I got a Samsung LA32c457C6H lcd and i can't take it out from hotel mode. what can i do to tune channels ?
4 Suggested Answers
ltfrc
  • 227 Answers
SOURCE: problem with tuning digital channel
I would believe from what you said, you have solved your problem. You will need a UHF antenna to receive the signal. Walmart or Radio Shack has a great amplified antenna that will work for you.
Mike
Posted on Mar 23, 2009
SOURCE: tuning option on menu is greyed out. cannot retune channels
If the channel icon is greyed out and you cannot tune the channels press the TV/DTV button on the remote control unit the icon is not greyed out and tuning is possible.
Posted on Oct 01, 2009
roety
  • 585 Answers
SOURCE: My Samsung LCD (LA46A850)does not tune Analog
Hi my name is Roety,
I can help you with your issue ,
Even before you run the auto program you should see a picture when entering a channel below 13 when entering the numbers in the remote. If no picture shows check the signal source the center connector may be bent.
Another possibility is selecting ant 1 or 2 make sure you are selecting the correct input the check the picture then run auto program
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Posted on Jan 19, 2010
Tv seems to be locked, cant access the program settings has it got a hotel lock?
hi,
u can remove the lock by fallowing settings.
1. press menu button and select channel and press enter.
2. select channel manager and press enter.
3. select channel lock then press enter.
4. select off and then press enter.
ok
Dec 15, 2010 | Samsung LA22A450 22 in. LCD TV
I would like to find the hd channel on my tv model le32r8
After tune in any chanel.Check ur tv remote display button on the remote control.Any tv channels play in 1080i modes are in HD channels.
Aug 17, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
How do i reset this tv?
The TV will search for active channels and add them itself. Use the remote to select the on screen menu and go to the Channel Setup mode. Then just push the up arrow and it will add the channels for you automatically.
There is a possibility that this set has another "mode' where you can select "hotel" or "standard" if it's there make sure you set that to standard the "hotel" mode disables some of the features like the ability to set the channels. I can't find this owners manual on line for free (RCA usually won't provide them) I can't be more specific. I doubt that you got a copy of the owners manual when you got the TV.
Zashiban
May 31, 2010 | RCA F27442 27" TV
Samsung Exit TTX mode
Had to reset the TV and re-tune all channels. But it worked.
Feb 02, 2010 | Samsung DynaFlat TX-P3064W 30" TV
I have a philips tv whith no remote from a hotel how can i program it so i get all channels ?
If this has been a hotel TV then you cannot tune it in manually as the Hotel Mode will be activated & can only be re set to normal TV use by using a specific code from the remote control. The only other way is to re-initialise the internal memory using software that is only obtainable from a Philips dealer.
Jul 12, 2009 | Philips Televison & Video
Hotel TV
check in preset under menu the channels 30 above maybe skip, set this channels to skip off. or just do the auto tuning.
Jun 11, 2009 | Zenith C27A24T 27" TV
I have a Samsung 27" TV and need to set it on channel 73 to get a picture from my Satelite Dish. The highest channel the tv goes to is 69.
Set the TV to cable tuning mode and use that channel 73. You have it set for air now so it can only tune to channel 69.
Apr 26, 2009 | Samsung TXN2771HF 27" TV
TRutech 15" LCD does not pick up all channels
Check your TV settings and make sure your tuning is set for cable (may say "cable" or "CATV"). Right now you'll probably find it set for "air". If the TV is set to tune off-the-air, cable channels 2 through 13 work normally, but above that they aren't detected. Once you set the tuning mode to cable, rescan channels and you should have them all.
Apr 01, 2009 | TruTech PLV1615T 15 in. LCD Television
Unable to tune channels on a Philips Combi TV/VCR 21''
To cancel the hotel mode, select program 38 again and press the 2 keys as before for 5s * The sign H- appears on the screen and the hotel mode is deactivated
Jun 24, 2017 | Philips 21PV375 21 in. TV/VCR Combo
Televison & Video Logo
167 people viewed this question
Top Televison & Video Experts
