I have a 40" Toshiba rear projection TV that has just lost sound & picture. The red power LED is still illuminated and you can hear something like a relay occasionally click at the back of the TV. Any help is gratefully received.
  • 5,568 Answers
You are probably hearing a relay that is connecting, then disconnecting power because of a fault in the power supply.
Most modern sets try to control damage when a serious fault occurs by shutting down instead of allowing something to burst into flame.
You need on-site help with this one.
Posted on May 05, 2008
Toshiba projection tv no picture
You will need convergence work to this unit. Not cheap.(Not recommended for DIY unless already experienced in this type work). Might contact a local servicer experienced with Toshiba & see if they can give you a quote over the phone. Be sure you are sitting.
This is probably a good time to consider entering the 21st century & look at LCD or LED flat screens.
Jul 24, 2014 | Toshiba 65H82 65" Rear Projection...
TV turns off after lightning strike
please post how many time it blinks, this does help us solve your problem.
Jul 25, 2007 | Toshiba TE55T11 55" Rear Projection...
My toshiba tv has no sound,what is causing it to malfunction
I have a Toshiba 52HM95 the red light and the green light keep coming on but I get no picture but I can hear the sound very good what could it be please help
Jan 13, 2013 | Toshiba TheaterWide 52HM84 52" Rear...
I recently picked up a Toshiba TN50V71 & am not sure where to start in troubleshooting it. There is no picture, & the led power light is steadily red.
Rear projection TV is made up of a TV, optical lens and a screen. So picture projection problems are from the small TV tube. Take off the back to reveal the TV and see what could be replaced?
Aug 16, 2010 | Toshiba TN50V71 50" Rear Projection...
I have a Toshiba 51h84.I push the power button and I get a solid red power light. There is a click from inside, kind of like a relay clicking on. No picture, no sound. If I leave it on I get an occasional...
Tv have "LAMP" indication LED light blinking?The tv projection lamp is dead,require changing.Hearing alot of clickings sound too?Mean the board,call the Ballast board is dead.Require change the Ballast too.The Ballast board,the board that help to ignite the projection lamp.
Aug 06, 2010 | Toshiba 51H84 51" Rear Projection...
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
Toshiba 40PW8DB Rear Projection
the scan derived voltages are running ,not firing up the b+ voltages for remainder of the set to operate.pop migt have a cap ,ic etc. service required .
Apr 13, 2008 | Toshiba 40H80 40" Rear Projection...
TOSHIBA 40H80 projection TV - no sound / no picture
it could be, that would be the first thing i would do to rule out I would first check for loose connections on the board.
Dec 06, 2007 | Toshiba 40H80 40" Rear Projection...
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
