Question about D-Link DP 303 (DP-303) Print Server
Hi - in my three-computer, PC network environment, I just changed from a static IP to a dynamic IP situation, and can't use some of the printers. I think it's because my DP 300U print server is stuck on stupid...
  • 724 Answers
Shut down all the printers and computers.
Boot all the printers first to establishe their IP addresses.
Then turn on a computer and search the network group for what is online. All the printers should show as long as they have theit IP address.
Once their static IP is established the rest shall follow with what ever IP addresses are left. A dynamic IP setup grabs the available ip address and can conflict with a device that has that static IP if the static IP device is powered up after.
Posted on Aug 26, 2010
What is the IP address for my Firestick?
The IP address of an item, unless you specifically assign it one, is done automatically by the router when it connects to the network. This address can be different each time the device connects depending upon what other devices are already connected.
Jan 02, 2016 | Computers & Internet
Tip
IP Conflicts in a work place
An IP address conflict occurs when two computers on a LAN or the Internet have been assigned the same IP. IP conflicts between two computers normally render either one or both of them unusable for network operations.
How IP Address Conflicts Happen
Two computers can acquire conflicting IP addresses in any of several ways:
· A system administrator assigns two computers on the LAN the same Static IP Address.
· A system administrator assigns a computer a static IP address within the local network's DHCP range (dynamic IP range), and the same address is automatically assigned by the LAN DHCP server.
· A malfunction in the network's DHCP server allows the same dynamic address to automatically be assigned to multiple computers.
· An ISP accidentally assigns two customers the same IP address (either statically or dynamically).
· A mobile computer is put into standby / hibernate mode and then awakened later.
Note that other forms of IP conflicts can also occur on a network. For example, one computer may experience an IP address conflict with itself if that computer is configured with multiple Network Adapters. System administrators may also create IP conflicts by accidentally connecting two ports of a network switch or router to each other.
Recognizing IP Address Conflicts
On most Microsoft Windows computers, if you attempt to set a fixed (static) IP address that is already active on the local network, you will receive the following pop-up error message:
The static IP address that was just configured is already in use on the network. Please reconfigure a different IP address.
On newer Microsoft Windows computers having dynamic IP conflicts, you should receive a balloon error message in the Taskbar as soon as the operating system detects the issue:
There is an IP address conflict with another system on the network.
Sometimes, especially on older Windows computers, a message similar to the following may instead appear in a pop-up window:
The system has detected a conflict for IP address...
On Mac or Linux computers, a similar message will normally appear on screen.
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
on Nov 24, 2010 | Computers & Internet
Try to connect the hp laserjet 8000 to network, since we connected with static ip, how could I change to dynamic ip?
First, why would you want a printer with a dynamic address? Do you have one reserved in the dhcp scope for it? Do you have the printer named in DNS? Printers are much easier to deal with when they have a static address, they're always in the same place on the network.
All that said, browse through the menus till you find the network setup find the IP menu and set it to automatic. Very simple. Make sure to save your configuration change.
Oct 24, 2013 | HP LaserJet 8000 Printer
What is the ip address
IP address
noun Computers. a code that identifies a computer network or a particular computer or other device on a network, consisting of four numbers separated by periods. See also IP.
http://dictionary.reference.com/browse/IP+address
PS. Free points for newcomers or are you to lazy to google it?
Aug 23, 2013 | Comtrend CT-520 Router
Change ip address
I believe the information contained in this link, is better than the prattle I could post,
http://whatismyipaddress.com/change-ip
Regards,
joecoolvette
Mar 21, 2013 | Lenovo Computers & Internet
HP laserjet 2015dn IP address problem
please do not assign dynamic IP on the network printer. give a static IP on it base on your network config. and also, please do assign all you computers on the network with static IP's so that every time they boot there will be no IP conflict or problem on the network connection.
Mar 05, 2010 | HP LaserJet P2015dn Printer
Scanner doesn't send to PC
hi
I dont work on Sharp machines but this may help
If a PC or network is running DHCP it means the IP addresses are on a short lease and are called Dynamic IP addresses.
If DHCP is turned off then your PC's are running Static IP addresses which means that they will not change.
Ok...if you are running dynamic IP addresses your scan to PC destination will have to be the host name of your PC and not an IP address
eg   james.
to find out, do the following
start,contol panel,system,computer name.
hope this helps
Aug 13, 2009 | Sharp Office Equipment & Supplies
Wireless printer
  1. Print a Network Configuration Page from the product.
  2. On the front panel of the product, press Setup .
  3. Press the arrow buttons to select Network and then press OK .
  4. Press the arrow buttons to select Network Settings and then press OK .
  5. Press the arrow buttons to select Network Configuration page and then press OK . NOTE: If the page does not print, unplug the power cable from the back of the product, wait a few seconds and then plug it back in. Repeat the previous steps, a-d, to print the configuration page.
  6. Change the IP settings to Manual from the printer:
  7. On the front panel of the product, press Setup .
  8. Press the arrow buttons to select Network and then press OK .
  9. Press the arrow buttons to select Advanced Settings and then press OK .
  10. Press the arrow buttons to select IP Settings and then press OK .
  11. Press the arrow buttons to select Manual and then press OK .
    1. Set the IP settings from the Manual IP Settings Menu using the following instructions:
      For this item...
    Do the following: IP Address Type in a static IP address on the same subnet. Select an IP address outside of the Dynamic Host Configuration Protocol (DHCP) range. Choose an IP address with the same first three digits as the assigned IP but a much higher fourth digit (between 1 and 254). For example, if the original IP was 192.168.0.1, assign the static IP to 192.168.0.200. Subnet Mask Do not change the Subnet Mask. Default Gateway Do not change the Default Gateway
  • tahnks
    TTYAGI
    Apr 30, 2009 | HP DeskJet 6988 Printer
    Connecting Brother MFC 7420 thru Dlink DP301P Print Server to home network with ONLY dynamic addressing
    I went and got static IP addresses from internet provider...Must of caught them on a good day
    Apr 24, 2008 | Brother MFC 7420 All-In-One Laser Printer
    D-Link DP 303 (DP-303) Print Server Logo
    110 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
