I want to access my modem - Computers & Internet
  • 30 Answers
Acces your modem? you would like to get out on the internet? otherwise try to write 192.168.0.1 in the URL window in a webbrowser. Then you should be able to log in to it.
Posted on Aug 25, 2010
Can't ping or access modem through dir-600l
Your cable modem is a normal home use cable modem. You do not need to configure your modem. Your ISP will send the information needed to the modem once it has been registered to their systems. With most cable ISP you should be able to connect the modem to the cable and gain access to the modem registration. NOTE: You must sign up for service first.
If you wish to access your modem page then you will have to change the WAN IP address to something like 192.168.100.25. Do not use 192.168.100.1 nor 192.168.100.255. Once done you will then be able to access your modem's web page.
Ref: http://www.motorola.com/on/demandware.static/Sites-Site/Sites-Motorola_US-Library/default/v1337719566432/Products/SURFboard%20eXtreme%20SB6121%20DOCSIS%203.0%20Cabl/577212-001-a.pdf
Dec 21, 2012 | D-Link Computers & Internet
Comcast installed Arris TM602G/CT Modem yesterday. Attempted to link modem to MAC AIRPORT wireless router. Have net access with my PC cabled to modem. If I hook the modem to the AIRPORT, the PC indicates...
first its a mac so no wonder its broken second its not your modem it would be your router settings. you may want to restore your device back to its defualts then try again.
Apr 13, 2011 | Computers & Internet
HOW CAN I GET MODEM ACCESS CODE ON SPEEDSTREAM 5100
hello
When you have modem plugged straight into computer, you can access it at 192.168.0.1, should ask for modem access code, (on bottom), then you can click 'advanced' > ppp location and set it for 'on computer'. There may also be a link for technician stats, it will give you info about isp connection. You should / might be able to browse but ISP may need original MAC address of machine (network adapter} you used when 1st signing up. Or if set to PPOE, it would look for name / PW in order to access INternet through ISP.
Anyway, try (after setting PPP on computer) Modem into WAN of router, access router, set PPOE > insert Log-in name / PW and save all settings. Then try homepage, if no, have router "clone MAC address" of the Network adapter you had the 5100 plugged into. Now it should work, even if no <INTERNET> light. ETHERNET light should be constant. Have router use DHCP to address machine independantly of what ISP addresses router, which it will do when modem (having connection confirmed with DSL light)
The other way, PPP location set 'on Modem', means the modem signs into ISP and then it assigns IP address with a timeout around 20 minutes. By getting connection test results when modem is connected to computer, it may seem to make sense, by understanding how ISP knows that modem access code / MAC address, and lets the settings of modem determine if router needs to sign in or not. If PPP is 'on modem', it will be looking for the MAC address of computer, that is why you may need to clone that address into router, so the router can appear as the machine to the modem, than the router assigns net address to computer.
Regards
Jul 09, 2009 | Efficient Networks SpeedStream 5100 Modem
Setting up my 2WIRE wireless modem as an access point
This setup is not possible for 2wire modem because it has a modem function. You can only set the device as an access point if its only pure router without an integrated modem.
Apr 27, 2009 | 2wire HomePortal 1000HG DSL Modem and...
"Lost" modem access code
This site may work for You:
http://www.softwaredriverdownload.com/download_siemens_speedstream_41004200_dsl_modem_manual.html
looks like a manual install of the driver packet. but it's FREE! Good Luck
Feb 19, 2009 | Computers & Internet
2wire wireless router/modem
there is only one quick way to turn off your wireless internet access.
Turn off the modem or router if you are using it.
For your information, all home networks have their own access key, without which nobody can access it... it is normally printed at the bottom of the modem. 10 digit encryption key.
Was I helpful enough??
Nov 07, 2008 | 2wire (1000-000057-000) Modem
Modem connects to Internet, but PC can't
Are you using a firewall? Did you tell the firewall that the browser has permission to access the internet (go beyond the local network of the modem)?
Jul 29, 2008 | Paradyne 6211 ADSL2+ Router (6211I1200)
go to dslreports.com, under forums see if there is a specific help for your telco or modem type. They are very helpful
Jun 01, 2008 | Efficient Networks SpeedStream 5100 Modem
Software
Yes you can use USb modem, you need to uninstall modem software, disconnect modem and reinstall software configuring it as usb. Start installation with modem disconnected and follow User Guide SBG900
Note: usb modem is much slower than ethernet modem (even if you use same machine) . Instead of using modem as usb I suggest using an external Usb Network adapter.
Regards
Apr 21, 2008 | Arris SURFboard SBG900 (49402201900) Modem
WIRELESS MODEM
Pcg U1 doesnt have wireless card. But is has PC card slot. You can buy a PCMCIA wireless card or USB wireless to get access to wireless internet access or PCMCIA modem if you use a modem to access the internet.
I hope this help
Jan 25, 2008 | Sony VAIO PCG-U1 Notebook
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
