Question about Sony Televison & Video
We have a slight shadow in the shape of a rainbow.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
U have a bad covergence ic , this is not a easy repair but repair cost is about $260
Posted on Aug 26, 2010
I have a Panasonic PT 47WX51E Projection TV I have this BLUE rainbow shape full across the bottom up one third the way. I have been told the convergence ic's need replaced. The picture is fine other than...
well it is probably the convergasnce needs set not parts when did you last have it serviced? these tvs need serviced every 3 years or so but can last longer basically in the back there are 20 odd thing like volume controllers that adjust the color and convergence ect you just need to get a tv service person out to service it then it will be like new again it will cost around 120 pounds but will definitely be worth it but don't attempt it yourself its not for people that are not trained believe me i tried and mines was out so much it couldn't be fixed lol but its worth every penny my friend just had his done after 5 years and its like new again i say 120 pounds but don't quote me it should be cheaper most tv repair company do it get the phone book out i hope this helped and i would like to know how you get on but don't worry calling out a repair man cant hurt im 99 percent positive that will be the problem but if not at-least you will find out if its not for free!!
Jan 15, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My e series rainbow smells very badly... my teenager often leaves the water in for days and that nasty smell has saturated the sweeper itself. How do I get the smell out
You should always put a new hepa filter in any E and E2 series Rainbow vacuum, when it taken to a new home, or every two Years, or so, or if your Doughter makes it get funky smelling. :-) It will smell like the home that it was in, or how ever it smells, until you do.
You can also use fragrances, and deodorizer air freshener in your vacuum, which not only eliminates odors, it add fresh aromas to your air that you breath, in your home, also.
Replace the hepa filter first thing.
The water separator is the thing that spins in the center of the motor where your water basin attaches to it. It looks like a cone shaped fan looking thing. It should be cleaned after every use.
Use your Rainbow separator cleaning brush, or a tooth brush, if you do not have the Rainbow one. They are just like tooth brushes.
Never store your Rainbow canister on your water basin, with or without water in it. It can and will ruin your vacuum in dew time.
You can get manuals either here,
http://www.rainbowsystem.com/ or here,
http://www.rainvac.com
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Jan 05, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Has rainbow lines on tv screen
shadow mask is warped. tv might have been dropped. crt is bad(picture tube). try deguassing it. if you dont know what that is take it to your local service center. the rainbow effect is a magnetic field of some sort. try unplugging and move to a different location. could be a speaker too close to tv.
Nov 12, 2009 | RCA F36650 36" TV
Rainbow e2 system. Will not power up
the water basin has a safety on it so the unit cannot run without it. if you look on the bottom of the rainbow you can see a small oval shaped space that you can depress just to test and see if it still runs it will only run with this depressed.
Oct 11, 2009 | Rainbow E series Canister Wet/Dry Vacuum
I have my vacuum set to shampoo a rug, but cannot get the water to come out
Sometimes it takes up to 10 or so minutes for the Aqua mate 2 to begin pumping out anything.
If it is the new Aqua mate 12 (the big blue one, that is like a giant power head) the same thing is true for it.
If it is an earlier model Aquamate, then it is clogged somewhere in the hose, or the fluid control valve is clogged.
Thank you,
Ralph
Jan 25, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Colourful picture
Discoloration of this sort is caused by magnetism. All CRT TVs (like yours) have a de-gaussing coil around the picture tube that de-magnetizes the screen (more specifically the shadow mask) every time you turn it on. It is likely that the circuit that controls this coil is at fault. There is probably a cold solder joint where it connects to the main circuit board.
The other scenario is that someone (small child generally) has run a magnetic object very near to the screen, magnetizing the shadow mask (inside the picture tube) and causing a rainbow effect. This is less likely if the rainbow effect is a nice even circular shape. Generally if it's been magnetized by a magnet as described the discolored areas will appear blotchy.
In short, if you have some electronics skills, get in there with your soldering iron and touch up the connections to the de-gaussing coil. If not, find someone who does.
Oct 01, 2008 | Televison & Video
Water blowing out of rear filter
Unless the design has changed, there should be a cone shaped filter with slots around the sides of it. It's secured to a brass bolt in the center of the Rainbow above the motor. The filter is used to keep water out of the motor. If it isn't attached it can blow water out of the secondary filter as well as the exhaust port. It can ruin the motor in some cases as well.
It shouldn't be operated without it being secured to the base of the Rainbow.
We used to call it a filter but what it is its a water serperator. It looks likes this:
http://us.st12.yimg.com/us.st.yimg.com/I/rainbow-supplies_2008_4241973
Aug 06, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Sony KP-57WS510 rainbows and arches
no the shape doesnt matter as long as the STK numbers are the same. I would make sure that the replacements are origional sanyo ICs as often the cheaper versions do not last very long.
Mar 18, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Picture problems
My computer did this and I think my TVs just gone the same way. Was definitely a loose connection somewhere. In the computer monitor it was because the pins in the plug were slightly bent and if I moved the wire the picture got better. In the end I had to replace the connecting cable
Mar 17, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
