Question about HP OfficeJet G85 All-In-One InkJet Printer
Color Quality is not so great anymore
I have tried and replaced color ink cartridge and black cartridge at least three times and it seems to be same for and progressively worse. The printing is redder and hazy looking. When printing alignment test page, only the black prints (gray), the yellow is good, and the green check marks print. All other colors and items do not. On the black-gray bar there little quarter of an inch prings tones of red, yellow, and blue.
\does anyone know of a solution to bring back the quality of the printing?
    Scholar:
  • 87 Answers
Sounds like the machine needs to be cleaned. Probably a heavy use machine that has quite a bit of ink spray build up on the inside. I would imagine your service station has quite a bit of ink build up in it as well possibly causing the cartridges not to be cleaned like they should. A good cleaning cures most of what ails inkjet printers. We would charge $85 in our shop for complete disassembly down to the metal frame and cleaning.
Inkworks
Posted on May 21, 2008
Black will not print
Please check it black ink cartridge and also check it your cartridge working conduction or not. If you are more then three time refill then not used cartridge because three time after not good quality print.
And go to printer property and check it color choose option if you are not choose black ink then not black printing.
Thanks,
HP Printer Support
May 30, 2014 | HP Officejet 6310 All-In-One InkJet...
Bluish color to copied photos
Replace color cartridge:Reason: Color cartridge carries three color for color combination, in that any one of color empty or dried up color combination wont happen perfectly, result printer get mismatch colors.. In your case it might be magenta color over.. replace color cartridge to get good print outs..
Jan 31, 2012 | HP LaserJet 3050 All-In-One Printer
Refilled the ink cartridges on my Canon PIXMA iP1600, as I have often have. Now it will not print in color very bright / the font size has been reduced considerably / I have chosen the three options of...
Ink cartridges can't be refilled more than a few times before they lose vacuum or can hold pressure which can affect performance.
Try to use only genuine new Canon cartridges for max. performance and quality.
Feb 03, 2011 | Canon PIXMA iP1600 Printer
Hi, my printer is a HP Color Laser Jet 2605dn. I've had it for several years and it's proved to work fantastic in all areas. However, in the last few months, I've had color issues. The printer prints out...
This printer does not use ink cartridges. It is a laser printer and uses toner cartridges. Yes, one or all three toner color cartridges maybe running out of toner.
Nov 09, 2010 | HP Color LaserJet 2600n Printer
I have been told my printhead is malfunctioning. Can I clean it myself?
You can look in thr user guide or printer help for Troubleshooting and Routine Manteinance.Make sure that the Printer Driver or Paper Type setting in the menu matches the
type of paper you are using. (See Printing in the Software User's Guide on the CDROM.Make sure that your ink cartridges are fresh. The following may cause ink to clog The expiration date written on the cartridge package has passed. (Cartridges
stay usable for up to two years if kept in their original packaging.) The ink cartridge was in your machine over six months.The ink cartridge may not have been stored properly before use.
Try using the recommended types of paper.
CLEANING:
Press Ink.
Press a or b to choose Cleaning.
Press OK.
Press a or b to choose Black, Color
or All.
Press OK.
The machine cleans the print head.
When cleaning is finished, the machine
will go back to standby mode
automatically.
Checking the print quality
If faded or streaked colors and text appear on
your output, some of the nozzles may be
clogged. You can check this by printing the
Print Quality Check Sheet and looking at the
nozzle check pattern.
Press Ink.
Press a or b to choose Test Print.
Press OK.
Print Quality.
Press OK.
Press Color Start.
The machine begins printing the Print
Quality Check Sheet.
Check the quality of the four color blocks
on the sheet.
Is Quality OK?
1.Yes 2.No
Do one of the following:
If all lines are clear and visible, press
1 to choose Yes, and go to step j.
If you can see missing short lines as
shown below, press 2 to choose No.
The LCD asks you if the print quality is
OK for black and three colors.
Black OK?
1.Yes 2.No
Press 1 (Yes) or 2 (No).
The LCD asks you if you want to start
cleaning.
Start Cleaning?
1.Yes 2.No
Press 1 (Yes).
The machine starts cleaning the print
head.
After cleaning is finished, press Color
Start.
The machine starts printing the Print
Quality Check Sheet again and then
return to step e.
Press Stop/Exit.
If you repeat this procedure at least five
times and the print quality is still poor,
replace the ink cartridge for the clogged
color.
After replacing the ink cartridge, check
the print quality. If the problem still
exists, repeat the cleaning and test print
procedures at least five times for the
new ink cartridge. If ink is still missing,
call Brother Customer Service
Nov 03, 2010 | Brother Multi-Function Center MFC-240C...
Canon pixma ip4000 color not printing correctly with full inks
In both cases be sure using correct ink. Use of generic ink can lead to leakage of catrridge seats do to crossion from inferrior ink quality (per Cannon). Be sure ink in proper locations - see manual. Run the maintenance proceedures: cleaning then print nozzle pattern. If all colors are not proper after two or three cleanings, perform deep cleaning. Print nozzle pattern after each cleaning. This should clear up problem. If not, print head may need replacement.
Feb 09, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Can we print with other three Color ink cartridges when Black Ink cartridge is emptied?
hi,
as u have ran out of ink you cant print anymore... you have to replace a new ink cartridge.... this is because when u print something, the colors will get mixed to print the exact color.... even if u are printing only in black, some other colors wil get mixed to produce the black color on the paper... so u need to change the ink cartridge.... u cannot run with a blank filled ink cartridge.... and the selection of your printer is very good...
thanks and regards
agnel
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Black ink
Print nozzles will be at bottom of cartridge...Make sure that u do not wet copper contacts ... first try using dry paper towel and check where ink comes and follow the procedure given below....
Cleaning procedure
  1. Remove the print cartridges.
  2. Moisten a clean, lint-free cloth with water.
  3. Gently hold the cloth against the nozzles for about three seconds, and then wipe in the direction shown below.
  4. Using another clean section of the cloth, gently hold the cloth against the contacts for about three seconds, and then wipe in the direction shown.
  5. With another clean section of the cloth, repeat steps 2 through 4 above.
  6. Allow the nozzles and contacts to dry completely.
  7. Reinsert the print cartridges.
  8. Print the document again.
  9. If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times.
  10. Check the warranty and try to get replaced
Jan 18, 2008 | Lexmark F4270 Plain Paper Inkjet Fax
HP PSC 1315 Printer
57 No. cartridge is defective. Through it in a dustbin and purchase a new one
Sep 17, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP OfficeJet G85 All-In-One InkJet Printer Logo
105 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
