Compaq Desktop won't start after city wide power failure
Our city suffered a power failure. My Compaq Presario S6300NX was connected to a surge protector when everything went out. I turned off the surge protector so that it wouldn't power up when the power came back on. After the power came on, I turned on the surge protector but no matter what I do the computer will not power back on. Everything else on the surge protector is working. I have also tried different power sources. I can't find a reset button.
There is a blinking green light on the back of the computer that appears to be in the fan area. I'm not sure what it signifies except that the cord is plugged in.
I am having the exact same problem after a recent power failure in our neighborhood. Anyone out there know of a solution?? The computer will not boot up at all, it is just dead.
same problem but mines SR1053WM. I had just ran sys.recovery on our desktop and wife was moving furniture so i turned it off and unplugged it.moved the furniture and plugged it back in the next day and pushed the power button and nothing.flashing green light working on back but no power.HELP1same problem but mines SR1053WM. I had just ran sys.recovery on our desktop and wife was moving furniture so i turned it off and unplugged it.moved the furniture and plugged it back in the next day and pushed the power button and nothing.flashing green light working on back but no power.HELP1
I have the same problem. The power to the tower is the issue so running any program can not happen there is no power, no boot up nothing. HELP?I have the same problem. The power to the tower is the issue so running any program can not happen there is no power, no boot up nothing. HELP?
to connect wireless to desktop you need a wireless add-on card which is connected to pci slot in your motherboard after inserting the add on card you need to load the drivers then restart the computer
hi i wonder if the mainboard has suffered a power failure due to power shortage through electrical system that it was connected to . if the lights do not appear on the media strip below the video panel and above the keyboard, that would indicate a power failure has resulted from the power supply burn out. That being said the mainboard has suffered a electrical sudden power down. Have you tried the AC adapter to ensure it works ? I would need the entire model number and S/N of the notebook to get some feedback from HP
The computer could not read your copy of Windows from your disk-drive.
Either:
* there is no electrical power getting to the disk-drive (check the power cable)
* the "data" cable between the motherboard and the disk-drive is faulty or not-connected (check it)
* the power-supply in your computer is not supplying power to the disk-drive (try different power-supply)
* the disk-drive itself has "failed" (maybe, the motor that spins the disk-drive has failed)
Take your computer to a professional technician for trouble-shooting.
If the pc is stock - no. To make it compatible you need to add a lot more memory, at least 1GB, and you need a decent video card. With that 7 will run acceptably well, it's still an old pc with a weak processor.
Purchase a USB wireless adapter, install the software then plug it in when the software tells you to.
You should now be able to connect to wireless networks.
My 6000 also died in a thunder storm with power surges. Power seems to be coming in to the cord, but the ON/OFF button on the front does not turn the computer on. Totally black screen, with no response. Hoping for help too.
Hi there. Reset the surge protector if you have one, or unplug it and leave it unplugged for a couple of hours, then try again. Post back with the results please
Unplug it from power.Pull the side cover to check for burnt smell or burnt spots on your board modem or power supply. Unplug the power suppy from the board, unplug the hard drive .
Then plug it all up again , put the cover back on it .Plug power cords back up and try it again.If you get no where after this the surge knocked out your power supply or hard drive or board. Always use a good surge protector on all computers and printer and copiers.
I have the same problem. Could someone please find the answer for us.
Do you hear beep during bootup process?
