Question about Sport & Outdoor - Others
I have a Marcy CL202 Cycle that is just over a month old and while using it suddenly there was no further resistance. I took the side panel off and it is not the belt. There is some problem with the magnetic wheel inside and the connector part from the belt no longer has any grip. Who do I need to contact to get this fixed?!
  • jdinteractiv Aug 25, 2010
    Thanks. I bought it via Amazon, but their 30 day return limit is up. I've emailed them, reply pending. Couldn't find a direct support link for Marcy, so I guess I'm at Amazon's mercy now.
  • 10,865 Answers
Hi. Definitely let the company repair this as it is under warranty and if you open it up you will void the warranty. Return it to the company that sold it to you. Also read this informative link http://www.excercise-bike.com/marcy-cl202-cycle
J.
Posted on Aug 25, 2010
  • Sport & Outd... Master
  • 3,083 Answers
Where did you order it from? They would be the easiest way to get a replacement. Your manual that came with it will have the support number on it. Unfortunately, there is no support site on the web, so one is left contacting the store they purchased it from, or the product support number in the manual Hope this helps, and thanks for using FixYa.
Posted on Aug 26, 2010
Marcy Upright Fan Cycle - Fan Hitting Cage As It Spins
You did great with the assembly, however, you're off on the alignment. Try to adjust to pull the axle in the opposite direction to clear the cage.
Nov 11, 2013 | MARCY MCPL 105 Upright Fan Bike
I have a 42'' Hannspree LCD tv. It about 2 months old and just recently it started to switch inputs automatically. I just will all of a sudden switch like the channel button is being pressed. I...
I sugest that you should contact service provider or return the unit where you bought your tv. so your warranty will not be void. Good day and best regards.
Sep 02, 2011 | Hannspree HANNslounge 32 in. LCD HDTV 32
I need the instruction manual for my Marcy impex home gym. Model number is xj-07461092505.
Manuals for most of the Impex equipment is available here: http://www.impex-fitness.com/download.asp .
The direct link for the MWM 980 manual is: http://www.impex-fitness.com/images/mwm980%20manual.pdf . This manual has the parts list, assembly instructions and the weight resistance chart. None of the products have a model number starting with xj- .
I hope this helps.
Mar 15, 2011 | Impex Marcy MWM 980 Home Gym
Tub fills, agitator does not start, buzzing sound only - which may last for several minutes before starting to operate. Clothes may wash but machine stops before cycle finishes. Last time machine was used...
The motor for the machine is probably burned out with the power off you can check the motor winding with a meter ohm the wire out to the motor if no resistance bad motor.
Mar 07, 2010 | Washing Machines
My daughter dropped her sister's Nikon Coolpix S560 in the sanddunes today with the lens open. It still took pictures after that but the lens wouldn't close. Now it opens and closes and makes a grating...
It seems that some sand particles are lodged between the lens casing and the camera's body. and when it finds that there is resistence in moving the lens, it shuts down. Use somethig that sucks, like the vacuum cleaner to **** the sand particles out. Do not blow, else the sand will go further in.
Aug 06, 2009 | Cameras
Defrost cycle not defrosting
Hi
Please check the defrost timer at the back of your refrigerator and also check the defrost thermostat. Defrost thermostat wiring(part #240) could be loose. You'll need to remove the back panel, held in place by 5 screws. Locate the defrost thermostat and disconnect it from the wire connection to another part. Due to the connection requirement, you may need to cut the wires from the original part and splice it with the connector with wires to the new part. After securing the spliced wires and covering in electrical tape, replace the panel and all the screws.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Jul 14, 2009 | GE Refrigerators
Sport & Outdoor - Others Logo
80 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
