Question about Mindscape PrintMaster Premier 7.0
I have Printmaster 7.0 but it is not compatible with my new Windows 7. What can i do to upgrade? How do I open my old Printmaster files? The previous files are on Windows XP.
  • rujuloveco Aug 25, 2010
    I will have to have somebody translate your answer for me, then I would like to get bacxk with you. since I did pay for a solution, and it has not solved my problem at this point. I will try to get back to you tomorrow.
  • 5,126 Answers
The upgrade path is to Printmaster Platinum 18.1 or Printmaster Platinum 2.0. I'm not sure which is better for you but both are $39.99 from http://www.printmaster.com/ .
The installers for Windows have changed over the years. Your alternatives would be to use a dual boot or virtual computer with XP installed. Win7 Pro and Ultimate allow you to run XP mode free after downloading two programs from Microsoft. All the other options require a licensed (paid) version of XP.
The compatibility mode is available but I'm not sure it will work in this case. You would need to right click on the installer and choose Properties. Then go to the Compatibility tab and chose an older version of Windows (Win98 may be a better choice than XP). Then right click on the installer again and chose Run as Administrator. Then you will need to do the same thing with the actual program.
I hope this helps.
Posted on Aug 25, 2010
  • 2 more comments
  • Cindy Wells Aug 25, 2010
    A couple of notes: 1) the biggest issue with XP mode and the other virtual computer options is that you can't just transfer files back and forth. You need to save to external media. (BTW once you have the dual boot or virtual computer program installed, you install the software as if it were the only computer present.)
    2) Printmaster 18 will import files from Printmaster 8 and more recent. Printmaster 2.0 will not import older projects at all.
    3) Opening your older projects will depend on how you saved them. I know more recent versions let you save things as a PDF. In that case, you can look at the files in Adobe Reader and edit them with Acrobat, one of the PDF generic programs, or most office suites (some need an add-on) like Microsoft Office or OpenOffice. For the lower price suites, this editing is done in the Drawing program of the suite not in the word processor.
    4) There used to be file conversion programs but I'm not sure of the default file type for Printmaster 7.
    If you give me the characters that follow the . in the file name I'll check if there is a converter for those. Most of the conversion programs I tried were for converting from one word processor to another (or spreadsheet programs) which is now included in the Office Suites.
    Sorry it took so long for me to find the import information.
    I hope this helps.
  • Cindy Wells Aug 26, 2010
    I've been using the virtual XP mode for so many older programs it's become part of my life. Let me attempt to translate my own comments.
    1) Printmaster 18 is the current version and is Win7 compatible. Unfortunately, it will not import projects from Printmaster 7 (only 8 and more recent).
    2) A dual boot computer uses two hard drives (or partitions on one drive). Each hard drive has its own operating system (for Windows they each must be licensed versions). When you turn on the computer or restart it, you will be asked which OS you want to start. After that, it's like having two separate computers with only one on at a time. Hardware and software get installed as they would on each appropriate computer.
    3) Virtual computers let you run a second computer OS inside of the real computer. So you can switch back and forth without rebooting. However hardware must be connected (installed) to only one "computer" at a time. This includes the hard drive. Thus we've been saving files to a CD or flash drive to transfer it to the real computer (to print or anything since the printer is installed on the Win7 computer). There are several virtual computer programs - VMWare, Virtual PC and Parallels among others. XP Mode is exclusive to Microsoft's Virtual PC program. Virtual PC is free to anyone with a valid copy of Windows http://www.microsoft.com/downloads/detai... . XP Mode is a package that installs the XP OS into Virtual PC http://www.microsoft.com/windows/virtual... ; it is free for users of Win7 Pro and Ultimate. For the other virtual PC programs, you need to buy/have a licensed copy of Windows XP that has not been locked to a different computer (the Microsoft validation locks it to a CPU and motherboard).
    The biggest problem with the virtual computer is that the real computer gives up part of its memory to the virtual one. The dual boot computers use all the memory it can in each OS. However, we've found that all programs that ran under XP work well in XP mode. (Programs for Win2000 and earlier didn't work as well.)
    4) Compatibility mode: Windows has a workaround that lets you run older programs in newer operating systems for many iterations. I found references that Printmaster 7.0 Premier would run under Vista when run as a Win98 was selected. The reasons I don't know if this will work in Win7 is a) I don't know your OS version and 64-bit Windows needs a program to have a security certificate that didn't exist when this program was written. b) Microsoft has changed a lot of the code from earlier versions of Windows . The compatibility mode tends to work best with programs written for the previous version of Windows not several generations apart. (I found a number of my XP programs didn't work in the compatibility mode but did in the virtual computer.) Printmaster 7.0 is listed as supported for Win98 to Win2K.
    5) Executable files end with .exe and Microsoft Word files end with .doc. What is the ending characters for a Printmaster 7.0 project file? If you provide that, I can see if there are any converters or readers still available. Newer versions of the software let you save files as a .pdf which translates to "portable document format" and was the Adobe standard file type. It is a very common format so if you had your files as PDFs, there are a number of programs that could open the file.
    Do these expanded comments and details help?
