Question about GE WBVH6240F Front Load Washer
Stuck something is stuck inside my drum housing area and I need to find out how to remove it
If you take the front lower cover off you will find a plastic knob. Get a bucket first then unscrew the cap with a wrench. All kinds of stuff will come out from the washer.
Posted on May 23, 2008
  • 177 Answers
Take a flashlight and look inside, see if you can find a screw or nail that may have gotten caught.
Gently pull whatever it is out.
Dont use the machine or you may damage it!
Posted on May 05, 2008
I have LG 6kg WP9032 machine. When i operate drier a peculiar sound is coming. Looks like something is stuck underneath the drier.How
Stuck under where ??? Between the drum and the housing inside ? Many times underwires from bras that come loose will get caught between the drum and make a squealing/squeaky noise.. look inside along the edges of the drum and see if you can see anything unusual sticking out..sometimes rotating the drum manually helps find it.
Jan 23, 2018 | LG Washing Machines
I own a SERVIS CARESS 1600 A waching machine and I think something might be stuck between the drum and the drum housing. There is a scraping noise as the drum rotates as if it is knocking against...
the only way in is not easy, there is a possibility that the heating element is touching the drum you would have to remove the back panel take off all connections to the drum at the rear and remember or write down a diagram so you know where things went in other words take the whole machine apart to remove the rear drum panel another way is to rotate the drum with a small screwdriver through one of the drum holes till you feel the element and push the element back down out of harms way sorry I cant help more but its worth a try eric
Dec 25, 2017 | Washing Machines
Money stuck inside drum making noise
The easiest way to access the area between the inner and outer drums is to take the front off. Instead of something being in the drum making the noise it may be the front felt pads that the front of the drum turn on. It makes the same noise. They are replaceable.
Jun 19, 2010 | Washing Machines
Somethings stuck in my washer
nasty problem. At the door of the machine there is a very slight gap between the inner and outer drum. smalls can get caught here and work their way down. solutions: power off lay the machine on its soapbox side remove the outflow pipe and see if you can find the offending object. Trickier solution: power off remove the heater usually at the back look into the heater housing and see if its there. Removing a heater can be tricky.nut in the centre unscrew but not fully. Tap the screw shaft lightly with a hammer and the remove the heater. When replacing lightly grease the seal to ensure it goes back more easily. Always power off before working on a machine
May 24, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
I have Whirlpool Duet Dryer that has a noise.
It is common for small items (such as coins) to get stuck inside the dryer drum baffles. You can easily remove them without disassembling the entire dryer. The screws that hold them in place are located on the outside of the dryer drum. In order to access, follow these steps:
1. Unplug the dryer.
2. Remove the top panel of the dryer by removing the three screws located in the back of the dryer holding the panel in place. Once the screws are removed, the top panel slides back, then lifts off.
Each drum baffle has two screws holding it in place. Remove the screws and the baffle will drop into the drum allowing you to easily check inside each one.
Another source of dryer noise is something caught in the blower fan housing. You will need to remove the lower toe panel directly below the dryer door to access. Follow these steps:
1. Open the dryer door and remove the lint screen (the blower fan cover will not come off with the lint screen in place).
2. Locate the screws that hold the toe panel in place along the bottom front edge of the panel. HINT: Propping the front feet of the dryer up can give you better access to reach the screws (a 2x4 works well for this). With the screws removed the toe panel will drop down, then come off.
3. Remove the screws that hold the blower fan cover in place.
Inspect the blower fan housing for any objects that may be vibrating against the fan blades.
If you still need further assistance, please let me know. I hope you find this helpful.
Sep 01, 2009 | Dryers
I have a frigidaire stackable washer/dryer unit. The washer works well. But, recently, the dryer started making funny noises almost every revolution like something was banging inside at a certain point....
Try to move the drum manually. if unable to run your hand along the front of drum where it meets the front panel....there are two pieces of felt. something has either gotten stuck there or something has gotten stuck in the blower housing.
Jun 09, 2009 | Dryers
Dell 1600N MF Laser Printer- Blank vertical strip on all prints
you need do follow steps:
1) take out the cartridge find a cover there is the drum inside, the drum you can see the color on the drum surface
2) check out and clean any pieces of paper or dirty waste toner stuck there, because there is a waste toner cleaner on the drum surface which is like a long rubbon strip (something like that) you can spin anyway a little to clean.
3) if you check out any different color (vertical round drum), that is the drum surface worn or scratched. you can see the worn area show light color than normal area.
so you need change it better. 4) if the color all very same and still not fix, you need check again something stuck the drum surface near cleaner rubbon.
hope help you fix it, please take a rating let me know how much helped you thanks! keep in touch your question please.
May 21, 2009 | Dell 1600n All-In-One Laser Printer
Object in the drum
this aint an easy fix.
Sometimes a bra wire gets through the holes and gets stuck.
the only thing you can do is split the drum housing and empty it out.
No hard to to but takes a lot of time and patience.
Sometimes when you are lucky take the pump hose off the drum housing and look in that hole. sometimes it gets stuck there
Mar 04, 2008 | GE WSXH208A Front Load Washer
SOMETHING stuck inside the dryer body - something like a coin... let me knwo
ok here is the best way to describe it you will need to get around the back there are two torks screws remove them and slide the top panel back to you ..OH I FORGOT unplug the machine first !!!....Ok now with the top off you will see the drum.. slowly hand rotate it until you see some screws that are lined up with the baffles inside the drum You will need to remove just a few screws on one side (the baffle that has the coins) dont take them all out or the baffle will fall inside the drum and it will be a pain to get back on9u will need 2 people) and that should do it you will need to rotate the drum around until the correct baffle ..the one with the coins in on top at the 12 o'clock position.. let me know if this works our for you
Feb 16, 2008 | Kenmore Elite HE4 Electric Dryer
GE WBVH6240F Front Load Washer Logo
60 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
