Question about Mitsubishi WS-55511 55" Rear Projection Television
TV will not turn off with remote or without remote, also, volume will not adjust, everything else works...........whats going on??
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
U have a bad control panel , take the front speakers grill off and disconnect the cable that goes to the s/w and try to use ur remote control againg
Posted on Aug 26, 2010
What is causing the volume to to change on its own?
This is a known issue for this model, and you need to ask for a service intervention via your dealer or Philips (http://www.support.philips.com/support/catalog_selector.jsp) to repair it.
Nov 22, 2015 | Philips Televison & Video
My tv was playing fine when I turned it off. Later, I drop the remote prior to attempting to turn the tv on.Tv will not turn on with or without remote.
OK, YES you CAN turn on the TV without the remote, in fact you can do nearly everything that can be done on your remote, on the TV itself, NOW look, CAREFULLY around the edged or sides of your set, you will find there are "Buttons" usually there are 6 - 7 Buttons, if you look carefully at them you will see they are marked, usually with a Volume Up & Down, word, or symbol, A Channel Up & Down, buttons a Menu, an Enter, and an ON/OFF button, & sometimes others. Now To turn on, Press and hold the Power button, the TV will Turn ON, you can change Channels, with the Channels, and Volume, with the Volume ones. The Menu button, will allow selection to all the other sub menus and settings. IF you need to get a remote, Please, get an original, it may be more hassle, it may take longer to get, it maybe costs more... BUT IT WILL WORK. Universal remotes, well, read through a few posts dealing with them, and you will see what I mean. IF you MUST get one, absolutely ensure that it performs every function the original one did, or you can have many headaches.
Apr 15, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My tv has no volume,i checked every cable connection and it all fine.I know my speakers are fine in the tv everything was fine until a button was pressed on one of the remotes the tv or the direct tv...
Remove all batteries from your remotes. Unplug the unit for several minutes. Plug unit in and use the controls on the set to turn it on and adjust the volume. This will eliminate the remotes. They could have a button stuck. If this does not work you may have a legitimate problem and need a tech.
hardrocko
Feb 01, 2010 | Hitachi 43UWX10B 43" Rear Projection...
I have a new TV Model 47PFL3603D/F7 and am hooked up to comcast digital box and cannot figure out how to get my comcast remote to regulate the volume. I have the set on channel 3 and everything works...
Usually on a universal remote (after programmed) the volume is controlled by pressing the cable button then adjusting the volume. When you turn your tv on by pressing tv power---then flipping through the channels by pressing cable--channel up or down. The remote (in my experience usually only controls the volume while in the cable mode)
Jan 10, 2009 | Televison & Video
Volume is very low
Use the satellite receiver remote control to adjust the volume first. The receiver itself offers volume control and you probably have that turned down. Then you are trying to raise it with the volume control on the TV. This is raising the TV volume, but there isn't much sound there in the first place. Use the receiver remote, and you will probably see a volume bar. At some point it might say something like "best stereo" or a star might appear. If that happens leave the volume set there, otherwise just raise it all the way. Then control the volume with the TV remote, or program the DirecTV remote for your brand of TV, and the volume button should control the TV then.
Dec 19, 2008 | Toshiba 32AF43 32" TV
Tv ws-65511 volume stuck
Did you ever get this problem fixed? Ours just started doing the same thing. It worked fine the night before, but today it's doing what yours is doing. The remote stopped working for the TV. The remote still works for the cable box, but volume and anything related to TV function not. The screen flashes when we try to adjust volume or anything else, but resets to previous volume. TV not responding to any commands either on the front panel or remote.
Any ideas? Thanks, Patti
Aug 10, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Using Without WIRED REMOTE
All I could suggest is run the decoder off the line-out of your soundcard, then regardless of what the volume or power setting is to your speakers, the signal will still come through?
Tony
Mar 03, 2008 | Logitech Z-5300 Computer Speakers
Sharp Aquos LC-42D62U VOlume Control
OK guys I'll save you. The tv is in hotel mode. To get it out from there you have to go in service menu but DO NOT CHANGE ANY OTHER THING IN THERE, only what i tell you. With the tv on and the K letter on the screen press in the same time vol- and ch- on the tv set. Now you'll be in service mode. On the remote press down arrow (not -channel) and you'll see up industry init. go there with ch- and press vol+ and enter. let the tv like that for few seconds and the tv will go green and hopefully industry init succsesfull will be on the screen. After that unplug the tv and replug it. Done!
Oct 19, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sony 36' TV Volume Goes up on own/Stuck on Video 2
There's a setting in the menu. I think it's called "smart audio". It's supposed to adjust the volume automatically for commercials. But I don't think it works that well. Give that a try.
Jan 09, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Mitsubishi WS-55511 55" Rear Projection Television Logo
29 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
