Picture is at the top of the screen . no exterior adjustments.
  • 5,568 Answers
Please provide make and model of your gear when asking for help; there are some basic differences in projection TVs that could influence the value of help we can give you.
Posted on May 05, 2008
The picture is about an inch short at top and bottom whether it is in 16:9 or 4:3 mode. Can it be adjusted? Is there a service mode? I am a retired service man.
hi sir have you been already tried all the picture format at picture settings. automatic, super zoom and wide screen. try also in picture settings go to vertical shift adjustment and horizontal adjustment to adjust the position of the picture.
Jul 11, 2011 | Televison & Video
Some channels on my tv are dark and tinted orange, I used the menu button to display the menue and scrolled down to picture but I did not know how to select picture.
Hello
Adjust colour control to zero, and check for a pure black/white picture. Adjust contrast and brightness control to minimum and check whether the picture goes completly off or a slight picture prevails. If the picture goes out when you turn down brightness control to 1/3 position, that is about 20 points, your TVs screen voltage is very low, and it can be adjustable. If the picture does not go out and more brightness prevails, screen voltage is high. If the screen voltage is high, there will be some fine lines across the screen at about an inch apart; on the whole screen from top to bottom.
Screen voltage adjustment is critical for the clarity of the picture. If it is low, no proper colour will be dispayed. If it is high, it is harmful to both picture tube and your eyes.
Never try to adjust it without proper knowledge about it. The screen control can be located alongwith the LOT [Line Output Transformer], of your tv. There will have two adjustable controls there, one is for Focus, and the other is for Screen. Both are interactive, that is adjusting one will effect an other.
Oct 18, 2010 | Emerson TS2587D 25" TV
Picture too large for screen
Press "wide mode" on TV remote until it is on "full". Check for same on set-top box.
May 02, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Screen is bowed on top and bottom. What could be our problem? Picture, letters & words blurry.
go to hatch screen adjust all colrs to make white color boxes , also adjusts linear lines
Dec 31, 2009 | RCA Televison & Video
The picture does not fit the screen. The top and bottom of the picture go beyond the screen
you may need to adjust the aspect ratio of the picture, there is typically an "aspect" button on the remote that will adjust the picture from widescreen, super widescreen 16:9 ratio and sometimes you can zoom in. try that
Sep 20, 2009 | Samsung Televison & Video
Picture has become progressively dark 27'' TV JVC AV-27320
disgaussing will not help this problem..i am scared your picture tube problem or try to change the crt socket first it is not cost much
Jul 01, 2009 | Televison & Video
Hazy, washed out picture on Magnavox 51mp6100d
Remove back see if you can get to tubes top lenses clean all 3 from dirt/dust/ After cleaning off lenses there is a black control box has 3 controls on top 3 on bottom these are to adjust each tube R-G-B Tubes screen/ focus adjust one tube at a time--- Like to adjust red turn g,b.screen drive off turn red up adjust focus to a clear picture ,then green same and blue If you turn screen up to much it will either shut off or you will see Drive lines adjust back down.OK after doing this turn color off in menu adjust all 3 screen controls untill you have Black and white picture try to adjust as close as you can to get bl/wt picture when that is done now turn color on and you should have alot better picture.
Dec 19, 2008 | Televison & Video
New Samsung PDP TV - picture problem
Unfortunately, you have to return the set.
You have a column of bad pixels. Take it back as fast as you can so you don't have to take it to a service center for repair.
Mar 22, 2008 | Gateway FPD2275W LCD Monitor
Picture adjustment on zenith SM3247MK8
Probablemente tengas problemas en el circuito vertical o los capacitores adyacentes hay que checarlos.
Mar 20, 2008 | Televison & Video
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