    In my last message, I said that dual boot computers used two hard drives or partitions. Partitions are divisions of one hard drive. Windows can reformat or partition a hard drive but if you do this to the C: drive you usually need to reinstall the OS and all software and files afterwards. Third party software (Symantec Partition Magic, Paragon Partition Manager) can do these without losing the data on the primary drive.
    Most computers come with at least two partitions on the hard drive these days. The second partition is hidden and holds a copy of the OS as it was originally installed on the computer at the factory.
    You have 7 days to ask for other expert opinions or reject my answer. My main concern is if the extensions changed when Broderbund took over the program and issued updates over the years.
    One of the Printmaster file types is PIX. I know two programs that claim to open that file type (assuming the standards did not change) gimp (freehttp://www.gimp.org ) and Image Converter Plus (not free http://www.imageconverterplus.com )
    I've found other file types related to certain Printmaster versions. Unfortunately, for one code, SHP, the same three letter code is used by geographic information files. All of the file conversion packages I found were for those gps and gis programs (Global Positioning Satellite and geographical information services). Another code, PM, didn't resolve in any conversion programs I know. BIZ and SIG files only seem to be openable in Printmaster and related programs from Broderbund. Since the notes I have say that the latest program only import files from PrintMaster 8, I suspect the files have changed.
    (if you had exported the files to PDF, there are lots of choices.)
How can I run PrintMaster 16 Platnum in Windows 7
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
Dec 10, 2011 | Broderbund PrintMaster Platinum 16
Our business has been using Printmaster 15 for a few years now. We recently bought a new computer with windows 7. Printmaster 15 is obviously not compatible with Windows 7. I bought printmaster 2011...
You can try version 15 in compatibility mode:
Troubleshoot Compatibility
This can help with some (but not all) programs/drivers:
1) Uninstall the program if it's already installed. Then when you install/reinstall it instead of double clicking on the install file right click it and select "Troubleshoot Compatibility"
2) Then click "Try Recommended Settings" and in the next window click "Start the Program" to install it.
3) After it installs see if it works correctly. Please note - some programs may not be able to run in Windows 7.
More details about how to make older programs run in this version of Windows:
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
Jul 19, 2017 | Broderbund PrintMaster Platinum 16
I have used PrintMaster 10 for a number of years on my old computer-XP. I recently purchased a new computer and wish to put the program on my laptop( Windows 7). I tried choosing the compatibilty method...
The only solution with this older software that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate (or are willing to upgrade to one of these versions), you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them. You can't have a printer installed on both the main computer and the virtual one at the same time. You will be asked to uninstall the printer if you try.
Your other option is to upgrade to PrintMaster Platinum 18.1, see http://www.broderbund.com/ for details, which is compatible with Windows 7. This will import your Printmaster 10 projects.
I hope this helps.
Apr 11, 2011 | Broderbund Print Master Silver 16.0 for PC
Have old printmaster platinum 8.0 tried to download on new comp windows 7 it says something about 16 bits
Printmaster platinum 8.0 is rather an old 16bits software and it is not compatible to your new version Win 7 OS.
You can check software compatibility @ Windows 7 Compatibility Center
Your option is to upgrade to version 18 which is Win 7 compatible.
Hope it helps.
Feb 20, 2011 | Computers & Internet
Have favorite publishing suite....easy and old....but now not compatible with my windows 7 system....what can i do to fix and have my new computer upload my cd: PrintMaster Gold Publishing suite Version...
  1. Open the Program Compatibility troubleshooter by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.jpg, and then clicking Control Panel. In the search box, type troubleshooter, and then click Troubleshooting. Under Programs, click Run programs made for previous versions of Windows.
  2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
Jan 10, 2011 | Computers & Internet
I am using an old (but good) Printmaster Platinum 11 and would like to update. A few years ago I got a detective Gold 18 which I cannot use. I have Windows XP Home and am being told that I must update my...
Not compatible or not working well with windows 7?
(make your program/application run with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Nov 18, 2010 | Broderbund PrintMaster Platinum
I have Printmaster Gold version 3. I have had it installed on windows xp I now have a new computer with windows 7 and would like to install printmaster gold. What do I have to do?
Is your PMG 3.0 on the software compatibility listing for W/7? Did you check it? Pleae check it here: http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
If your software is Windows 7 compatible, the list will tell you ... it should run with no hitches. If PMG 3.0 is not listed, you can appeal to the Printmaster Company for a upgrade path.
There is a compatibility test you can run from within the above link that will tell you what on your 'old' computer will migrate to your new computer ...
Even thogh this response was probably not within your expectation, it is a viable response and I hope it assist you in solving your delima.
Thank you for your interest in FixYa.com
Jul 01, 2010 | Computers & Internet
I could not install PrintMaster Publishing Suite 7.0 on our new computer running Windows 7. Is this software compatible with Windows 7? Is the a version to upgrade to that is compatible that we can work...
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Jun 20, 2010 | The Learning Company PrintMaster...
Mindscape PrintMaster Premier 7.0 Logo
1,534 people viewed this question
Top Mindscape Computers & Internet Experts
Josh Whitehead
Josh Whitehead
micky dee
Are you a Mindscape Computer and Internet Expert? Answer questions, earn points and help others
