The washer is leaking from the bottom when emptying. Not all the water just leaves a puddle
    President:
  • 2,702 Answers
You could have a split pipe under the washer or the emptying pump water seal may be leaking look at the pump first as the seal is under a lot of presher when the pump is pumping out
Posted on Aug 25, 2010
My kenmore elite topload washer is leaking underneath washing machine leaving a puddle whats causing this?
depends. first and foremost, I would fill the unit up about halfway with water, with tub being empty of any clothing. Tilt the machine back where you can look underneath it real good. see if you see any leaks with it half full of water. If you don't see any leaks, put the unit back on all fours, and put it into drain/spin. After tub empties of water, tilt unit back again and check for leaks near the drain pump and hose. If you need any further assistance, look for me on 6ya
Nov 27, 2015 | Kenmore Washing Machines
Water build up
Good Afternoon Friend,
I understand that you are getting puddles of water in the back of one of the bottom shelf and in one of the vegetable drawers in your Frigidaire refrigerator. I suggest putting the crisper drawer control on the Hi humidity setting. This should allow more moisture to escape out of the drawer and not cause as much puddling. Also, check your water filter and make sure it is not leaking, as well as any moisture from the ice maker. If further troubleshooting is needed, I ask that you please leave the model number of your washer. Typically, you can find this number inside your refrigerator on the liner walls. Hope this is helpful.
-Best Regards-
WP
May 29, 2014 | Frigidaire Refrigerators
Why does my double doors/GE/culligan refrigerator leak water at night
there will be a drain at the back of the fridge down the bottom there is probably something caught in it blocking it causing the water from the evaporator in the fridge to run out instead of down the drain
May 22, 2014 | GE Refrigerators
Dish washer will not empty all the way out when cycle is complete
Try checking the outlet pipework, it may not be all downhill, problem with dishwashers is they tend to have standing water in the drain, you need to make sure the pipe has a good tilt, and flush your pipes regular with a cleaning agent for dishwashers.
Jun 09, 2012 | Dishwashers
I ran a load & after switching the wash i noticed a puddle of water sitting at the bottom of the washer
water puddles usually indicate a leaking water pump-check the gaskets to make sure they are sealed before replacing the pump
Sep 17, 2010 | Kenmore HE2 Plus Front Load Washer
Leaking water on spincycle
I have the same problem with my washer. The problem just began a few weeks ago. It is splashing out the front left corner of the tub and running down the inside of washer and then leaking out the bottom of the frame. It is just enough water to be annoying. The washer is about 6 years old.
Model: FAV6800AWW
Serial: 11277017EG
Any ideas??? Help!
Jul 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My whirlpool duet front loader is leaking water? Not sure from where cause I havn't caught it in the act. But when I go in to get the clothes I have a puddle right under the front door. Cant tell if is is...
empty the washer. then remove the bottom panel of the machine.put some water in it and see if the water is leaking when it is filling or full.I have seen a small hole in the tub just behind the bottom counter balance where the mounting bolt goes you may need to use a small mirror to look under there.f94b104.jpg
Jun 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Why would a dryer be leaking water at the bottom?
look for a restricted vent . and a cold floor or room . this would cause condensation and would leak from inside / causing leakage on floor in or around the dryer .. hope this helps . pls leave feed back .. mm
Dec 12, 2009 | LG DLE3777 Electric Dryer
Leaking at front base of washer. Not a stream but a growing puddle as it goes through its cycles. Not sure where to look to find the cause. All water and drain connections are good.
Remove the cabinet to access the water pump. It is attached to the motor front/center.
It will be leaking.
No repair, only replacement will stop the leak.
Remove 2 screws on the right and left sides of the control console. The console is hinged. Fold it to the rear of the machine. Unplug the lid switch connector.
Remove 2 clips holding the back panel to the cabinet base.
Remove the cabinet. Motor and pump are at the bottom center.
May 24, 2009 | Washing Machines
Puddle under 1 yr old washing machine hours after it is finished
Sounds like either the gasket on the inlet is leaking or not tight or the solenoid housing is cracked causing the leak. When its in use the pressure from the line is realased when the solenoid is opened letting water in. When not in use the solenoid stays closed allowing pressure from the line to build causing the gasket to leak. Check your gaskets, and solenoid housing for leaks and then check to make sure your water pressure is not set too high.
Joe
May 19, 2009 | Kenmore 22422 Top Load Washer
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
