Question about Nelson Sprinkler: Traveling Tractor
Need a ramp that the tractor goes on top of to shut it off. broke mine
  • 43,501 Answers
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Posted on May 19, 2011
X300 how to remove the deck and inststall new blades ?
Ordinary you do not have to take the deck off if you can run the tractor up on a ramp. Can make one out of 2x6. Run up on the ramp and block wheels then get the wrenches you need and lay down on your back and-work that way. I sharpen mine that way twice a year. I use vice grips and snap on the frame to keep blade from turning.
Dec 18, 2016 | Garden
Was cutting a yard and the blades just shut off and they won't engage at all now. Everything else is fine. What could be causing this?
I suspect that either the drive belt for the blades broke or spring tensioner broke. You may need to have someone fix this for you. What is the make and model of the tractor?
Jul 13, 2015 | Garden
Need diagramof ground drive belt asembly
I just put a new one on mine. Your owner's manual has a diagram. Should be a diagram on the deck close to right rear wheel.
Aug 06, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need a new shut off ramp
You can purchase parts from Nelson directly.
http://www.lrnelson.com/replacement-parts/
Current price for a new ramp is $7.02. Par number 77529.
Jun 28, 2012 | Nelson Sprinkler: Traveling Tractor
Starter repair
sounds like a briggs engine some starters have a roll pin that holds it in some are a snap ring you can get the gear at any power equipment shop or check your napa dealer mine stocks it for a $10 you will be good to go
Jun 03, 2012 | Garden
Brand new nelson tractor sprinkler runs for about 20 minutes and then stops. water pressure is fine
Too heavy a hose can cause this (after 20 minutes, there's just too much hose behind the sprinkler to drag any further).
If the unit shuts off entirely, the sprinkler could be hitting the top of the hose (wheels digging into soft soil) and tripping the auto shutoff under the unit. (Mine does this every once in a while).
Apr 11, 2012 | Nelson Sprinkler: Traveling Tractor
Do you have to remove the deck to replace the 3 blades?
I had a 3 bladed 48 inch Husqvarna for years and I had a set of ramps which I got at a garage sale for a few bucks. Drive the thing up the ramps and the deck bottom and blades are exposed. Block the rear wheels and you are in business. Ramps are better than jack stands for this as you will be applying sideways torque when you unbolt and rebolt the blades.
Aug 22, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
The mower deck clutch cable broke so blades will not engage and lever is loose on my Sears Craftsman 42-inch lawn tractor (917-271-742). I fished out the top piece of the cable, about 12 inches down to a...
I just got the kit 175067. Have the old one off except for where it's attached to the lever, schedule and weather has kept me from going further. Very simple to reconnect things at the pulley and above but not too sure how to connect the rest onto the lever and haven't had a chance to get a good look at how the old one might be connected yet. Should be a simple fix.
Jun 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 19 hp Troy Bilt Super Bronco with the
sounds like spring tension on top of deck is connected to a bolt post,mine broke and went missing with the spring,blades kept slipping,didnt know how to tighten belt,go figure
May 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Nelson Sprinkler:  Traveling Tractor Logo
166 people viewed this question
Top Nelson Garden Experts
Dennis
Mike Squire
Phil Walker
Phil Walker
Are you a Nelson Garden Expert? Answer questions, earn points and help others
