Question about Whirlpool Dryers
Runs but does not heat what parts do i need - Whirlpool Dryers
  • Whirlpool Master
  • 43,501 Answers
Hi,<br /> If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.<br /> <br /> Check out this tip that will give more details&hellip;<br /> <br /> Gas dryer not working gas dryer not heating<br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"><a rel='nofollow' href="http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not" target="_blank">http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not</a></span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"> </span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"> </span><br /> If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat. <br /> Check out this tip to see the things that can fail to cause your electric dryer not to work.<br /> <br /> Dryer Troubleshooting Electric dryer wont heat<br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"><a rel='nofollow' href="http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won" target="_blank">http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won</a></span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"> </span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"> </span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">heatman101</span>
Posted on Aug 26, 2010
Why is my Duo Therm Heat Pump Running in the Aux Heat Mode?
MORE THAN LIKELY YOU HAVE A BAD FAN CONTROL MODULE , AND YES I WOULD GET A PRO BECAUSE YOU CAN SPEND LOTS GUESSING PLUS MIGHT NOT HAVE TO GET EXACT BOARD MAYBE OEM PART AVAILABLE WITH A LITTLE WIRE CHANGE AND SAVE YOU LOTS OF MONEY ON PARTS .
Aug 18, 2014 | Heating & Cooling
Jacuzzi hot tub will not reach temp pumps do run?
If your hot tub is running but NOT heating then you need to look at a couple of things.
First, on the topside, is the heat indicator light on?
If it is on and the tub is not heating then the temp sensor or the high limit sensor is not working and need to be replaced.
US Parts Center
Oct 22, 2013 | Jacuzzi Home
Hi, Our dryer runs but doesn't heat. We checked the power source, heating element with ohm meter but it was fine. What else should we check? Thanks.
Hi.
If the dryer runs there is no problem with power. If the appliance runs but does not heat the problem is one of the thermal devices. The dryer comprises one thermal fuse, several thermostats and the element. Thermal fuse and thermostats must be checked along with the element.
Start from the thermal fuse. The fuse can be tested reading impedance with a multimeter. If the fuse is open it will read Ohms infinity. In that case replace the fuse. Here the part: ASSY-BRACKET (THERMOSTAT) (Thermal Fuse with Bracket).
The fuse is part n.15 in Diagram one below. Click on the picture to enlarge:
If the fuse is OK, or if replacing the fuse did not help test the thermostats. You have the following parts:
THERMOSTAT - Part 11 in diagram
High Limit Thermostat -Part 13 in diagram
THERMISTOR - Part 27 in diagram
If the appliance is running the door switch should not be the problem. If you need test also the DOOR-SWITCH.
The thermostats can be tested reading impedance. If there is no heat, then one of the thermostats is open and will return Ohms infinity. Other way to test a thermostat is by jumping its contacts and running a controlled cycle to prevent overheating.
Regards.
Ginko
Aug 09, 2011 | Amana NED7200TW Electric Dryer
Roper electric dryer will not heat after replacing heating element and thermal fuse. what's wrong.
It doesn't necessarily mean the heating element is busted when the dryer stops heating and the thermal fuse is not part of the heating circuit, it is part of the motor circuit. The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components. Click on the link below for the detailed instructions. Indicate the exact model number of the dryer should you need further assistance.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Feb 12, 2011 | Dryers
Dryer runs but will not heat. i just replaced the heating element but it still is not heating up.
you probably didnt need a heating elemnt you need another much cheaper part call me and i can tell you how to find it and get it fixed
steve
210 313 7844
Nov 16, 2010 | Maytag MED5700TQ Electric Dryer
Dryer drum turns but no heat is produced.
If this is an electric dryer, unplug, remove the back, and remove the heating element. Check for continuity. There is also a fuse, and a thermo fuse that need to be checked for continuity. If any is bad, replace (get parts from local appliance parts shop). If all is well with the parts, check to see that your 220 is OK. Check the breaker box (switch breaker off and then back on) and see if that fixes the problem. Some electric dryers motors can run but not have the correct electrical leg to run the heating element.
Good luck
Dec 30, 2009 | Whirlpool Dryers
Kenmore 110.72822101 dryer does not heat. Need schematic
Parts to be tested:
Thermal fuse - test continuity with multimeter at Rx1 (Ohms) Heating Element - Same Thermostat-High limit - read Ohms, must have low impedance at room, and infinite at limit temp. Fan - Check if it is running Timer assembly - Difficult to test in full, look for faulty parts at a glance - read volts out.
always disconnect power when testing the appliance.
Here below the schematics and illustrated parts breakdown:
Please, do not forget to leave feedback.
Many thanks.
Ginko.
Sep 21, 2009 | Dryers
No heat is produced when dryer is running. How
most likely the heating element is toast, remove and replace, inexpensive, second could be heat thermostat but unlikely
Aug 08, 2009 | Dryers
MAYTAG PYE2300AYW ELECTRIC DRYER running but no heating
you need to take it apart if you'd like call 417-926-0106 i'll walk you through it Jim
Feb 27, 2009 | Maytag PYE2300AY Electric Dryer
Dryer won't heat but still runs.
it sounds like the heating element or the limit switches are out on it. they arent very expensive if you know how to install them
Feb 24, 2009 | Frigidaire Dryers
Dryers Logo
15 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
