Question about Hammer Set Of 6 Hilti Te-c3x Drill Bits Sds Plus
'Whats the difference between a te c3x bit and a sds bit'
  • 43,501 Answers
The difference is the type of shaft on the bit so that it matches to the chuck type of the drill...They are NOT interchangeable!!!!
You need to know which type of check your drill has and order accorndingly...
heatman101
Posted on Aug 25, 2010
My friend gave me a hilti T22, what kind of bits do I need for it?
Is it a TE-22?
If so check out
http://www.bamanufacturing.com/page_ref_6.htm
Looks like TE-22 uses tapered shank bits
a TE-22P uses SDS plus shank bits
I'm not familiar with a T22
Dec 11, 2014 | Drills
What hilti hammer drills use TE-C bits? I want to buy one
TE2, TE4, TE6, TE7, TE30, TE40. The 30 and 40 are only corded, (not cordless).
TE-C bits come TE-C (standard head) and TE-C3X which is a high performance bit. SDS is the industry term for this connection.
Dec 09, 2012 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
My hilti te-75 drills but is not hammering or will not go into chisel mode whay coud be the problem with it
Have seen this problem with some 'none' HILTI bits which do not fit correctly into the SDS chuck.
Tends to be with larger drill bits which have a wider shank than the SDS connector, the wider shank hits the end of the drill nose which stops the end of the drill bit contacting with the internal hammer.
Solution is to purchase original bits from Hilti. If you have OEM bits and chisel it will be another problem. Hope this helps.
Feb 07, 2011 | Hilti TE 70 Hammer Drill Performance...
Will the bits from the te-c3x fit my te-17
Yes. New bits will fit old Hilti drills. Old Hilti bits do not fit the new (last 15 years) Hilti drills.
Apr 07, 2010 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
When drilling in precast concrete, Does it take a special concrete bit?
It depends on what kind of fastener you are going to use, a split bolt is different that an ancor bolt and the need different size holes. so tell us the type of anchor bolt your using.
Jan 05, 2010 | Hammer Set Of 4 Hilti Concrete Drill Bits...
I need to know what carbide Masonry drill bits are available for the Hilti TE-6s and where I can buy them
Any SDS Plus or SDS drill bit will fit. Available at Home Depot, SEARS.
May 13, 2009 | Drills
My hilti te 6-s stopped working trigger looks to be ok. wondering how to test trigger and motor to be sure niether is the issue. thnx
I would first check the cord to the switch and then the 2 wires coming from the motor to the switch to see if they have continuity. UNPLUG tool first. to be on the safe side remove the bottom cover 2 T15 Torx screws and look at the brushes also and while apart if you have compressed air blow thru all the openings. The switch is hard to check so I would check everything around it first and if OK I would say a bad switch.
Apr 07, 2009 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
Drive systems Question
SDS (or Slotted Drive System) bits for hammer drills/rotary hammers allow the bit to slide in the chuck and enhance the hammering action of the tool. For most applications, these bits provide plenty of torque. SDS Max bits are similar to SDS bits, but have larger shanks and come in larger sizes than SDS bits. These powerful bits are useful in industrial applications.
Aug 27, 2008 | Makita Rotary Hammer 450 Rpm, 2500 Bpm,...
Hammer Set Of 6 Hilti Te-c3x  Drill Bits Sds Plus Logo
144 people viewed this question
Top Hammer Drills Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
shall39
Level 1 Expert
Are you a Hammer Drill Expert? Answer questions, earn points and help others
