Question about Casio G-Shock GW300CA-1V Wrist Watch
Kao postaviti alarm i upaliti svijetlo - Casio G-Shock GW300CA-1V Wrist Watch
  • 831 Answers
Thank you for contacting Fixya,<br /> Please refer to Casio website for more info on this watch.<br /> <a rel='nofollow' href="http://www.gshock.com/support/">http://www.gshock.com/support/</a>
Posted on Aug 26, 2010
How do I unhide alarms 2 and 3?
Set multiple alarms. If any alarm is active,(picture of alarm hear) appears in time display A. Press MODE repeatedly until ALARM appears, followed by ALM1. Press STOP/RESET to select Alarm to set. B. Press SET/RECALL to set alarm. HOURS digits will flash. Press +/- to change HOURS. C. Press NEXT and +/- to set MINUTES, AM or PM (if primary time display is in 12-hour format), DAILY, WKDAYS, WKENDS, or day of the week (weekly alarm). D. Press DONE to exit. E. Press +/- to set different Alarm. Set as above. F. In Alarm mode, press START/SPLIT to turn Alarm ON or OFF. TIP: Alarms apply to selected Time Zone of watch display. Backup Alarm sounds after 5 minutes if no button is pressed. Turning off any Alarm or backup will not affect other alarms. http://assets.timex.com/user_guides/W191_M131/W191_M131_NA_EN.pdf
Dec 01, 2015 | Timex Sports Ironman Triathlon 100-Lap...
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    Replaced batteries in Casio Pathfinder watch. Functions work, but alarm does not sound.
    there are two reasons for this while changing the battery the small coil sping that operates the alarm as fell out or you av put the back on in the wrong position
    Jan 20, 2013 | Watches
    Can not turn off alarm
    If you have Alarms on, you will see a small bar above the Alarm numbers (1 to 5).
    Press the Mode button to get to Alarm mode. You will see Bell AL on the top. Use Reverse/Forward to switch to the Alarm you want to turn off. The Alarm number will increase/decrease on the right of the time.
    Use the 12/24Hr button to cycle through the Alarm options.
    When the Alarm bar is blank, the alarm s/b off.
    Note: The Casio manuals are online.
    http://www.manualslib.com/manual/221397/Casio-Db36-1av.html
    Aug 19, 2011 | Casio DB36-1AV Wrist Watch
    How to set the alarm
    These are the instructions posted on the Armitron website. I hope they help.
    1. From Time Telling Mode, press 'B' twice to enter the
    Alarm Mode.
    2. Press 'A'. Alarm Hours flash. Press 'C' to advance the
    Alarm Hour.
    3. Press 'B'. Alarm Minutes flash. Press 'C' to advance the
    Alarm Minute.
    4. Press 'B'. Alarm Time Zone flashes. Press 'C' to select
    either Time Zone 1 or Time Zone 2.
    NOTE: The Alarm is available in one Time Zone only.
    5. Press 'A' to end set sequence.
    6. Press 'B' to return to Time Telling Mode.
    ACTIVATING THE ALARM AND HOURLY CHIME
    1. While in Alarm Mode, press 'C' to activate the Alarm.
    The Alarm symbol appears to indicate the Alarm will
    sound at the preset Alarm Time for 20 seconds or until
    'A', 'B' or 'C' is pressed.
    2. Press 'C' again to activate the Hourly Chime.
    "CHIME" appears to indicate the Hourly Chime will sound
    every hour on the hour.
    3. Press 'C' again to deactivate the Alarm.
    4. Press 'C' again to deactivate the Hourly Chime.
    5. Press 'B' to return to Time Telling Mode.
    Apr 12, 2011 | Armitron Digital Sport #40/8095SIL Watch
    I have a Casio 50M. I can't stop the alarm function. It seems to beep when it wants to. This watch has the REM feature. Help !!!
    Hi trapmanjohn,
    Man what an aggravating problem! Try this procedure.
    1. To turn the daily alarm and time signal on and off:
    2. In the Alarm mode, press "B" , upper right button, to cycle throught the on and off settings as follows:
    Alarm on Indicator/Hourly Time Signal On Indicator
    a. }}}} with Bell = Both alarms on
    b. Display Blank = Both alarms OFF
    c. }}}} = Daily alarm on only
    d. Bell = Hourly time signal on only
    The Alarm ( }}}} ) indicator flashes while the alarm is sounding.
    The Alarm ( }}}} ) indicator and hourly time signal on BELL indicator are displayed in all modes.
    To Test The Alarm: In Alarm Mode, hold down the "B" to sound the alarm.
    Your Module number is #3171. Down an Operation Guide for the 3171 from here for more clarity:
    http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3171.pdf
    This should help you with nuisance...Good luck.
    Regards, Bill
    Sep 08, 2010 | Watches
    My husband would like the alarm off. i don't know how i did it but i set the alarm. please help me remove the alarm setting. thank you.
    * Press the MODE button until you are in ALARM mode
    * Press STOP/RESET (-) or START/SPLIT (+) to cycle through alarms
    * When you have selected the alarm you wish to erase, hold down STOP/RESET (-) to clear the selected alarm
    Aug 19, 2010 | Timex Watches
    Can't figure out how to deactivate the alarm on Umbro U564B watch
    Start with watch in normal clock mode. press and hold bottom right "lap reset" - alarm time appears. Keeping "lap reset" held, I can then toggle the alarm on and off using top right "start/stop".
    Qiu: Circle segment lights up (only a black point in the middle, NO ALARM)
    Circle segment with a black section on the above middle point, ALARM ON.
    Mar 03, 2009 | Bulova Watch
    Alarms, alarms, alarms
    Press mode until in Alarm Mode
    Press Receive until alarm # shows AL1-4 or Sig
    Press Time/Memo to change alarm on or off. On is shown by indicator next to alarm name.
    Mar 04, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
    Unwanted alarm
    using the button at bottom left of watch, set to the alarm mode and press the button at bottom right to toggle between alarm settings. The bell and wave symbols will appear and disappear on top left of watch display.
    Jan 08, 2008 | Oregon Scientific SE233 Wrist Watch
    Casio G-Shock GW300CA-1V Wrist Watch Logo
    21 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
