Question about Whirlpool Refrigerators
My Whirlpool refrigirator suddenly stopped making ice cubes. Model #ED2GTQXKQ84 Serial #SM5143540 Automatic ice cube maker
    Genius:
  • 1,622 Answers
You can do this by yourself by the following the instructions below.
Take off the back panel in the freezer, Use a nut driver or ratchet and socket with an extension, Behind the frost is the evaporator and the defrost heaters.One heater in the middle and one at the bottom. They are glass.They are glass tubes, If you can see the bottom that is great, if not use a hair dryer and defrost only the very bottom to expose the lower heater only.
Now in the refrigerator section at the top where the controls are take off the long plastics piece to expose the timer. The timer should be on the right hand side and have a little circle that is slotted. Get a flat screwdriver and turn that timer slowly clockwise just until it clicks and refrigerator turn off.This will put it into defrost.
Now look at that heater that you exposed and see if it glows and get hot. if it does , then the timer is bad.
If the heater doesn't come on theb go ahead and defrost the rest of the evaporator with the hair dryer. This will take little while. Don't poke at the evaporator.
Once totally defrosted look At both heaters.They should look like clear glass and see a silvier coilrunning through them, if they look discoloured at all then heater aare bad.The heaters come as a complete assembly with the defrost thermostat which clips onto the evaporator.
If the heaters look okay the onlyway to know for sure if they are bad is to check continunity with a meteron the plug at the end of their wiring harness. If you can check that you can splie in a new defrost thermostat to solve the problem.
However the best thing to do is replace the heater and defrost thermostat. it is easy to install.
Following the below solution this will solve your problem.
Posted on Aug 25, 2010
Why would my GE (model # TBX18SA) just stop making ice?
Is there any ice remaining in the slots of the ice maker? If not then the water control valve will need to be replaced. If the ice maker still has ice in the cube slots and does nothing then it is the ice maker that needs to be replaced. Here is the=> WR30X10093 Ice Maker for your TBX18SA and the=> WR57X10033 Water Inlet Valve
APPLIANCE 911
Mar 15, 2016 | GE Refrigerators
Ice cubes are too thin. Making on time, but no volume due to small cubes. What part will correct this?
Well this thing is made to make ice cubes so if the ice cube are to small thin then you water supply must be restricted because its cold enough to make the ice just the volume of water isn't their .Check the feed system for restrictions .
Jun 01, 2015 | Whirlpool Gold Series GI15NDXT 15"...
Whirlpool model # ed5vhexvq1 side by side ...ice maker will not dispense ice..water works but it sounds as if there is no power going to icemaker from dispenser
Does the icemaker bucket has ice cubes. If yes then your problem is in the dispensor. If no ice cubes on the icemaker bucket then your problem is with the ice maker unit.
Let say Ice cubes on the ice maker bucket and dispensor makes noise when pressing for ice cubes. Then either your ice dispensor flapper is frozen or may be ice cubes in bucket may have defrost and frozen again sticking together.
Oct 01, 2014 | Whirlpool Refrigerators
My ice maker makes ice but melts fast
All ice is the same...at or below 32FH is ice, above 32FH it's water
Perhaps your ice maker is making very small ice cubes that melt faster then bigger ice cubes, if so the your ice maker needs to be adjusted too make bigger ice cubes.
Aug 10, 2014 | Scotsman DCE33PA1BC 15in Built-in...
Whirlpool ice maker not working
Ice makers are some of the most worked part of a refrigerator and have about a five year lifespan. There are just too many things that can go wrong that can stop the ice making process. To explain the process of a Whirlpool ice maker I am going to post a Whirlpool Ice Maker Troubling pdf and a short YouTube Icemaker Repair toutorial. If you have any questions I will be here to assist you, Thanks Sea Breeze
May 23, 2012 | Whirlpool Refrigerators
My Whirlpool refrigerator Model # ED5RHEXNL00 Ice maker broken
Hello. Thanks for choosing fixya! The most common cause for your problem is that someone accidentally raised the wire in the icemaker area that turns it off. Check that first if the wire is up, push it down and within a few hours you will have new ice. The second most common problem is that the cubes in the mold got stuck in there. the fix is to use a blow dryer to free them up, then dry out the mold and spray some PAM cooking spray in to the mold to lubricate it. The final possibliity is that there is ice in the water supply line that feeds your ice maker. Once again get out the blow dryer and thaw that ice so that the water flows once again. good luck with it. regards, joe
Nov 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker cubes haning up stopping ice production
Bob Ray, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Bob Ray), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 15, 2017 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
24 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
