Question about GE Refrigerators
What is the gas pressure that should be in the compressor?
  • GE Master
  • 43,501 Answers
The pressure wil really vary according to the inside temp. of the fridge...
low side when cold inside 10-15 and high sode around 150-175 PSI
heatman101
Posted on Aug 25, 2010
When max pressure reached engine dies instead of idle down
Has Pressure Switch Issues - About Air Compressors
www.about-air-compressors.com/has-pressure-switch-issues.html
Many times folks think that they have a pressure switch problem since air leaks out the ... The pressure switch does not kick off when the compressor has reached itsmaximum pressure. ... compressor sits humming and trying to turn the motor insteadof cutting out. It is a ... I have an old, about 20 year old, Ingersoll-rand T21.Missing: idle
[PDF]21 Front St. - Celtic Distributors Ltd
www.celticdistributors.com/content/Celtic/.../BasicCompressorTraining.p...
The air compressor motor and/or engine will get hot while in operation. .... enters thru the intake ?lter and the intake valve on the down stroke of the piston. .... My gas unit builds pressure but instead of idling the engine dies? 0 Check ... most single stage compressors only reach maximum pressure of 125 to 135 PSI. A slight.
[PDF]ALTRONIC GAS ENGINE GOVERNOR OPERATING ...
www.altronicinc.com/pdf/engine-controls/govinstall.pdf
Dec 16, 2015 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
1994 chevy 1500 ac compresssor stopped working fuse is good
couple of reasons
there is no gas in the system and the low pressure switch has stopped the ac compressor
there is too much gas in the system and the high pressure switch has stopped the compressor
there is a blockage in the tx valve and the high pressure switch has stopped the compressor
The climate control module has failed and stopped the compressor
I am thinking a leak and no gas.
Apr 16, 2015 | AC Cars & Trucks
93 ford tempo air conditioning compressor clicking on then off?
There are 2 switches that control the ac compressor operation . One is to stop the compressor destruction from an over full system or a high head pressure from the condenser fan not working . When the system pressure is exceeded then the ac compressor switches off . The other is a low pressure switch that shuts the ac compressor when there is too little gas . Unless you have checked the system for leaks ( why else would you be adding gas) then if you have just recharged the system it is more than likely that there is too much gas . Best advice is to go to an accredited ac specialist and have the system checked for leaks and the correct gas pressure/ volume
May 03, 2014 | 1993 Ford Tempo
Builds up pressure pop off valve at tank opens will not regulate pressure
I would say you have a problem with your pressure switch, you may need to adjust it down. The pressure switch is normally located under plastic cover where your on off switch is on the compressor. There should be a screw with arrows next to it. Try that, otherwise you may need a new switch
Sep 27, 2012 | Champion International Champion 2 Stage...
1995 GMC A/.C compressor wont run
bypass the low pressure cut off and put in more freon
Aug 24, 2012 | 1995 GMC Sierra
Pressure release keeps kicking off
The pressure switch is faulty needs to be calibrated.
Jun 22, 2012 | Ridgid 17048 Gas Powered Wheelbarrow Air...
Aircon not cooling
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the A/C and check the compressor.Make sure that the thermostat was set to normal mode. If there is no cooling then we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
So try this test from the outside and make your observations so that we come to the solution.
May 18, 2011 | LG Kitchen Ranges
Compressor wont kick down at desired pressure
replace the pressure vale or try lubing it for wd-40 first otherwise the shaft has worn inside and is sticking.
Jan 19, 2010 | Hitachi EC2510E 5.5hp Gas Air Compressor
2000 Ford Taurus AC compressor not working;I tried putting freon......compressor has to kick-in in order to take in the Freon; compressor wouldn't kick in ; by pass the low pressure switch, Comp didn't...
the compressor doesn't have to be working for the gas to go in
you connect the gas to the inlet line and as the gas pressure in the system rises , the ac compressor will cut in normally and suck in the rest until the pressures are correct
of course you have to be putting in the correct gas because the switches are different
Nov 08, 2017 | 2000 Ford Taurus
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
