Question about Sport & Outdoor - Others
I own a seadoo aqua master motorized inflatable model no. ZS40. I need a replacement battery with the attached wires. Would you please tell me where I can purchase this item. The battery that came with the sea-doo is a McNair 12v 12 amp. I have looked everywhere for a replacement. Thank you, Sharon Hoffler
  • 2 more comments
  • believe0324 Aug 25, 2010
    Store does not ship items...
  • believe0324 Aug 26, 2010
    This site will not sell to retail..
    I own a seadoo aqua master motorized inflatable model no. ZS40. I need a replacement battery with the attached wires. Would you please tell me where I can purchase this item. The battery that came with the sea-doo is a McNair 12v 12 amp. Thank you, Sharon Hoffler
  • 10,515 Answers
You could check the below site :-
http://www.seascooterexpress.com/store/seascooter_battery.html
Usually they would have all the batteries. If unable to find battery there, revert and i would search some more details for you.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 26, 2010
  • 10,865 Answers
Hi Sharon. Go to this link for all of your aquamaster needs, incl. battery and cables
For more information on
Sea-Doo® Seascooter™ Products
(Warranty, Customer Care / Maintenance,
Parts & Battery Purchase)
PLEASE VISIT
www.seadooseascooter.com
Posted on Aug 25, 2010
  • 2,382 Answers
Hi, you can get the battery by contacting Canadian Tire on 1-800-387-8803 It costs $49.99
  • 1 more comment
  • Tunde Autos
    Tunde Autos Aug 26, 2010
    O.k...
    Canadian Tire will not deliver. I would need to go into their store. I live in Virginia, USA.
  • Tunde Autos
Need a manual for Panasonic Lumix model #DMC-ZS40
Melanie:
Copy and paste the top URL to your browser for the basic manual for the ZS40.
Copy and paste the bottom URL to your browser for the advanced ZS40 manual.
Mac
ftp://ftp.panasonic.com/camera/om/dmc-
zs40_en_om.pdf
ftp://ftp.panasonic.com/camera/om/dmc-zs40_en_adv_om.pdf
Nov 21, 2016 | Panasonic LUMIX DMC-ZS40 Black Digital...
How do I wire a aqua-flo circ master hp 240 volt pumpAqua-Flo pump
1st hot wire to L1 the 2nd to L2 green to case of motor see if there is a schematic on the side of the motor
Oct 20, 2014 | Pool & Spa
Why does my 1995 seadoo bombardier shut completely down while wide open
Very likely a cracked wire on the ignition-advance. As the throttle is advanced so is an advance-lever that causes the wiring attached to it to Flex, causing an intermittant loss of current to the coil/CDI.
The flywheel may have to be removed to repair/replace the wiring.
Aug 16, 2014 | Tempest SeaDoo/Sea-Doo/Bombardier Jet Ski...
Parts. i have a 408 seaspray model and the seal kit is bad. I need a replacement, but am having difficulty finding one. Does Coleman have the part for sale?
The XP2 pump uses a 5/8" shaft seal.
You can find them as under part numbers - PS-200, AS-200 or 92500150.
Feb 27, 2012 | Pool & Spa
Motor just hums when turned on. I am assuming that a starting capacitor needs replacement. There is a capacitor on top of the motor. Should I also expect to find one under the wiring cover on the end of...
Probably. Consider also there may be a problem with your impeller ... the motor will humm (because it is running) but it will not pump anything because the impeller may have the center spun out of it.
Oct 24, 2011 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I need to purchase a stationery switch for a flowmaster xp2 model 06620390-2
What is the serial number that goes with the motor model number? I am assuming the 06-620390-2 is off the motor; if not please also add the motor brand and model number as well.
John
(P.S. for a faster response please send this information thru our website at www.arrowmotor.net using the contact feature)
Dec 27, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
What windings do the leads of the capasitors get attached to for the flow master xp2
Please reply with the motor brand, model and serial number so we can get you an accurate wiring diagram. Simply comment on this post and enter the information there.
John
Dec 09, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Aqua flo master piump is kicking main breaker off to spa. I think thermal switch my be bad. Where is it located and can I bypass it to see if this is the problem?
Thermal switch should not be causing the problem. It is much more likely that the problem is the motor, or shorted wiring. If there is a thermal overload switch it will be mounted inside the tail of the motor, but you may need to completely pull the motor apart to get to it. Is the breaker tripping only when you turn the pump on? what I mean is if the pump is off will the breaker reset, and then only trips when you try and turn on the pump? check wiring closely where it comes into the motor, and look for bad insulation where it might be touching the frame or another wire. If your familiar with motors and windings, you can also disconnect the wires from the motor and check the windings with an ohm meter. How old is the pump? and how long has it been installed. Is this a new problem on an old installation? or did you just install the a new motor? Also if you still suspect the motor, might be worth taking down to a pool pump repair shop if there's one near by most will test a motor for you for free. If you need more help, post a comment and'll I'll reply asap. Good Luck!
Sep 19, 2010 | Aqua Flo Aquaflo Flo - Master Xp2 2 Speed...
Sport & Outdoor - Others Logo
378 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
