Question about Car Audio & Video
Every now and then, the ignition key locks tight in my Dad's Renault Megane Scenic (1998) and cannot be turned left or right or removed. My Dad says that he tries everything he can think of to release it but it seems to have a mind of it's own and only allows itself to be turned or released when it feels like it. Is it because of some kind of safety system that my Dad doesn't know about or is something broken? Please help!
  • 2,200 Answers
There is no specific safety mechanism on the Megane causing this problem. The possible causes of this are;
1) The steering lock jamming against the ignition and making the ignition barrel hard to turn. This will also cause the key to jam in the ignition and the barrel will not turn.
This is easily resolved by rotating the steering wheel back and forth whilst turning the key in the ignition at the same time. The important thing here is to lift the weight of the steering off the locking mechanism by turning the steering wheel away from the point where it has engaged the locking mechanism.
This will release the key and allow it to turn freely in the ignition barrel.
2) The second possibility is a worn ignition barrel which has become sticky. The pins in the tumbler of the ignition switch sometimes jam or seize up. Often this can be resolved simply by spraying some WD 40 directly into the keyhole.
Turn and work the key in and out of the ignition a few times to help work the lubricant in aroung the pins inside the tumbler. Finally wipe off any access lubricant and you are done.
3) If the key gets stuck in the ignition or will not turn or come out - one handy emergency solution that often works is to tap the end of the key whilst it is still in the ignition with the handle of a plastic screwdriver or similar tool. This often has the effect of loosening the pins inside the mechanism enough to release the key or allow it to turn and get you started.
4) A badly worn ignition will need to be replaced if it fails to loosen up with the WD 40.
Please do leave a vote for the solution. Thanks.
Posted on Aug 25, 2010
Imobiliser renault scenic megane is stuck on and can't start car, car will turn over key fob will lock/unlock car had to replace ignition barrel so battery has been off
tight you replaced the lock barrell so you have new keys ,now inside this key is a chip so remove the chip from the old ley and tape it to teh transponder ,now make sure the chip that was inside the key is removed by whatever means you have to use even drilling it out.Then it will start as what happens is the new lock has the key programmed to a code for instalisation in a new vehicle and the chip in the key is confusing the transponder its a renault remember and they do have a mind of their own in regards to the immobilisor ,if you do as i say it should start if it doesnt then lock and unlock the drivers door three times slowly then jump in quick and start car within 20 secs of the key turning procedure and if that doesnt work then call the dealer and pay through the nose
Sep 24, 2011 | Renault Sport Cars & Trucks
Can any one help,i have a renault megane scenic s reg,back right door will not open from inside or out can any 1 help please
sounds like the locking mechanism froze up. you'll need to remove the door panel and lubricate the lock
Mar 17, 2010 | 2000 Renault Sportwagon
1998 renault megane ignition problems. My wifes Renault megane scenic 1998 has has nothing but problems since we bought it. The most recent being as follows. I was driving the car and stalled it. from then...
it sounds like one of three things are happening
1.your battery has adead cell in it and does not have enough cracking amps
2. your alternater isn't charging your battery enough
3. your starter is worn out causing it to need more amps to turn over
You can go to your local auto parts store and have them test your battery and charging system usually for free. if the battery and charging system checks out then pull the starter off and have it tested.
Oct 17, 2009 | 2000 Renault 181
Scenic power steering not working on right turn.
yes its the pump torque unit you need to replace your pump.sorry
Sep 19, 2009 | 2002 Renault Sportwagon
Can some one tell me how to turn off child lock on my 1998 Renault Megane??? I cant open the door from outside.
Cant you tell me where to turn on the child locks on a 54 plate Renault scenic please???
Apr 19, 2009 | 2000 Renault 181
My renault megane scenic engine is locked
do you mean that your engine is not turning by key or by hand?
Jan 22, 2009 | 2004 Renault 181
Speedometer wont move
You probably have a broken speedometer cable. Was the needle wagging back and forth and making strange noises periodically before it quit working?
Jan 14, 2009 | 2000 Renault 181
R reg Megane Scenic non start
Hi
Well, no noid signal and no spark says to me that the crank sensor is at fault.
Does the check engine light come on when you turn on the igntion? If not then the ECU is not waking up.
Regards
Geordie
Jun 11, 2008 | Renault 181 Cars & Trucks
Car Audio & Video Logo
55 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
