Question about NEC Electra Elite DTU 16D-2 Corded Phone
Soft Keys not working
Soft keys on one station are not working Other stations are still programed and are working fine. Is it possible for a user to unprograme there phone?
Yes, a user can de-program their phone if they accidentally punched feature 99, which is a clear-all code
other suggestion is that the clear cover that goes over the keys might need to be pushed down and re-secured to the base, if it is not set properly the keys cannot be pushed all the way down and it seems the phone is inoperable
Posted on Jun 24, 2008
I use a lap top, IBM ThinkPad, that has been in my docking station for a long time and it works fine in the docking station with the external key board and screen. I recently took it out of the docking...
NUMBER LOCK
You have press the NumLk key (number lock) and this changes the right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock.
Dec 03, 2012 | IBM ThinkPad T41 Notebook
The soft keys on my reciever are not functioning. I can't turn my "CB" on or off, I can't "select" and pre-set radio stations. The only soft key working seems to be the number...
By far this is not a cop out answer, but, as a Harley Mechanic, I would recomend taking it in to the dealership. If it is a 2010 it should still be under warranty, and any advice anyone will give you on this would be way more difficult and a headache than just taking it in.
May 01, 2011 | Harley Davidson FLHTCUI Electra Glide...
I want to format my htc p3400i
To perform a hard reset
1. Press and hold the left SOFT KEY and the right SOFT KEY, and at the same time, use the stylus to press the RESET button at the middle left side of your device.
2. Release the stylus, but continue pressing the two SOFT KEYs until you see the following message on the screen:
operation will delete all your personal data, and reset all settings to manufacturer default.Press Send to restore manufacturer default, or press other keys to cancel.
3. Release the two SOFT KEYs, and then press the TALK (Send) button on your device.
Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have been backed up before a hard reset is performed.
Mar 09, 2011 | HTC Cell Phones
Who is production key
Options available with the play station device inlcudes first familiarising with the user guide to ascertain the feature functionalities. Among details provided on the users ownser guide are support expert contact, disgnostic material instructions. Important knowlagde about the playstation device that least requires product keys to perform functionalities. First the devices performs as video grame device once powered on to capturs functionalities requiring disk or cartidge media to commmnece funtionalities.
Mar 02, 2011 | Ubi Soft Prince of Persia: The Forgotten...
CAN'T GET ALPHABET LETTER TO APPEAR FOR STATION ID.
Letters are on the soft pad to the left of the number keys. Very tiny, so look close. You can also lift up the mylar sheet and remove the paper sheet.
Mar 04, 2010 | Panasonic Panafax UF-890 Plain Paper Laser...
Station name
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key. (or the clear key to erase)
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
Jan 20, 2010 | NorStar T7316E Corded Phone
I need to recall the system speed dial directory on my NEC Electra telephone system. I am unable to find a memory re-call/display feature in my manual.
With this old model of phone you don't have the soft keys to scroll through the directory like the newer models have.
In order to check the system speed dials you will need to check them manually:
System Speed Dial #'s
LNR/SPD key and the system speed # 00~79
Station Speed Dial #'s
LNR/SPD key and the system speed # 80~99
This will dial the # and/or display the name associated with the speed dial.
In order to program them refer to this manual:
Elite IPK Features and Specs
Look under Speed dial-Station or System.
Nov 11, 2009 | NEC Electra Professional ETW-16DC-2
The keypad 3, 6 and 9 of my sonyericcson k750i are not functioning....
If you feel confident and competent enough, try taking your phone apart and giving the internals a good clean, take the white keypad PCB out and clean both it's contacts and the contacts on the phone's mainboard, and clear out any dust. Put the phone back together and see if that's solved the problem. It could also simply be that the keypad connector has worked loose
Key Pressed : Key presses phone appears to see
3 : 3 then left soft key
6 : 6 then right soft key
9 : 9 then back
c : c then #
left soft key : 3 then left soft key
right soft key : 6 then right soft key
(All the other keys worked correctly)
As I didn’t know what was causing this I attempted to move all data stored on the phone to the memorystick so I could master reset and possibly reflash, although after this I returned to the homescreen to find all keys had started functioning correctly again,
9 : 9 then back
c : c then #
Jun 25, 2009 | Sony Ericsson K750i Cellular Phone
LANIER LX231 WITH LANIER VTI LX547
We use this equipment in remote locations and have found that the type of phone needs to be a centrex line, such as is used on a fax machine. Note: in the past, we used to have to use an "analog" phone line, which is just a normal phone line.
You probably have two different phone lines involved here.
Jun 12, 2008 | Lanier Audio Players & Recorders
Phone doesn't ring at station
Sounds like your station (phone) is set to not ring. You need to check your ring assignment.
Feat # *
Enter password (default is 000000)
Press the soft key under "show"
Press the soft key under "next" until 1. STATION appears in the display.
Press the soft key under "show" SHOW STA:_ appears.
Enter your station number and press the show soft key
Press the "next" soft key until RING ASSIGNMENT shows on the display.
Press the "show" soft key. You will see CO LINE 1 : followed by NONE or DAY or NITE or BOTH.
If it says NONE, your phone never rings for an incoming call. If DAY or NIGHT your phone rings depending on the time of day and the time definitions for DAY and NIGHT programmed into the KEY unit. If it says BOTH, your phone should ring all the time.
If you need to change the setting, press the "chg" soft key until the desired setting comes up.
When you're done with LINE 1, press the "next" soft key to move to the next line. Repeat the process for all your active lines. Obvisously changing settings on lines with no CO connection will have no affect.
While your in the mode, check your RECEIVE ASSIGNM as well to make sure your phone is configured to receive incoming call. It was the station feature just before the RING ASSIGNMENT feature.
Hope this helps.
Jun 04, 2008 | Vodavi Starplus SP7314-08 Corded Phone
NEC Electra Elite DTU 16D-2 Corded Phone Logo
151 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
