Question about Air Tools & Compressors
Looking for operating manual for paslode roofing coil nailer 3175RCU and strip nailer 5350/90S
  • 4,234 Answers
Go to the link below and click on the "downloads" tab. Select the owner's manual which is a PDF file.
http://www.paslode.com/air-nailers/roofers-choice/
I couldn't find a manual for the 5350, but did find a part breakdown and diagram here:
http://www.paslode.com/uploadedFiles/Knowledge_Center/5350%2090S.pdf
Hope this helps,
Dan
Posted on Aug 26, 2010
New nailer double firing and jaming
Some trigger valves (tva6) are sensitive (defective?) however there are some things you can try to change how the gun acts. I have noticed that the brand of oil has an effect on the orings. Some brands will swell the orings, I like Paslode nail gun oil. Do not wash the gun with gasoline or wd40. Use diesel. Change the nail depth setting one position. Lowering the air pressure will make a difference. I find that most operators use too much pressure. A stronger safety spring under the trigger will separate the trigger and firing pin quicker. Finally you could use single fire trigger. Good luck
Jan 16, 2014 | Stanley Bostitch Rn461 Gun Coil Roofing...
My makita an451 roof nailer keeps shooting 2 nails I've tried 2 different brands of nails
Nailers that use strips of nails (one nail directly behind the other) will sometimes drive two nails at once and is caused by damage to the driver. The nails are so close together that the driver will hit the first and part of the second nail head. Coil nailers, as your an451, use nails seperated by welded wire making it very difficult the the driver to hit the second nail. Usually when a coil nailer shoots two nails, it is acutally the trigger valve that acutates twice (two very rapid fires). Two very rapid fires is caused by faulty trigger valve. I have seen a roofing coil nailer fire one nail and a second nail drops out of the gun. Caused by weak / malfunction of nail feeder or wire used to weld nails together is too thick.
Sep 17, 2011 | Makita Roofing Coil Nailer AN451
IM350 when battery inserted flashes green then goes to red. Tried battery in other gun and works ok. Tried full charged battery (green in other gun) and led goes red in this one. Measured voltage at 6.74v....
Check the battery contacts in the gun...
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Feb 05, 2011 | RTO PasLode 900420 Impulse Framing Nailer
I put in battery green light came on as normal, and strip of nails, gun fired once and light shut off, and will not work at all, what could be the problem? thanks
heatman101
Oct 23, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Cell engages, battery operating properly, trigger will not fire as though it is locked
heatman101
Oct 22, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode Impulse Framing Nailer won't operate
heatman101
May 10, 2010 | Omega Paslode 901000 Impulse Cordless...
I can't put mt paslode finish nailer back together again
go to Paslode.com and you can download a manual that shows the spring. It sits in a recess under the follower that pushes the nails
Jul 20, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Will bosch nail guns operate with Paslode brand nails?
The F28WW takes 28Deg nails that are collated with wire, so your nails won't work in that gun. The N80SB is also a 28Deg nailer so your 30 Deg nails won't work in that gun either. Sorry about the bad news but it looks like your going to have to spring for new nails
Jun 11, 2009 | Stanley Bostitch N80CB Coil Framing Nailer
Paslode 5300/75S Framing nailer
Soory It is a roofing nailer not a Paslode framing nailer. ended up replacing the main valve. all is well now. thanks
Sep 13, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
228 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
