Question about Cisco 7960 IP Phone
I have tried repeatedly and I can not get my phone to set up. Not even sure what the phone # is. I need it from the start to the finish. I also need my work # to forward to my cell phone 817-713-1767.
    Champion:
  • 331 Answers
What service are you using to provide your SIP? The 7960 requires a call manager, or other network bootable server to make the phone function. It will not function on its own.
Posted on Aug 27, 2010
How do I get my phone to ring again - it automatically goes to silent even though I don't have it turned tO SILENT
Do you have "do not disturb" set? In settings, check under "sounds" try turning off "vibrate on ring" if it is set and be sure you have a ringtone set - also try different tones to be sure they play properly. If that fails - a hard reset can't hurt (hold power and home until you see apple logo then release and wait for phone to finish booting). Toggle the switch off-on several times in case it's failing and slipping on the internal part of the switch... and if everything still doesn't work, possibly the switch did fail.
Feb 15, 2016 | Apple iPhone 5S
In CW mode only, when switching from SEND to receive, there is a brief audio tone at the same frequency as the sidetone even with the ST disabled. Can't find it.
IM not 100% sure but it sounds as if what your experiencing is normal , for a send to listen transisiition If I remember this function is called Ping , and it was common on older sets to let the repeater know you had finished so it would switch from send to receive faster (no time out) I think this feature was inside the mic ? and could be added to radio later if you wished it too . your radio might have a setting for use with repeaters , you should be able to shut it off in settings
Feb 09, 2016 | Radio Communications
Can I check my messages from a phone outside my home, is it possible to make a remote enquiry? And if so, how does it work?Thanks in advance for your answer. Regards, Joy
Remote Message Retrieval
You can operate your answering system from a remote location using any touch-tone
telephone or the handset.
Remote access away from home
You can check, play, or delete messages, even record a new greeting message when
you are away from home. Additionally, you can turn On or Off your answering system
from a remote location.
Remote access:
1) Call your telephone number and wait for the system to answer. If the answering
system is off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off),
press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code" in your owners manual.
3) The answering system announces the current time and the number of messages stored
in memory. You hear "To play incoming messages, press zero-two. For help, press onezero".
You will hear a beep.
4) Enter a command within 15 seconds, each command there after must be entered
within 2 seconds. You may select a command from the following chart:
For your convenience
a remote operation
card is provided for
you to use while
away from home, it can be found in the back of your owners manual.
Command Function
0 then 6 Answering System On
0 then 7 Memo Record/Stop **
0 then 8 Greeting Message Record/Stop **
0 then 9 Answer System Off
1 then 0 Help Guidance
Command Function
0 then 1 Repeat a Message*
0 then 2 Playing incoming Messages
0 then 3 Skipping a Message
0 then 4 Deleting a Message
0 then 5 Stop Operation
* For Repeat a Message function, press 0 then 1 within about four seconds to
repeat the previous message, or press 0 then 1 after about four seconds to repeat
the current message.
** For Memo Record and Greeting Message Record function, the first time you enter
the corresponding command, it starts the Recording function. If you want to stop
the recording, press 0 then 7 or 8.
5) After the command has finished, you hear intermittent beeps indicating that the
system is in the command waiting mode. You may enter another command at this
time from the chart above.
6) When you are finished, hang up to exit the system. The answering system
automatically returns to standby.
Your machine automatically has a PIN set of 80.
If you are trying to use remote access from a cellular phone and having trouble: Try changing your tone length on your cell phone to long.
May 25, 2011 | Uniden Cordless Phone
Mobile hung on align screen page despite aligning screen several times. mobile was working fine. suddenly system was hung. tried to hard format using call and end button on start up page. ever since the...
Please try this with windows XP
Make sure you:
Turned off any Firewall you have on the PC.
Not running the update in Safe Mode.
Not to perform any other work on your PC.
Make sure the phone is fully charged (important)
Do not update from a PC where you have limited rights. Eg. Internet Cafe, Work etc.
Prefer Laptop as if you have electricity dropped you will have some extra battery and wont harm your phone.
Use only one USB port for you Omnia update, the best one it works for you. Do not try multiple.
Steps used for updating under Windows XP (32 bit).
  1. Make the Install Microsoft ActiveSync 4.5 (once)
  2. Make Install the Samsung Modem Driver XP (once)
  3. http://rapidshare.com/files/179674742/MODEM_DRIVER_FOR_XP.zip
  4. Reboot the PC.
  5. After the first 2 steps try to disconnect your Omnia from USB and connect it back on. Repeat it 1-2 times so the PC can recognize the phone.
    Leave the phone connected for about 10-15 minutes. If it disconnects by itself most probably you have to repeat the procedure from 1st step.
    It is advised to reboot your PC also.
  6. Make sure that have backup all your important stuff (contacts, pictures etc).
  7. Switch OFF the phone by holding the Power button for ~5 seconds.
  8. Run the updater. (Works the same way for Original or Cooked ROMs)
  9. Switch ON the phone again by holding the Power button.
  10. Press START and happy flashing. Do not move your phone or the USB wire as it might fail during flashing.
  11. Wait until the updater shows JOB DONE! DO NOT DISCONNECT BEFORE.
  12. Disconnect your phone.
  13. Leave the phone to reboot 2 times, calibrate screen and finish the start-up procedure.
  14. Enjoy the new firmware.
This is for windows 7 and vista
Things you'll need on Vista:
VMware Workstation (latest will work)
Microsoft Windows XP CD or .ISO image and the serial key
2gb of free disk spaceSafety Tips before starting:
Use the ones that mentioned for Windows XP.
