Question about Samsung HCM5525W 55" Rear Projection Television
Need the part number for the red projector, convergence. I can adjust the blue Hor. and Vert. but I cannot adj the red in any direction
  • 74 Answers
TRY AUTO CONVERGENCE
Posted on Aug 25, 2010
  • jlavadjm Aug 25, 2010
    I did, and it isnt working, I tried "Manual Convergence, and I am able to move the Blue, and Line it up, but the red is way out and will not adjust.
Convergeance procedures
No brand or model here and are needed--on almost all sets it is done with the remote.
Nov 04, 2012 | Televison & Video
Convergence issue; red 3D effect. In grid convergence mode blue will converge w/green fixed lines and red horizontal will but the verticle red will not adjust far enough left to converge. has ajustment...
Convergence is dead.Must know how to solders?Must replaced ICS and all of it resistors.Tries Tv repair World.com,Tvrepairkits.com for a convergence kit.The shop will cost u $300 for parts and labors.
Jan 24, 2010 | Hitachi 43FDX01B TV
Adjust color, need service manual
On controlls the foucus...the other the brightness. I would not mess with them. 99% of the time the problems is one of the two listed below...
You have one of two problems. Sometimes both.
Problem #1) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #1
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Problem #2)
Your TV may have a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSolution # 2
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 05, 2009 | Philips 9P5544C 55" Rear Projection...
Red lines running through tv
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 17, 2009 | Sony KP-51HW40 51" Rear Projection...
Colors shadowing eachother, adj convergence, but will not save.
Sounds like your convergence IC chips have failed. You can buy the parts from various suppliers or you can just get a complete repair kit from www.TvRepairKits.com
Mar 15, 2009 | Philips 46PP9302 46" Rear Projection...
How do I ADJ the convergence on my PTL555U projector?
These adjustments are internal to the machine, It is not a recommended user adjustment. Typically these are set at the factory under controlled conditions using a known signal source. Also, I'm not 100% sure about your model (I'll investigate further), but it may not be adjustable at all. How far out does the convergence appear to be? Can you see it under normal use conditions or only when using the test pattern?
Thanks,
Dan
Mar 06, 2009 | Panasonic PTL500U Multimedia Projector
CRT Rear-Projection Red Vertical Alignment
You may have a convergence problem. Here are some of the most common symptoms and example photos.
  • Screen looks 3D
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Oct 11, 2008 | Philips 51PP9200D Television
Apex gb55hd09w triple vision
Go in and find the conv ICs, they will be mounted on a
big heatsink and the wires going to the conv yokes will
most likely plug in somewhere closeby.
Conv ICs are the workhorse of the CRT RPTV, and it is
not unusual at all for them to need to be changed out
at some time in the life of a CRT RPTV.
Mr Bob
Comment by MrBob84, posted on Feb 04, 2008
PS -
The wires for the conv yokes at the CRT necks are the
thin ones. The thicker ones are for the hor and vert
sweeps, which must never be disconnected from their
circuitry during CRT operation.
If your beam loses sweep on any of the CRTs, it will
instantly score/gouge your phosphors on your CRT faces,
vaporizing the phosphors there and ruining the CRTs.
The beam is very powerful, but in normal operation
moves incredibly fast, not damaging anything. Any
slowdown of the movement of the very powerful beam that
draws the picture, acts like the searing vaporizing beam in Tom Cruise's War of the Worlds.
Feb 04, 2008 | Televison & Video
Center adjust on Red gun is not aligning with B&G vert.
frist set blue and green than set red itwill shoew yu single chakall will be focous in single line than than gun will be allign horizontal if it will correct if itisnot comming than cathode problem.
Oct 06, 2007 | Sony VPH D50HTU Multimedia Projector
Convergence problem w/ red horizontal only-WS-65807
Do not try to adjust anything yet!! Adjustments do not get out of alighnment all of a suddenly. The convergence adjustments are there to do minor aging alighnments. I would first check for bad solder connections on the convergence IC's first.
Sep 08, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Samsung HCM5525W 55" Rear Projection Television Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
