Question about Dishwashers
Whirlpool DWF417W, Type 12155 A couple of weeks ago the machine failed to empty, leaving dirty water in the machine at the end of the cycle. Start a new program it emptied & all was then well. A couple of days ago we started a wash cycle as normal, shut the door, the pump normally runs for about 10 seconds then the cycle starts. However the pump just runs continuously?? After looking here there seemed to be a few links to the subject of water being in the base & the anti flood switch being activated. I removed the machine & proceeded to strip it all down & give it a service. There was indeed about 15mm of water in the base. This was all cleaned out & the machine all cleaned out. I removed all of the hoses from the suction unit & cleaned all of this out, removed the pump etc. All looks good, no debris. The machine does however smell inside. One thing I did notice was some soggy, dirty looking salt in one section of the salt container, this was impossible to remove? I rebuilt the machine & re-fitted it all clean & dry. I then tried to start a normal program. Still the same, the pump runs continuously. I then decided to run the self test that i found on here. Held down the program select button for 30s, all lights lit up & then pressed it again, & shut the door. Wash program started all seemed good. until the end. I opened the door to lots of hot water lying in the bottom. The fault code lights were as follows:- (Lights from left to Right) 2 & 3 illuminated 5 flashing???? My manual says "Dishwasher does not drain". I can see that!! Where do I go from here, any ideas????? Thanks
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. As you have already checked the drain & it is not clogged or blocked and the line is not kinked, then check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher that has gone bad and should be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 26, 2010
Whirlpool type 111-05 Top Loading
The electronic timer is worn and requires replacement, this would be a bulky metallic box located just behind the large setting knob.
Dec 22, 2013 | Washing Machines
Whirlpool Sm8525079 Rev fills up with water, but won't agitate.
Your lid switch has a fault, Sometimes the switch can bend which means that it won't always operate.
Mar 08, 2012 | Washing Machines
I have a Whirlpool Ultimate Care II, top loading washer. Upon intial start up the machine agitates. During the spin cycle, the cold water remains ON, throughout the cycle. This is leaving the clothes wet...
The timer is at fault.
During the spin cycle the timer should send intermittent power to the water valve. This activates cold to help rinse soap residue from the laundry.
If cold is continuous it means the timer is not breaking correctly.
Feb 14, 2010 | Whirlpool Washing Machines
Maytag dishwasher not draining fully
Try cleaning out the air gap.  The air gap is not part of the machine, and is located on your sink. If this becomes clogged, it may cause the machine to not drain properly.  Also, I know you said you checked the drain hose and cleaned as far as the filter and chopper blade, but have you checked the lower filter?  There is a filter located underneath the machine that should periodically be cleaned.  To check this, you need to access the machine from underneath by removing the bottom vanity cover. Hope that one of these helps!
Aug 01, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Two year old Whirlpool washer started failing to advance from the rinse cycle to the spin cycle a couple of weeks ago. However, the water would drain through and run until you manually advanced the system...
Hi, I just want clarification. Is the washer filling to a point when it starts draining the water before it starts to agitate? If this is the case, check the end of your drain hose and make sure that it is as high as the top of the washer. Make sure that where it goes into the drain pipe that it is a loose fitting so that air will **** back into the drain hose. Please let me know if I have given you the right information or if I have missed what you are describing so I can assist you further.
Thank
Vic
Jul 13, 2009 | Washing Machines
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Dishwashers Logo
89 people viewed this question
Top Dishwashers Experts
Owen Barnes
