Question about Protron PLTV3250 32 in. LCD Television
Wont power on and power supply works - Protron PLTV3250 32 in. LCD Television
  • 74 Answers
FAULTY CAPS IN POWER SUPPLY
Posted on Aug 25, 2010
Insignia quit working after storm
Check the fuses on the power supply board first. They usually blow when you get a power surge. You may be able to replace them and get the TV running for a few dollars. If the fuses are good then the power supply board will be the issue. The main board should not be damaged because the surge has to go through the power supply board first.
Aug 22, 2012 | Insignia NS-LCD47HD-09 47 in. LCD TV
I'm working on a sanyo 50" hdtv, It wont power on,
The power supply board have 6 capacitors dead,must have very high current going through the tv to have that many cap to died on the power supply board.U have good electronic skills trouble shoot the power supply board again,have something else is dead in there?Or try website like Ebay.com to buy a refurbish power supply board for the replacement.
Nov 24, 2010 | Sanyo DP50747 50 in. Plasma TV
Headlights wont work even with bulb replacement
dear sir
first open headlight box and remove the bulb and check by tester power supply (DC power supply ) Is coming there or not if its coming and bulb wont work then its problem in bulb if supply is not coming till headlight then check fuse box and other connector i think there any fuse is broken that's why headlight is wont working . change fuse after that headlight will work again
hope answer the question
thank you
please vote!
Oct 13, 2010 | Chrysler PT Cruiser Cars & Trucks
My enermax power pack sparked out of the fan in the back and now my computer wont turn on. Not sure if it's the power pack or the board is fried... Any help would be appreciated thanks =)
if it sparked then something inside the power supply malfunctioned and that is the reason it wont work. You will need to replace it. Unlikely that it fried your board in the process. You can test this by swapping the power supply with one that you know works.
May 20, 2010 | Enermax EG301P-VB (eg301vb) Power Supply
My gateway desktop PRB 510S, if I turn it off and unplug it or electricity goes off, the computer wont start back again. Wont do anything. No lights no fan, nothing. Then 5 to 10 minutes after I turn it on...
Try connecting a different power supply to it. If the same situation repeats, then it's an internal (motherboard) problem. If the problems go away, then the power supply needs to be replaced.
6 years... I'm surprised the PSU even lasted that long! The power supply is the cheapest part of the PC and usually one of the first parts to fail. Don't worry, a replacement power supply is not too expensive. Good luck!
Dec 02, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
My l100 wont turn on the power lead is connected but it just wont come on
Sounds like a power supply issue. Replace it and it should work. If not then the motherboard is the problem.
Nov 10, 2009 | Acer Aspire L100 PC Desktop
Wont boot
Check power Supply as it might have shortened the power, Open the case and remove the big white power lead from the motherboard (this is clearly visible as all the colored leads re and yellow from the power supply - normally a P4 feed into the socket).
Unplug this, find another power supply and using the big white cable connect this to the motherboard and try powering the machine up with that.
If works - great just replace all power cables from the power supply in your machine with the ones from the working one (not forgetting to remove the old power supply from the computer and replacing it with new one).
This should work
Sep 20, 2009 | HP Compaq Presario SR2011WM PC Desktop
Puter wont turn on
try to unplug again then plug in switch-o the power if it won't work then your power supply is busted you need to replace the power supply. if you want to make sure dismantle the power supply that connects to the motherboard, the connector has 20pins, then plug the power supply connect pin green and pin grey if the fan will rotate then the power supply is still okay.. if your power supply is ok check your outlet voltage if there is power including the circuit breaker that supplies power from this outlet.
Dec 16, 2007 | E-Machines eMachines Desktop PC
Protron PLTV3250 32 in. LCD Television Logo
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
