This is about our Dell 3115cn Laser printer. It continuously reads "Load Tray 1" even when there is paper loaded. It will take one page then will read "Paper Jam" when there is no paper jam and then will read "Load Tray 1" again. It seems like the separator rolls aren't picking up the paper. No one has an answer how to fix this other than "go buy a new printer". Can someone help?
  • 1,110 Answers
I have seen this problem on a couple of Dell 3000 series printers. The first cause is a dirty paper feed roller. Just remove the paper tray completely and look inside the open port toward the back and in the center from left to right. A flashlight will help. You should be able to see a gray/black rubber tire an inch or inch and a half wide. You can clean it with a cloth damped with glass cleaner. While you are looking into this port check for the second cause. You should see 2 small white plastic blocks, towards the back, on the bottom sheet metal pan on the bottom of this port. Just make sure there is a block at each side and both are attached. I have see one of these blocks get popped out. Since these blocks release the paper lift plate in the tray when inserted, what happens is the paper is not lifted up to the feed roller to be fed into the printer.
I hope this helps and Thank You for using Fixya.
Posted on Aug 25, 2010
Illegal settings , this is unavailable when (the tray) (no paper) us selected,
Go to setup, default settings, copy, scroll down to paper tray (using left and right arrows) select tray 1
Jul 30, 2013 | Dell Printers:Dell MFP Color Laser 3115cn
I have a printer when i am printing showing load tray 1 and 024-965 printer letter. what is the problem ?
My best guess is either the printer is looking for a specific type or size paper in tray 1 or it is looking for paper in the manual feed or bypass tray.
Jul 24, 2013 | Dell 3115CN
I cannot figure out where to load legal sized paper into our Dell 3130cn printer? Can anyone assist me?
The handfeed tray normally opens from the front by pulling down on it. You can load any type of paper in this tray. Good luck.
Dec 12, 2012 | Dell 3100cn Laser Printer
Prints 2 pages and says to load paper
Somehow after adding paper you changed the paper size to B5. Change it back to Letter and it should resolve your problems
Apr 11, 2010 | Dell 2135cn All-In-One Laser Printer
Dell Laser Printer 5100cn Load MPF Letter Plain 1 !
Are you trying to use the "MPF" (Manual Paper Feed) tray?
If you are then the manual paper feed tray is usually a fold down flap at the back of the printer. It only accepts on piece of paper at a time.
However, if you are just trying to print to the printer's default tray, then you need to check both the "Page Setup" in the application and the printer driver properties to make sure that you are calling the correct paper tray.
Don
Nov 18, 2009 | Dell 5100cn Laser Printer
Dell 3110cn - Load MPF 024-969 letter plain error msg
dell mfp laser 3115cn giving me 024-969 no paper detected
Oct 26, 2009 | Dell 3110cn Laser Printer
Mpf error
MPF is refering to Manual Paper Feed or bypass tray. This tray should fold down to enable loading of paper. It is mostlikely above tray 1.
Sep 15, 2009 | Laser 3115cn All-In-One Printer
Will not print
This usually happens when the paper tray is set to the incorrect paper size.
This printer determines what size paper is installed in it by the little "fingers" on the left side of the tray. When you adjust the paper tray, it determines how those fingers are positioned, and therefore, how the switch reads the paper size.
If the tray setting is off, even by one little click, then the machine may read the paper size as other then letter. If this happens, you send a letter size job to the printer, and it doesnt think it has letter size paper, it will tell you to put letter paper in the MPF feeder.
If the tray is definately set to letter, but the machine still thinks it does not have letter, then the tray or the switch that reads the tray is defective, but 99% of the time it is just the tray is not set correctly.
The MPF door can be open or closed 100% of the time with NO EFFECT on how the printer works.
Oct 10, 2008 | Dell W5300N Laser Printer
893 people viewed this question
jasbo
jasbo
