine only the fuel that is in the fuel line, until it quits.
              Why it won't start again is probably another matter.
              Feb 09, 2017 | Kohler Engines New 18 HP Kohler Engine...
              Runs good until hot chokes itself out or runs out of fuel engine reavs high then for 3 or 4 times then cuts off
              sounds like the coil is breaking down at high temperature. make sure the engine is not covered with grass clipping and dirt. replace the coil. i think this will solve your problem
              Mar 14, 2016 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
              I have a 1998 kia sportage wil crank over and will not start. no spark.
              Sounds like the coil or possibly the electronic ignition, replace coil as this is the cheaper option. Check to see if your Kia then starts if it does allow the engine to run until at operational tempreture then shut off the engine allow 5 mins then try to restart if your Kia if it starts again without straining or being boosted via jumper cables problem solved. If by any chance you do replace the coil & your Kia still will not start the electronic ignition is the next step & that can be done yourself as long as you have the required tools & knowledge, if not a trained professional will be able to replace the electronic ignition but this will be very costly if it is the electronic ignition.
              I hope this helps.
              Jun 06, 2015 | 1998 Kia Sportage
              Hedge trimmer does not stay on
              Will it start & run OK, does it stop after it gets hot then will restart & run again when it cools untill it warms up then stops again,it yes it can be a bad coil,I had this problem on a leaf blower.sometimes just testing for spark won't help you out it may still have spark but the electronics inside the coil that controls spark timing goes bad you could still have spark but it's out of time so the engine still won't run if you suspect this problem change the coil,bad coils can also make them hard to start.good luck
              Mar 06, 2014 | Weedeater Gas Powered Hedgetrimmer...
              Craftsman 26 hp Kohler engine 54
              to be honest the enigne ahas a control that the left side must fire and run before the right starts to fire it sounds to me like you have a fuel issue possibly the carb. is gummed up and dirty.
              Jul 27, 2012 | Craftsman Kohler Courage 26 hp 54" Garden...
              Cub cadet 12.5 hp kohler comand engine sporadic loss of spark
              spark control, yes, trace spark plug wire back to its end, you will find what I will call a coil, for lack of the better word, it can be. I would think that is your problem, if you are presently not getting a spark in the plug.
              Jul 18, 2010 | Cub Cadet Street Sign- tractor lawn riding...
              Ok i took it to the shop and had the timing belt pully and belt changed and water pump changed and cam sincer changed and i got it home and it worked good for 2 days and then it shut off so i got it back...
              may be a bad crank sensor or on its way out. evidently when it gets hot it shuts engine down. a bad crank sensor will stop engine while driving, and will not restart for about 15 to 20 minutes later. it will keep repeating this until it is fixed. usually it sets a problem code. but other sensors have gone bad and no codes or light is not on.
              Jun 01, 2010 | 1996 Chrysler Cirrus
              Sport & Outdoor - Others Logo
              100 people viewed this question
              Top Sport & Outdoor - Others Experts
              Bill Eager
              Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
