Question about HP F4480 All-In-One Printer
My HP Deskjet F4400 scans photos very dark & adjusting the colors doesn't help at all. Is there something I can change so this doesn't happen anymore?
weblord
  • 507 Answers
SOURCE: Press the Scan button on the printer and it asks me to insert the
the software was not completely installed, that's why. do a complete uninstallation first of the said program/software driver and then restart computer, then do a complete installation this time.
Posted on Jun 09, 2009
DosHog
  • 168 Answers
SOURCE: The color is not adjusted right.
The first step is to determine whether the problem is in the printer or the driver.
Run an alignment test and then, using the printer menu, print a picture that is within the printer.
If the internal picture has the same problem, and all ink cartridges are flowing properly (you will be able to tell from the alignment test), printer replacement is going to be the least expensive repair.
If the internal picture prints ok, then try printing a picture from the computer again. If that gives you the old problem, disconnect the printer from the computer. Then, uninstall the printer, reboot twice and reinstall the driver, hooking up the printer when asked.
Posted on Jul 28, 2009
SOURCE: HP deskjet f2280 won't scan
you can try clicking MY COMPUTER then C: then PROGRAM FILES then Hp then Destination folder then bin then find the hpscnapp with a printer icon.Scan will work.Hp 2280 frequently encounters error especially if you're using VISTA. Hope i helped! Good day!
Posted on Aug 05, 2009
Roonie Tunes
  • 136 Answers
SOURCE: Why won't my HP Deskjet F2100 scan a image?
Try scanning from your PC, if you have a program that will allow it... if you have Word '97, you can do it like this:
  1. With your scanner ready and the image on the scanner glass, in Clip Organizer, on the File menu, point to Add Clips to Organizer, and then click From Scanner or Camera.
  2. In the Insert Picture from Scanner or Camera dialog box, under Device, select the scanner.
  3. Click Insert. The new clip appears in the My Collections folder, in a folder named after your scanner
If you do not have Word '97, but a program that SHOULD work but doesn't have the correct driver, go to www.twain.org for the latest twain-compliant drivers for your scanner! You may also be able to find a simple scanning app (in the downloads section) at www.cnet.com
Hope this helps!
-- RT
Posted on Sep 03, 2009
MalKontent68
  • 748 Answers
SOURCE: how do I lighten color on hp deskjet F4400 series?
Explain what you want to accomplish please.
If yor printer soaks plain paper with too much ink, go to printer properties and change the media type to plain paper, and the print quality to Standard or even Draft.
If however you want to print pictures on photo paper, and they are too dark/saturated, you need to adjust the photos using some picture edit/touchup application - there are plenty of them available free online, or on computer magazine CDs etc.
Posted on Dec 30, 2009
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
    If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
    For additional support please visit http://www.inkjet411.com
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
Will HP 60 ink cartridge work with HP Deskjet 2460? Tnx.
This is all HP recommends for the HP Deskjet 2460, so I wouldn't suggest buying anything else. First of all it might not fit and second, even if it fits, other issues may come with using those. If you can't see the list here it is:
HP 21 Black HP 21 Black Twinpack HP 21/22 Black/Color Combo HP 21/22 Quad Pack HP 22 Tri-color Twinpack HP 22 Tricolor HP 58 Photo
Jun 23, 2011 | Office Equipment & Supplies
How do I scan with HP psc 1210
Answer is on this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02455373&lc=en&dlc=en&cc=us&product=90764#N305
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Jan 24, 2011 | HP PSC 1210 All-In-One InkJet Printer
How to instal HP Deskjet F4400
use the link below to install the driver so the scanner will operate for you
http://bstdownload.com/tagged/hp%20F340%20driver/
Jul 30, 2010 | Visioneer 4400 Flatbed Scanner
The scanner won't scan to the computer, but when I test it in scanners & cameras it says it is working.
This is my solution :
1st step : Turn on your *HP Deskjet F4185*.
2nd step : Click the Start menu.
3rd step : Click Devices and printers. A new window will appear.
4th step : Then, click the "Fax button ".The window Fax and Scan window will appear.
5th step : On the lower left corner , click "Scan" below the "Fax" button.Scanned documents (if there's any) will appear.
6th step : Click "New scan" button below the "File" button. And your printer will start! Glad to help..
Mar 29, 2010 | HP DeskJet F380 All-In-One Printer
How do I lighten color on hp deskjet F4400 series?
Dec 30, 2009 | Office Equipment & Supplies
Jun 09, 2009 | HP Deskjet F340 All-In-One Printer
Ink tone
Hi Pam -
This is a common problem with the CX 5000 - there is no contrast control (i.e., light/dark) like you would have on a photocopier. But if you use the scanning mode (EpsonScan) instead of the copying mode, there are a couple of alternative options that might help:
1) Brightness - in the EpsonScan program, in Home Mode, under Image Adjustments, there is a button labelled "Brightness." Depending on the colors and contrast of what you're copying, adjusting the brightness may help.
2) Color Restoration - In both Home Mode and Professional Mode, this feature is meant to restore the color to a faded photo - depending on the colors of your document, it may make the copy lighter or darker, but it's an option.
Hope this helps!
Dec 11, 2008 | Epson Stylus CX5000 InkJet Photo Printer
HP F4180 Printer not printing in correct colors.
http://h10025.www1.hp.com/ewfrf/wc/solveCategory?lc=en&dlc=en&cc=us&lang=en&product=3235312
HP recommends that you follow the above link to proceed with the troubleshooting of your problem.
If this doesn't help, please let me know!
regards,
ROnald.875083
Sep 04, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
HP F4480 All-In-One Printer Logo
70 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
