Question about Mcintosh MC352 Amplifier
Hi ! I have a Mc Intosh MC352 and my problem is that I have it hooked up with my B&W 802s. And i notice one side is louder than the other. I checked my Wires an everything seem s fine. What's the problem.. Is it the amp
  • Scott Frye
    Scott Frye Aug 26, 2010
    Can you listen to the audio on headphones? and does it appear level on both sides when you do?
    Are the volume knob pointers at the same point on the front panel when completely off?
    Thanks
  • Mcintosh Master
  • 5,113 Answers
Swap the speakers around. If the sound stays on the same channel and doesn't move with the swap, then the amp has a fault on that channel. If it does move to the other side the speaker is the problem.
If it is an amp fault you can track it down using a insulated tool and the buzz test. You simple touch points on the good channel with the tool and in places it will buzz. You compare that by touching the same places you got a buzz (on the good channel) on the bad channel instead and if it doesn't buzz or it's weaker then you have located the problem.
You can also check the voltages with a meter in the same way. As the voltages should be the same on the two channels.
Posted on Apr 18, 2015
2 Suggested Answers
  • 15 Answers
SOURCE: Panel lamps for Mcintosh MC352
You can get an upgrade to LED light instead from
http://www.audioclassics.com/
This would be a great option.
Posted on Jul 27, 2010
Hi, I have a BEHRINGER V-Tone GMX212, I left it
Did you left the amp on overnight with a guitar hooked up to it?
Oct 29, 2013 | Behringer V Tone GMX212 2X60 Watt Stereo...
Self propelled lawn mower is louder
Change the muffler, the baffles wear out after awhile making the mower much louder.
Sep 09, 2012 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Where may I find a owners manual for the mc intosh mx 4000
Go to google and google 'Mcintosh mx 4000 manual'
May 09, 2012 | Computers & Internet
I took the apes off my 2009 rk and installed stock-style bars with internal wires And after completion the bike wont start and the abs light is flashing and the front brakelight switch has power on both...
I don't know a lot about the later model bikes since I specialize in repairing the older bikes but I guess you damaged your front brake light switch in the right side handlebar switch housing. The switch sticks out of the side of the housing that faces the front MC. That's my best guess.
Good Luck
Steve
Jul 15, 2011 | 2008 Harley Davidson FLHX Street Glide
Left channel doesnt produce sound as vu meter don't represent any output as well. Think perhaps the mono stereo switch could be the issue, seems like I was able to get channel running by flipping switch...
Hi
from your description it looks like the switch causing this problem
replace the switch might solve this problem unless its cause some short on the main circuit
if you want to fix he Amp let me know
ecrdn@yahoo.com
Jack
Oct 19, 2010 | Mcintosh MC352 Amplifier
Jul 03, 2010 | Mcintosh MC352 Amplifier
Amp turns off
what ohm is it running at? if you have all three hook up it parallel then its to low of ohms and it would be louder if you unhook your 10" sub as it moves differently form the 12"s and it cancels out some bass. but if you want it then you have to change the wiring around a bit. take the positive wire off a 12 and put it on the positive side of the 10 and then take the ground for the 10 and hook it up to the positive side of the 12. so you should have one wire from the amp going to the negative side of the 12 and one going to the positive side of the 10 and a jumper wire from the 10 to the 12. and if it still shuts off then you have bigger problems.
Sep 25, 2009 | Ultra Linear UL-2200D Car Audio Amplifier
One speaker is musch louder X-530
On the TV sound options see if there is a balance option. Adjust according to taste if there is that option. Hope this helps.
Dec 24, 2008 | Logitech X-530 Computer Speakers
Amp output
If you are hooking up the speakers in a bridged configuration to the amp then you are forcing your amp to drive a 1 ohm load on each channel. If your amp is not capable of driving a 1 ohm load then you will fry your amp. It may take a month or two, but it will fry it. How does it feel temperature wise? If you cannot place your hand firmly on any part of the amp and hold it there all day long, then it is running too hot. Good luck. Hope this helps.
Apr 04, 2007 | Alpine MRD-M1000 Car Audio Amplifier
Were the negative and positive post....
If it isnt this way try this, Take the + Lead from the amp to the + on the Sub, Cross from the - on the first side to the + on the other set of posts, then take the - from the second set of posts to the - one your amp. I assuem this is a Dual 4 Ohm and will bring that down to a 2ohm which induces more power from your amp and should be louder it could be 2X2 1
Jan 26, 2007 | Kicker S10L52 Car Speaker
Mcintosh MC352 Amplifier Logo
212 people viewed this question
Top Mcintosh Audio Players & Recorders Experts
sean tan
Level 1 Expert
 Grubhead
Grubhead
Jay Plesset
Are you a Mcintosh Audio Player and Recorder Expert? Answer questions, earn points and help others