Make sure you turn off the USB on the Windows Mobile Device
Center.How-to disable it. Go to Windows Mobile Device Center:
Mobile Settings -> Connection Settings -> Untick "Allow USB Connections".
After flashing tick it back.Let's start:
  • First install VMware's Workstation. You can get a trial version at http://www.vmware.com/
  • If you have an .ISO image of your Windows XP CD on your hard disk like I do, you won't need the CD, otherwise you'll need it. If you don't have the image, put the CD into your CD/DVD-ROM.
  • Run the workstation.
  • Go to FILE -> NEW -> VIRTUAL MACHINE and choose TYPICAL. On the next tab select the source from where you want to install a virtual Windows XP operating system (CD or image).
  • On the next tab, press next. When the dialog appears, choose YES.
  • Now enter a name for your virtual XP machine and choose a location where you want to save the machine - it's good to have at least 2gb of free space!
  • On the nex tab, I've chosen 2.5gb. I think that's enough, if you wish only to flash your ROM. You can choose to install the machine to a single file or splitted. I've chosen single.
  • On the next tab, click Customize Hardware button and select "USB Controller". Make sure High-Speed USB 2.0 and Auto connect USB devices are checked. Press OK, then press FINISH.
  • Maybe you'll get a warning from VMware but don't bother, just skip it.
  • The Windows installation process should follow. The installation took on my PC for about 25min.
  • When the setup has finished, you can normally run and use Windows XP via WMware.
  • Update your XP machine via Windows Update, reboot and start flashing.
Flashing:
  3. Reboot the PC.
  4. After the first 2 steps try to disconnect your Omnia from USB and connect it back on. Repeat it 1-2 times so the PC can recognize the phone.
  5. Make sure that have backup all your important stuff (contacts, pictures etc).
  6. Switch OFF the phone by holding the Power button for ~5 seconds.
  7. Run the updater. (Works the same way for Original or Cooked ROMs)
  8. Switch ON the phone again by holding the Power button.
  9. Press START and happy flashing. Do not move your phone or the USB wire as it might fail during flashing.
  10. Wait until the updater shows JOB DONE! DO NOT DISCONNECT BEFORE.
  11. Disconnect your phone.
  12. Leave the phone to reboot 2 times, calibrate screen and finish the start-up procedure.
  13. Enjoy the new firmware.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 29, 2010 | Samsung SGH-i900 Omnia Unlocked Cellular...
How do I change the Baud rate on a canon f80 fax
To set the receive speed
Change RX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (RX or send) speed if this message appears frequently on the LCD.
  1. On the operator panel, press <Menu>.
  2. Press the left '<' or right '>' arrow repeatedly until [USER DATA] appears.
  3. Press [Set].
  4. Press the right arrow repeatedly until [FAX SETTINGS] appears.
  5. Press [Set].
  6. Press the right arrow repeatedly until [RX SETTINGS] appears.
  7. Press [Set].
  8. Press the right arrow repeatedly until [RX START SPEED] appears.
  9. Press [Set].
    1. The factory default RX (send) Speed is 33600 bps.
    2. You can select from the following RX Speeds:
      14400 bps
      9600 bps
      7200 bps
      4800 bps
      2400 bps
  10. Press the right arrow to display the applicable RX Speed.
  11. Press <Set>.
  12. Press <Stop> to return to standby mode.
To Set the Send Speed
Change TX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (TX or send) speed if this message appears frequently on the LCD.
  3. Press [Set].
  5. Press [Set].
  6. Press the right arrow repeatedly until [TX SETTINGS] appears.
  7. Press [Set].
  8. Press the right arrow repeatedly until [TX START SPEED] appears.
  9. Press [Set].
    1. The factory default TX (send) Speed is 33600 bps.
    2. You can select from the following TX Speeds:
      14400 bps
      9600 bps
      7200 bps
      4800 bps
      2400 bps
  10. Press the right arrow to display the applicable TX Speed.
You can download a copy of the user manual for the F80 at
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=7175
Please make sure to rate this solution. Thanks.
  1. Press <Set>.
Apr 29, 2010 | Canon MultiPASS F80 All-In-One InkJet...
My nokia E63 can't boot?
1.remove the battery..
2.leave it for 1 minute..
3.place the battery again..
start your phone..
if its not starting or a long blank screen appears repeat step 1,2 & 3
before starting your phone press button 3+*+power button simulatenously..
this will boot/hard reset your phone back to its original factory setting.
Make sure you back up all data before trying these steps!
Jun 16, 2009 | Nokia E63 Cell Phone
Problem setting up voicemail
Check the procedure is correct.
1 Tap Voicemail, tap Greeting, then tap Custom.
2 Tap Record when you’re ready to start.
3 When you finish, tap Stop. To review, tap Play.
To rerecord, repeat steps 2 and 3.
4 Tap Save.
Hope this helps
Regards
Apr 17, 2009 | Apple iPhone 3G
I was just on the phone and finished my conversation and out of nowhere it powered off. I went to reboot it and the loading bar goes all the way up and the screen goes black. It keeps repeating this over...
i was texting and my nokia surge just turned completely off.it has no damage to it..i tried charging it but it wont even turn on or show that its even charging i dont know whats wrong with it n i dont have a warranty...
Sep 23, 2008 | Cell Phones
Samsung SCH-u740 problem - front screen stays on and speakerphone switches automatically
I would recommend a hard-reset of the device. Keep in mind that this will delete all of your contact information and customized settings.
On a side note, be careful not to accidentally press the speaker-phone button on the right side of the phone during a call. I used to have this phone and I would sometimes do it without even realizing it.
Apr 24, 2008 | Samsung SCH-u740 Cellular Phone
Cisco 7960 IP Phone Logo
53 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
