posted by jojoey on May 05, 2008
ok i have a cobra 29 ltd class hooked up to a aries techongley power supply and when i key up the light dims y and will this effect my radio and the galaxy does i need to be turned up or not
Comment by jojoey, posted on May 05, 2008
please email me at fatmanstomps1995@yahoo.com if you know the reason y it does this thanks
Solution #1
posted on May 28, 2008
Hi Joey,
It sounds to me that the power supply you are using may be a little under powered. It's not really a bad problem as long as the voltage doesn't drop below about 10.5 - 11 volts. As for the Galaxy. I'm not real certain of the question but a Galaxy will usally use more current to make it work properly, so I would suggest a bigger ( more amps ) power supply.
Good Luck and I hope this has helped some
Ed ( Radio Man )
NC Electronic
Mills, Wyoming
307-266-4675
Ed ( Radio Man )
NC Electronic
Mills, Wyoming
307-266-4675
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Galaxy DX-2547 40-Channels Base CB
Email this problem
Email this problem
Can you Help with these CB Radios problems?
Repair Service
Find CB Radio Repairman Near You:
