Question about Nikon D70 Body Only Digital Camera
What does HR in a Nikon D70 mean? - Nikon D70 Body Only Digital Camera
  • 1 more comment
  • Steve Aug 25, 2010
    Where do you see "HR"? If it appears in the viewfinder or display - what are you doing when it is seen? What mode are you in? Is there a speedlight on the hot shoe? Please provide as much info as possible. I do not recall ever seeing it on my D70 - and I can't find mention of it in the manual.
  • hernandez384 Aug 25, 2010
    The camera went dead: the shutter not provoking a response. The screen said "this card can't be used" and, HR appeared in the control panel. The camera did, recently, say the card was unusable, but I was still able to use it, but not this time.
    The shutter stopped getting a response and the screen back of the camera said the card could not be used. Then the control panel showed HR. The camera recently said the card couldn't be used but it operated anyway, and I was able to get some shots which I was able to post. But this time it kept shouting HR at me, and wouldn't budge!
  • 560 Answers
Hi. HR is an error code which is related to the memory card. It doesn't have exact meaning (as far as I know, its not in the manual and website).
There are several possibilities why you are getting this error. It could be corrupted memory card, damaged pin, loose connection between the memory card and camera, dirty contacts, camera is not giving enough power to memory card, etc...
Some fixes that may work:
- Make sure your battery is fully charged.
- Remove memory card and put it back making sure the connection is not loose.
or
- Clean the gold contacts using pencil eraser. Remove eraser dust with cotton buds.
or
- Format the memory card on the camera.
- If all fails, use a different memory card.
Good luck.
Posted on Aug 25, 2010
I have Nikon af s 300mm f2.8, it only work with D3s, D300s but not with my D70. Can you tell me why and is it lens problem or camera
Hiyour lens should be af-s 300/2.8 vr.. nikon product are all compatible. which means your d70 something wrong I think. If you have bundle lens with d70, you can check it out easy. usually d70 comes with af-s 18-55 which is pretty much same work method with af-s 300. THanks and best regard!
May 26, 2011 | Nikon Cameras
Nikon d70 keeps popping up with "CHA". Wich means
You could try formatting in on PC by right clicking the card's icon in My Computer to bring up the options, then format it on the camera as well
Dec 16, 2010 | Nikon D70 Body Only Digital Camera
I have a Compact Flash card of 512mb (CF card) i use this card in my nikon D70, i went to my friend house and tried connection my camera to his comp to download image, but my friend machine was infected by...
Guide to recover deleted photos from Nikon D70?
Connect Nikon with PC
Using a USB cable or putting SD card into an SD card reader to connect Nikon with Computer.
Scan Nikon d70- Running the Nikon Photo Recovery,you can choose Nikon media drive and click "Start Scan" for scanning
Recover deleted photos
After scanning, you will see all recoverable media photos and videos with file type. At last, click "Recover" to recovering deleted Nikon D70 photos.
This Photo Recovery also can recover all photos files from Nikon D3100 like JPEG, BMP, TIFF, GIF, etc. Support all Nikon camera.
For full details please refer to Nikon D70 Manual.- https://guideusermanual.com/product-name-d70-manual&po=4425&lang=English
Mar 28, 2017 | Computers & Internet
Self timer in nikon d70
Hello. I have a Nikon and it is a great camera. here is the owner manual for your D70. Go to page 105 and 106 to use the self timer.
http://www.nikonusa.com/pdf/manuals/dslr/D70_en.pdf
please rate my answer as very helpful. thanks, Joe
Apr 26, 2010 | Nikon D70s Digital Camera
Nikon D70 batteries discharging too quickly
Try switching to the EN-EL3 EN-EL3a 1500mAh Li-Ion Battery for Nikon D70..or a 1800mAh.
Mar 17, 2010 | Nikon D70 Digital Camera with 18-50mm Lens
My nikon d70 says that file does not contain image data
If the memory card came from a different camera and inserted into the Nikon D70, the error message will appear. Just format the memory card with the D70 and the error should disappear.
Hope this helps.
Andrew
Feb 05, 2010 | Nikon D70s Digital Camera
Received an r05 notation on the number of exposure box of my Nikon D70. What does this mean? There is not annotation to such an error notice in the manual.
It's simply telling you that you can take five more pics in a burst before the buffer fills up. It's not an error, it's supposed to do that.
It's only a problem if it gets to r00 and stays there.
May 12, 2009 | Nikon D70 Body Only Digital Camera
Cant take any pictures ... code reads off r33 what does that mean
check to see if auto lever on rear is on dot. I accidentally moved mine and camera would not focus or fire when I was in automatic mode. I went to manual and everything was okay. Switched back to full auto and had same old problem.
Mar 01, 2009 | Nikon D70 Digital Camera with 18-70mm Lens
Nikon D70 flash doenot fire
According to my information, the camera may need a new flash PCB (printed circuit board). Check the repair service search on this site for someone in your area. The part number for the circuit board is: 1S014-020-1 and runs about 50$
Sep 21, 2007 | Nikon D70 Digital Camera
D70 USB setting issue
Users of Windows 98SE, Windows ME, Windows 2000 and Mac OS 9.x may experience problems trying to download images from the Nikon D70 using Nikon View. Initial shipments of the D70 have the USB option in the "Set up" menu set to PTP - Picture Transfer Protocol. PTP is only compatible for downloading images with Windows XP and Mac OS X. To solve this issue please set the USB menu option to Mass Storage and then connect the camera to the computer. The D70's card will then mount like a removable disk and Nikon View will be able to transfer images
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Nikon D70 Body Only Digital Camera Logo
366 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
