Question about Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
Frigidaire Electrolux Model FD81050REB2 Serial # TH73491151 just quit working in cycle
I have the model#FR26C7DS2 for Frigidaire but i need serial# manufactured by Electrolux ?
Factory may be able to help you if you can provide the serial number on compressor should be on work order when unit was built
Jul 25, 2015 | Frigidaire Refrigerators
Serial number search engines
Hello friend, thank you for your post!
I understand that you would like to verify you have the correct part. I have provided a link where you can run your model number and it will provide you a parts manual. Within that manual you can search for all parts available for your refrigerator. I hope this helps. -Matt
Frigidaire Product Manuals
Sep 01, 2014 | Electrolux Refrigerators
Frigidaire dishwasher codes
Hello friend, I appreciate your post!
I see that your question is under Electrolux dishwashers but you are seeking for Frigidaire dishwasher codes. Could I get your model number please? It is located on the serial tag which can be found on the interior wall on the dishwasher on the right hand side. Additionally, is your appliance producing an error code? If so, what is that code? With this information I can better assist you. I look forward to your response. -Matt
Jul 29, 2014 | Electrolux Dishwashers
My Frigidaire electrolux dishwasher model # FDB2310LCC0 trips a pf code 40minutes into the cycle and it is not the circuit breaker. how do i correct this problem?
Good Morning Doria, thank you for allowing me to assist you!
Typically PF means power failure and you should be able to start a cycle. Unplug the unit or flip the household circuit breaker. Wait about ten minutes and then turn the unit back on. If the error code continues to display, I would suggest contacting a professional to accurately diagnose and repair it.
Best of luck!
Oct 07, 2013 | Electrolux Frigidaire Professional Series...
I have a Frigidaire front loaded dryer that is just a few years old. It continually beeps and the lights on the front panel flash and after few minutes it shuts off. How do I fix this problem?
I had encountered issues like your concern regarding the problem Frigidaire dryer. Most of them had contacted the Frigidaire repairman to check and put in a new control board and it works like brand new. Though it costs $100 for the service but this amount will be refunded if you contact the Electrolux and ask for a code to give unto the repairman to cover the cost of the board.
You may contact also:
Chris Polk
Escalation Specialist
Electrolux Major Appliances
chris.polk@electrolux.com
So you may be guided, just send your contact information, and the best time to contact you. He would also need your model and serial number and a file number if available.
I hope it helps ^_^
Aug 26, 2012 | Frigidaire Electric Dryer
Model fwt645rhso will agitate but won't drain out, on spin cycle washer spins one way, stops goes back the other way, but water will not drain out. Does not rapidly spin on final cycle. Any...
There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
Jun 18, 2011 | Frigidaire GSTF1670A Front Load Washer
I have a frigidaire pro series micro wave built in undercounter serial number 7g61910011, I am moving and want to know how I can uninstall..the store personel who installed took the install manual..and I...
Your model number will be on a tag inside the cooking cavity or around the control panel frame or door frame.
You will need that number.
You can download owner's manuals and installation instructions for Electrolux and Frigidaire here.
Nov 25, 2009 | Frigidaire Microwave Ovens
Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
148 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Colin Stickland
Colin Stickland
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
