Question about HP Pavilion 753n (P9852AR#ABA) PC Desktop
Message- start windows normally. It stop working. do not pass start window normally
    Genius:
  • 1,234 Answers
Choose This
Last known good configuration(your most recent settings that worked)
Posted on Aug 25, 2010
My gadgets stopped working
hi,
it is normal, windows decided to remove the support of it because too many malwares where passing by...
for my part i have seven X64 and i only have the orange calendar working, if i take the clock, it have a bug, it first shows correctly, but then disapear, and i saw one day by moving a monitor position to have the two screen one over the other, and the clock was at the top, but when i came back to normal config (one monitor) it disapears again...
so no more gadgets !
cheers
mich
Apr 10, 2015 | Microsoft Windows 7 Home Premium 64BIT...
Rear windows reset
once you either get new batteries or charge them back to normal operation. the procedure is as follows: on the driver door panel you have the 4 window switches either one at a time or two at a time you start with the front windows all the way up then hold the button down for 10 seconds after the window was all the way down. then the front pass. window. then do the same for the rear this will relearn the start and stop of the windows. hope helps
Jan 08, 2014 | 2005 Bentley Continental GT
Need for speed most wanted has stopped working??
you can try re installing the game , if the same problem persist, check the OPERATING SYSTEM compatibility of the game... if its not compatible with windows 7 it wont work normally, try to find NFSMW that is windows 7 compatible here www.isohunt.com
Jan 28, 2012 | Toshiba Satellite L650-BT2N23 Notebook
When you turn on treadmill the incline goes all the way up and all the way down. Does nothing else.
First we need to do a calibration follow this procedure
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of incline, press the Stop key and then remove the safety key.
If the incline moves but you it will not operate normally nor calibrate, check the wiring from the incline sensor to the power board. If all looks normal, put it back in calibration and see if you see a blinking “- -” symbol in the incline window when you are calibrating. If not, the incline sensor is bad Call icon Fitness @ 800-999-3756, they may have the sensor or they tell you, you need to replace the incline motor
May 29, 2010 | Proform 675 E Treadmill
I have a Image 15.5 Treadmill, it turn on, Incline...
If the incline moves but you it will not operate normally nor calibrate, check the wiring from the incline sensor to the power board. If all looks normal, put it back in calibration and see if you see a blinking “- -” symbol in the incline window when you are calibrating. If not, the incline sensor is bad call icon Fitness @ 800-999-3756, they may have the sensor or they tell you, you need to replace the incline motor
May 21, 2010 | Icon Image 17.5 S Treadmill
2002 taurus, power windows all stopped working at once along with lighted window switches. Drivers window stuck down. Relay was hot! Also heater blows cool air, started doing this after I added radiator...
LOOK FOR BLOWN WINDOW CIRCUIT BREAKER.YOU HAVE A SHORT IN WINDOW SWITCH OR BAD WINDOW ELECTRIC MOTOR.YOUR HEAT PROBLEM IS A STOPPED UP HEATER CORES.THE STOP LEAK STOP ITS HEAT.THE STOP LEAK HAS STOPPED OR PLUGGED YOUR HEATER CORE SO COOLANT CANT PASS THROUGH IT.YOU GOING HAVE TO FIX RADIATOR LEAK AND REPLACE HEATER CORE TO GET HEAT AGAIN.
Jan 28, 2010 | 2002 Ford Taurus
Windows vista will not load, when power is turned on, the first screen is windows error recovery with options Launch Startup Repair or Start Windows Normally, start windows normally shuts computer down
Try a recovery . If that does not work try a hard drive test . If that passes reinstall the os . If it fails look at options on how to change the harddrive .
Oct 20, 2009 | Acer Aspire 5920-6727 Notebook
EVERY TIME I TRY TO TURN ON MY DELL COMPUTER IT ACTS LIKE IT IS ABOUT TO START UP BUT THEN GO TO A BLUE SCREEEN AND GIVE ME A ERROR MESSAGE AND WILL NOT GO ANY FURTHER
BSOD = Blue Screen of Death
You have a problem with Windows booting.
When you computer starts up and it has passed the bios check start pressing F8 until you get the Windows start up options, select safe mode and see if windows then boots normally.
If it does then search/run msconfig.exe, on the General tab select Diagnostic startup, click OK and reboot and see if windows now loads.
If it does then you have a program or driver installed that is conflicting in Windows, so remove any recently installed programs or hardware drivers
Go back into msconfig and select Normal startup and see if Windows boots again.
See how you get on with that
Apr 19, 2009 | Computers & Internet
HP Pavilion 753n (P9852AR#ABA) PC Desktop Logo
23 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
