I have a rite temp two brick heater.(Model # RTL 100 MZ) When I hook it up to a propane cyl. the pilot light has a huge flame and the bricks will not light when turned on!!
  • 139 Answers
Sounds like the orfice is clogged or the pilot assembly needs cleaned ..try tapping an the assembly while it is lit ..to see if the flame straightens up. if so clean the assembly with a tooth brush or small wire brush..good luck... let me know if it works/ joe/
Posted on Aug 25, 2010
My mother has a 3 brick wall unit...two of the bricks burn with a blue flame now instead of the inferred...should she replace that wall unit?
Hopefully, Becca the unit won't have to be replaced at this time. It sounds like the burner(s) is clogged and and needs to be cleaned To do this, turn the pilot light OFF and allow the unit to cool. Remove the front of the heater cabinet to access all of the inside workings. Carefully remove the 3 ceramic plaques and set them aside, where they won't get broken.Using a vacuum cleaner that has a hose, brush attachment and crevice tool. Vacuum all of the interior of the heater that you can reach with the brush attachment and crevice tool. Then turn your attention to the burner(s), Vacuum them thoroughly using the brush attachment, then switch to the crevice tool attachment and vacuum all the little holes on the top of the burner(s) thoroughly. Before reassembling the heater, carefully vacuum the ceramic plaques on both sides using the brush attachment. Be careful not to drop them. Then reinstall the plaques and the front of the heater cabinet.
Light the pilot and allow it to burn for 2 minutes, before turning the control knob to ON. Watch the plaques and the flames to see that burn as they should after turning it ON.
If the above didn't solve the problem, depending on the age of the heater, it may be time to replace it.
I hope this helped you and thanks for choosing FixYa.
Aug 16, 2011 | Reddy Heater RLP100 Portable Forced Air...
Heater pilot light flame is high and middle brick is blue not orange?
both need a clean pilot is blocked hence high flame , both need a clean could try blowing then out with a air line , or can of air or just clean injectors on both.
Jul 26, 2011 | Heating & Cooling
My flame is above the guard on the heater in the middle flame. How do I adjust the flame to be lower?
this is happening because the bricks need cleaning. I imagine the flame is burning blue instead of glowing red in the middle brick. Contact your local propane or natural gas dealer about getting the heater cleaned. This type of problem causes a huge loss of efficiency and could be dangerous.
Oct 29, 2010 | Vanguard International Infra Red - Medium...
Kozy World propane wall heater
The ceramic "bricks" need to be heated evenly. Since 3 are good, I would have to assume the other two have a restriction. Maybe a spider in the orifices, If  you can access the "jet" where gas comes out, try using a paper clip or something similar to clear any blockage. If that wont do it, pull the burner, remove each orifice and clear. Good Luck
Dec 30, 2009 | Heating & Cooling
Pilot lights but goes off when releasing valve to turn on
i would suspect defective thermopile or obsruction in pilot assembly that prevents pilot flame from hitting thermopile . check pilot flame characteristics, should be blue and stiff.if it is yellowish that would indicate blockage.use multimeter to determine voltage output. you need about 100mv to maintain pilot and around 400mv to operate control valve
Jul 06, 2009 | Pentair MiniMax 100 Aboveground 100,000...
Glo Warm propane heater started to go out. I blew out the pilot with air compressor. It is staying on, but the middle burner in back of the pilot light is flaming a little above the brick. The other...
sounds like when you blew heater out with air compressor you moved brick so flame isn't hitting bottom of brick like they should. You should try and put brick back on top of flame so that you don't get to much heat on the refractory of the heater.The refractory will take the heat for awhile then refractory will start to break down. Then you will either have to install new refractory or replace heater
Jan 17, 2009 | Desa International GWP20T GLOWARM Wall...
Can not get the bricks to light on my empire corcho
I have the same htr in Mich. & have worked on gas htrs.for many years.
Does the flame go out when you let go of the button to lite it?
If it does, then the thermocouple is bad.
If the flame stays on, but goes out when you turn the dial,
the gas regulator is bad.
Probably a little more expensive to buy new then to fix it.
Michael.
Nov 20, 2008 | Reddy Heater RLP100 Portable Forced Air...
Heating & Cooling Logo
278 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
