Question about GE WBVH6240F Front Load Washer
Scratching noise I think there is something stuck under the drum, I hear a loud scratching noise when i use my washer. I cant figure out how to get to it.
  • 1,554 Answers
The only way you can do it is to fish under the rubber flap in front.
other wise you have to remove the top access panel, bottom access panel , remove the panel control
then the front door and panel
now you have access.
it really isn't that hard. just sounds difficult.
Posted on Jun 08, 2008
Very loud during cycle
most top loading machines have clips that attachthe top to the front, pry up on top with small pry bar or screwdriver. if noise is a banging noise, you may have a spring that broke or came off underneath machine. i would check under washer before removing top.
Nov 10, 2013 | Maytag Washing Machines
I have a Kenmore HT4 front washer and it washer is making a loud noise when it is in the spinning cycle. It sounds like the inside cycle is hitting up against something. It seem to wash okay and we...
There is only two things that I can think of 1: The bearings are going or 2: something has got under the door seal and is in between the metal drum and the plastic cover (around the drum). Could be something like a coin or even a bra wire.
Jul 28, 2011 | Kenmore Elite 45986 Front Load Washer
Hearing a scratching sound while drum is spinning...sounds like something is scraping it?
its one of two things 1. something is stuck under the lip of the drum,like a dime or paperclip. Fell all around the lip of the drum and you should feel it. 2. your Bearing Glides are worn down, they run about $5 each and yours has four of them, you will need to pull it apart to change them, its not to hard to do yourself
Nov 17, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
When the washer is filling a loud noise is coming from the motor, it sounds like a bearing is going out. It seems to do it mainly when the washer is draining, but it starting to make the noise through the...
Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings. Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.) Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub. Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water. Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers. Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Thanks for contacting
Nov 11, 2009 | Fisher and Paykel GWL11 Top Load Washer
Loud rattling noise, but dries ok
The drum of a dryer is supported b the front and back of the unit, spins on a felt gasket. Noise is coming from rollers or their is something stuck between drum and the felts. The pulley is a piece of springy metal with a plastic wheel on it, could also be worn. If you take off front of dryer, drum will come loose, check to see if something is stuck. Common for loose change to get jambed in felts. Also spin rollers and pulley to see if need to be replaced. I still think something is caught in felt.
Aug 17, 2009 | Kenmore 63942 Dryer
Something stuck in drum, spinning cycle loud hammering/clacking sound
hi there,
sounds like you may have something caught between the tumbler and the cabinet. since the drum has holes in it, can you have a look if you can see anything that's come of clothing, like a bra wire. it's usually something bigger.
Sep 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer makes loud knocking noise
I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. You can also move the inner drum up and down to see if there is something wrong with it..
Sep 28, 2008 | Roper RAS6233KQ Top Load Washer
Kenmore front load washer
My Kenmore front-load washer starts to make the huge noise. The noise happens during the wash cycle, but is mild. During the spin cycle, the noise becomes really loud. It looks like the drum is getting loose and hitting other part of the machine.
I checked the drum, and I can sway the drum easily with my hand. So it looks some supporting structure is broken. I don't know if it is easy to open the washer to check what has been broken.
May 20, 2008 | Kenmore 44072 Front Load Washer
Broken washing machine
the machine water ceal and bearings must be changed before it spoil the drum.there is small metal under washer drum to give u sine noise if the drum unstable.and if you keep using the the machine,drum get demaged.mostly all front loading machines are like that.the test is,open back cover check if there is rust on the centre shaft,that means leaking throw the ceal and the door and try to list up the inner drum if plays means problem with bearings as above.
Jan 08, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
GE WBVH6240F Front Load Washer Logo
87 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
