We are going through ink like crazy on our Epson 600 Workforce fax. It's supposed to yield up to 500 copies, and we just replaced cartridge yesterday and it already says ink low. Can I change a setting to use less ink?
  • jeanine_rcn Aug 26, 2010
    We don't have a manual. Where do I set "draft"? I can't find it in the set-up.
  • 526 Answers
Just so you know, the # of copies are based at 5% coverage, so make sure that is whats happening. When you are telling the printer to print, in the printer drivers, you can select rough draft type printing where it will use less ink.
Also, make sure your not using generic ink.
Posted on Aug 26, 2010
  • adi Aug 26, 2010
    how are you using this machine? fax, copier or printer?
    if more than one, which has more usage.
Problem with printing, no ink on paper
The print heads are clogged or you are out of ink. Try the steps in the link (Epson support page).
Epson WorkForce WF 2530 All in One Printer
Apr 06, 2016 | Epson WorkForce WF-2530 All-in-One...
I just replaced all four ink colors in my Epson 600 workforce and its not printing right. its all yellow and pink.
It appears that some ink nozzles are blocked or not seated properly.
Go to the Epson support site below and enter Epson WorkForce 600 as your model. Then go to Troubleshooting Guide in the list on the right of the web page
Welcome to Epson Support
Oct 03, 2014 | Epson WorkForce 600 All-In-One InkJet...
Why doesn't my black ink work in my Epson WorkForce 600 series after replacing the black ink cartridge?
The Epson printer may only use genuine ink cartridges which contain a chip so that you cannot fill the cartridge with ink or use non genuine ink cartridges.
OR
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 01, 2013 | Office Equipment & Supplies
My Epson Workforce 600 printer will not print black ink. I have changed ink cartridges several times and have cleaned the heads/nozzles several times. What can I do to fix this?
It appears that your printer is malfunctioning and will require service. Contact Epson and verify if your printer is still under warranty so they can replace it. Otherwise, have your printer check by the nearest service center in your area.
Oct 23, 2011 | Epson WorkForce 600 All-In-One InkJet...
Ink leaking from right hand side where all the cartridges are. 1 year old machine never a problem until now model 610 fax/printer/copy
When the print-heads are in their "resting" position, they are over the "waste-ink-absorber".
If that absorber is full, it will leak. So, take some paper towels, or sponges, and press them on top of that "waste-ink-absorber", to remove the ink.
May 11, 2011 | Epson WorkForce 600 All-In-One InkJet...
I just replaced my ink cartridges for my Epson Workforce 600 printer and the magenta and yellow colors do not print. The status shows that both are still full of ink, but when I do the nozzle check,...
Try "Nozzle cleaning" and if the problem persist, try "Deep nozzle cleaning". Try them only once or else the ink will run out very quickly.
If the ink cartridges are not genuine Epson, remove them and buy genuine cartridges. If needed, repeat the procedure with them.
Non-original consumables very often clog the printhead.
Aug 07, 2010 | Epson WorkForce 600 All-In-One InkJet...
I cant change ink cartridge in my workforce500. the cartridge wont center itself so that i can open it and replace the ink
Epson has a Trouble Shooting Guide. Make sure that the 500 model number is showing on the top left. Select installing cartridges. Select Holder won't go to position. Then follow the rest of the instructions.
Here is the USER'S GUIDE, with instruction for changing the cartridges.
Hope this gets your printer working.
Good Luck
Feb 19, 2010 | Epson WorkForce 600 All-In-One InkJet...
Epson Workforce 600 "ink cartridge cannot be recognized" error
My printer quit printing blue after I cleaned the print heads. What can I do? I tried recharging the cyan cartridge and cleaning the print heads again. it's still not working! GRR!!
Aug 22, 2009 | Office Equipment & Supplies
How do I refill ink cartridge
from home click on set-up, then maintenance, then click on replace cartridge. Make sure that you replace it with epson cartridges.
May 01, 2009 | Office Equipment & Supplies
77 people viewed this question
jasbo
jasbo
