Question about Kenmore 24032\24036 Top Load Washer
I have lid swich broken in my washer. the model no.11024692300, company is kenmore. can u please send me the discription with written & picture manual to how to fix it....thanks
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24692300&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on Aug 25, 2010
Kenmore 80 series washer will not drain or spin but will fill up how to fix it
The usual thing wrong when a washer such as the one ya have doesn't spin or drain,it's going ot be a broken lid switch. Its a pretty common thing so i have written this tip of how to check for a broken lid switch, http://www1.fixya.com/support/r9939128-whirlpool_kenmore_estate_kitchen_aid
GENE
Oct 10, 2011 | Kenmore 24032\24036 Top Load Washer
Washer will not drain, full of water.....what do I do?
next time send the model number,you could have a bad or blocked pump or a broken lid switch,close the lid and open it a few inches open and close it a few times you should hear a clicking sound,no click bad lid switch depending on the model.
Sep 25, 2011 | Kenmore Washing Machines
HI I HAVE A KENMORE WASHER MODEL #82881100 SERIAL #C92167486 THE WASHER FILLS AND NOTHING ELSE.DOESN`T AGITATE,SPIN OR DRAIN. THANK YOU IF YOU CAN HELP. BOB
you forgot the first three 110.82881100 is the full model,you'll need that to order the right parts.it sounds like you have a broken lid switch,i looked up your machine and it takes the older cherry switch part number 279347 and it's around 35 dollars.close the lid down,then open it around an inch or two,do this a few times,you should hear a clicking sound,if it isn't clicking the lid switch is broke,i'll send you a video from utube but it's for a different lid switch but you take the machine apart the same way but it's for a 247 lid switch and you need a 279347.if you can hear the motor running and this is happening you could have broken the motor coupling and i'll send that along too.http://www.youtube.com/watch?v=MFsvLiuTniU this is for the lid switch copy and paste.this is for the motor coupling http://www.youtube.com/watch?v=9K1KHEogf3c hope this helps salde
Sep 04, 2011 | Kenmore Washing Machines
Washer starts to fill whith water then stops .
next time send the model number so i can look up you machine,i can give you the part number and price.if it's a top load washer set the timer on spin,open the lid and with a screw driver push down on the lid switch,you'll see a hole in the top of the frame and a strike on the lid the strike pushes down on the lid switch and sends power to the washer,the factory doesn't want the washer to run if the lid is opened,if it starts to spin then you have a bad lid switch,the switch could be totally broken so if it doesn't run the easiest way to check the switch is to push down and the up on the switch if it makes a clicking sound the switch is good,no clicking the switch is bad.this is a common problem,let me know if this is it.if it isn't the problem send the model number.thanks.
Apr 03, 2011 | Kenmore Washing Machines
Washer stops working after first fill
is it a kenmore?if so open and close the lid,if you don't hear a clicking sound when you close down the lid the lid switch is broken,it's a safety so you can't run the machine with the lid up,if the switch is broke it kills the power to the washer.next time send the model number and let me know how you make out
Nov 04, 2010 | Washing Machines
Washer won't empty and spin
check the lid switch,open the lid and close it a few times,if it doesn't click or you don't hear a clicking sound the lid switch is broken,next time send the model number.
Jul 15, 2010 | Kenmore Washing Machines
How do I replace lid switch in a Sears Kenmore 80 series, model 1
The following link explains step-by-step how to replace a lid switch on a Kenmore top loader:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
If you have any questions about this repair, please post back and let me know. I hope this helps you.
NOTE: Kenmore is manufactured by Whirlpool so these instructions will apply.
Apr 07, 2010 | Kenmore 24032\24036 Top Load Washer
My Kenmore 26962 Washer will start its cycle once
check you lid switch
most machines will not go into the cycle
if that switch is bad
some models have a tab on the lid that dresses this swich when you close the door
but with out the proper model number i cannot help you more sorry
Oct 09, 2009 | Washing Machines
Kenmore machine stopped spin. Checked the
Check your lid switch. If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain, this is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If not activated by a lid strike, other models have the lid switch located under the washer casing next to one of the lid hinges. It is activated by a rod contacting an actuator. The mounting scews for this type are located under the operator console.
If you determine the switch to be defective, the following link explains how to access the washer interior and replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of a replacement is $25 to $35.
If you have questions, please let me know. I hope this helps you.
Key Symptoms:
If the Motor Coupling were bad the washer will not agitate or spin, but WILL drain.
If the Lid Switch fails, the washer will fill, but stop before the spin cycle and WILL NOT drain.
Aug 23, 2009 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
