Question about Dell Vostro 200 PC Desktop
I have dell vostro 200 that run fine for 3 years, but the Computer did not boot up just days ago. The fan runs really loud, the lights are blinking on the front, nothing on monitor and it beeps 4 times then pauses and repeats the 4 beeps over and over. Any suggestions as to what this could be?
    New Friend:
Power is on start pc within 10 second then restart on beep, no display
Posted on Jan 21, 2013
    President:
  • 2,678 Answers
Http://www.pchell.com/hardware/beepcodes.shtml
Posted on Aug 25, 2010
2 Suggested Answers
bob_computer
  • 3153 Answers
SOURCE: dell vostro 200 4 repeated beeps on start up
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes P
c
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Posted on Oct 05, 2009
Dell vostro 200 powers on fan, but have a black screen and cannot run is safe mode or boot up
It sounds like the Video card has suffered a catastrophic failure. Remove & go to a parts store or order from someone like Frys.com or ebay or Tigerdirect.com If you don't know how to use someones computer to look up "How to change the Video Card on a Desktop PC" & you will find a video of how to.
May 15, 2014 | Dell Vostro 200 PC Desktop
What does the amber light on a vostro 200 motherboard represt
Don't know
DO know;
The fan running at high speed, means you need to remove old Thermal Paste off of the CPU (Processor), CLEAN thoroughly, and PROPERLY apply fresh, new Thermal Paste.
Computer UNPLUGGED from power.
FOLLOW Anti-Static Precautions. If you do not know what they are post back in a Comment.
http://support.dell.com/support/edocs/systems/vos200/en/mini_tower/om_en/html/index.htm
http://support.dell.com/support/edocs/systems/vos200/en/mini_tower/om_en/html/parts.htm#wp1565324
http://support.dell.com/support/edocs/systems/vos200/en/mini_tower/om_en/html/parts.htm#wp1508953
http://support.dell.com/support/edocs/systems/vos200/en/mini_tower/om_en/html/parts.htm#wp1533914
http://www.hardwaresecrets.com/article/274
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3829122&CatId=503
Plus scroll down, and read reviews.
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 19, 2013 | Dell Vostro 200 (CU409) Motherboard
No sound coming out of my speeakers. Speakers hooked up. Note: computer would not boot up two days ago, then began doing so. COuld this be motherboard prob lem?
Hello! please go to this website: http://www.dell.com/support/drivers/us/en/19/Product/vostro-200
Here is a link to reinstall the correct bios firmware http://www.dell.com/support/drivers/us/en/19/DriverDetails/DriverFileFormats/Product/vostro-200?DriverId=R199863&FileId=2731123001&urlProductCode=False
Then choose the correct OS from the drop down and reinstall your sound card drivers. let me know how that goes!
Jul 26, 2012 | Dell Vostro 200 PC Desktop
I have a dell Costco 1500 that wouldn't come on. I changed the battery but after a few Dave it quit working again. I messed with the ac adapter & got it going but it gets really hot.
If the laptop is running to hot, the problem is in the cooling fan and blocked heatsink ports. The computer must be dismantled to access the motherboard, remove fan and heatsink, use a can of compressed air and clear out all the ports and fan, next get rubbing alcohol and paper towel, remove thermal grease from the processor and heatsink, now apply a fresh thin layer to the processor and heatsink and assemble, this will cure most heat related issues.
Apr 23, 2012 | Dell Vostro 1500 Notebook
Pc fan runs but does not boot up
Your computer is not POSTing, the procedure is all explained in my published guide entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
Happy testing
damnor01
Nov 19, 2010 | Dell Vostro 200 Mini Tower With 20" Flat...
My XPS 200 keeps shutting down and power light blinks
During when does your computer shutdown? Please check the diagnostic lights at the back as well which ones have light on it during the time it would shutdown.
Since you said that the light is blinking yellow it just says that your power supply is running outside its normal operating range. So most likely you would need a change of power supply. Maybe a higher wattage would be better.
Apr 28, 2010 | Dell XPS 200 PC Desktop
Solid orange light on my vostro 200
If your fans come on full blast then you have a bad motherboard. If the amber light blinks, you have a bad power supply.
Nov 26, 2009 | Dell Vostro 200 Desktop Computer
It will not power on when I press the power button and there is a blinking "A" light going off. When I press the power button the "A" light with a lock around it blinks, the fan sounds like it is going to...
try to run diags, press and hold fn key then press the power button an release them both at the same time when the computer turns on, check for any error message, or try to reseat your memory modules too
Oct 04, 2009 | Dell Latitude E6500 Laptop
Dell Vostro 200 PC Desktop Logo
570 people viewed this question
Alun Cox
