Question about Logitech MX1100 LASER Mouse
Can't switch the mouse buttons between click and right-click
Try "uberoptions"... this add on is for setpoint and it allows any assignment to buttons..
ilteri? MUTLU
iltermutlu
Posted on Oct 28, 2010
3 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: HP Optical Mouse right click button does not work
Hello PearlySue,
Just download the latest driver for your operating system HERE
and reinstall the driver. Once you've done that, reconnect the mouse and hopefully, it should work. If it does, it would be that the mouse is kaput and you may have to replace it. If it is under warranty, just take it back to the point of purchase and get it replaced. If not, you may have to purchase a new one. But do try the latest driver download first and see...
Should you have any further questions, please feel free to post them here. Please do not assign a rating until you feel your problem is resolved. I will try my best to help you further if need be.
If you are satisfied with my solution or have no other questions, please close the problem by assigning a FIXYA rating for my solution. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 20, 2008
d-ruffles
  • 65 Answers
SOURCE: hp optical mouse right click button does not
More than likely the mouse has "worn" per se. I know, not proper terminology, but best to understand. So my suggestion is to get a new mouse, not much you can do unless you take it apart and replace the bearings or button yourself. I'm sure there is a guide for such thing. But if you don't have time then you should just buy a new one from Wal-Mart or your local computer store.
Hope this helps. Good Luck!
Posted on Jan 03, 2010
This is a problem with a iHome Laser Mouse product. ihome 3-Button Laser Mouse Model Number- iH-M120LB Serial Number:0906001183 I am having trouble using the left click button on the mouse. I...
When you change the left mouse pointer to be the right mouse pointer in the settings of the mouse, then if the right mouse button stops working, it is a software problem and reinstalling drivers is the way to go. If on the otherhand the left mouse button still does not respond, then there is a problem with the switch in the mouse. This is hardware related. Either clean the mouse or buy a new one.
May 11, 2017 | iHome 3 Button Fast Track Laser Mouse...
I can't figure out how to change from right hand click to left hand. Please tell me how to do it. thanks
start run control panel mouse/ buttons/ configuration
press ok............
cheers
Mar 27, 2011 | Computers & Internet
Left click button wont work
Hi, it is either a:
1., software problem (check control panel => mouse for options)
2., hardware issue, listen to the sound of it clicking, if it sounds different from (for eg. weaker) than the right click than it is a faulty switch
You may try taking apart and replacing the switch if you another mouse lying around.
But if are not experienced with soldering, just remap the left click in control panel (replace left click with right click and right click with middle button) or get a cutom mouse utility to do the same.
This way you can use it while you get a new one.
Mar 03, 2011 | GE 97985 Mouse
My mouse switched to left hand and i need it right hand
- Click on Start
- Click on "Control Panel"
- Click on "Mouse"
- Untick "Switch primary and secondary buttons"
- Click Ok
Feb 28, 2011 | HP Wireless Optical Mouse
HOw to replace the mouse left click and right click
The mouse click changes are based on OS used.
In windows OS ..Click Start button on your windows desktop. Select and click on Control Panel from the menu. Select and click Mouse from the control panel. From the Mouse Properties Window, select the Buttons tab. Select and check the Switch Primary and Secondary Buttons check box. Click the OK button.
Your mouse buttons should now be switched around, so now when you click your left mouse button, it will behave as a right-click, and clicking your right mouse button will behave as a left click.
Dec 01, 2010 | HP Compaq Presario C306US Notebook
My mouse has stopped working
The mouse buttons may have been swapped from LH to RH or vice versa.
Go to Control panel - Mouse - Buttons tab - in Button configuration click the selection box (Switch primary and secondary buttons) with the right button on the mouse.
If you have used the wrong mouse button then select it again with the correct button.
Then click Apply and then OK.
May 26, 2010 | ASUS F5R-AP038A Notebook
How do i change the mouse buttons on a compaq 6735s
Are trying to switch to lefthanded settings?
Converting to Left Hand Mouse for Windows XP Users:
  • Call up the Start menu by clicking on the Start button or by pressing the Windows logo key (located between the Ctrl and Alt keys). Alternatively, you can press Ctrl + Esc
  • Click on Settings and select Control Panel.
  • Double click on the Mouse icon to display the Mouse Properties
  • Select the Buttons tab and click on the check box marked Switch primary and secondary buttons to set the mouse buttons up for left-handed use.
  • Click OK or press Enter to confirm your choice and exit the mouse properties (note: you should be using the mouse’s right button now to make selection)
http://www.tipandtrick.net/2009/customizing-the-mouse-for-left-handed-users-in-windows-xp/
Jan 02, 2010 | HP Compaq 6735s Notebook
I have a new HP7900 tower, with aHP mouse. I have
Hello If your using Windows software (xp , vista) open controll panel and then right click and open the mouse icon.Under the buttons tab you can choose right or left hand operation.Be sure to click apply at the bottom of the box before you close it.
Dec 10, 2009 | Office Equipment & Supplies
Right and left click are working backwards
Go to control panel, mouse, buttons tab, uncheck "switch primary and seconday button"...
Pls rate this solution.
Apr 07, 2009 | Microsoft Wireless Notebook Optical Mouse...
Right button doesn't work; single click with left button
You can probably repair this yourself if you are technically inclined and careful.
There is a tutorial here showing how to disassemble the mouse: http://www.vk2k.com/Logitech-MX1000-Battery/
The microswitches for the buttons can be opened if you are very careful, and then you'll have to clean the contacts. Regular rubbing alcohol should work fine. Be careful not to lose any parts when opening the switch.
If the switch contacts have corroded, you may have to replace the contacts or the entire switch. You may be able to take a similar switch from another mouse (many manufacturers use similar switches). SWometimes there are MX1000 or similar logitech nonfunctioning mice being sold on eBay for parts.
Good luck
Mar 03, 2009 | Logitech MX1000 Laser Cordless...
Logitech MX1100 LASER Mouse  Logo
69 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
