Question about Kenmore Elite 45986 Front Load Washer
I have kenmore elita washer he 4t whw i try to turn non it displey dl f what do i do
  • 15,935 Answers
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Posted on Sep 16, 2010
My kenmore elite HE 4t washing machine will not start. error message dL. It has happen before but I was able to get it started and working for several weeks till now.
'dl' stands for Door Lock (Error). There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 23, 2011 | Kenmore 24032\24036 Top Load Washer
My Kenmore HE-4t washer will not begin the cycle, after I choose it, it clicks and then flashes "F", then "dL"
F DL is a Door Lock Error it mean that the door cannot be locked this could be caused by a locking mechanism malfunction, a wiring problem or a problem with the CCU(central control unit)
Try checking what you can see of the lock mechanism visually and make sure nothing is obstructing or jamming it. Outside of that I would recommend calling a service tech. Please let me know if I can be of further assistance.
Mar 19, 2010 | Kenmore Washing Machines
I couldn't get the washer to start (HE 4T). It
DL stands for Door Lock failure, if your door isnt closing all the way, check to make sure your hinges are lining up and that one of the arms has not broken off on the door, there should be 2 arms going into the door lock. whats common on these is that the door latch has trouble unlocking so it is forced open and now the door latch mechinism is stuck in the locked position and cant re-open. problems with this lock opening and closing- 9 times out of ten, come from a main computer failure to send power to the door lock. this can be temporairily fixed by re-seating the door latch wire harness in the main computer, but its usually recommended to buy a new computer since this problem has been address on the new series of computer. there is no recall on this board at the moment. estimated cost $250-$400
Nov 24, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore He 4t stops working signals F dL do you know why
yes, i know why...had the same problem myself. bad ccu connection. try to resolder or replace board. you can also try to replace door lock, but most likely that's not it. ccu is bad and cannot recognize door is locked.
Aug 11, 2009 | Kenmore Washing Machines
Error message of f dl on kenmore washer model he 4t
does your washer stop on spin cycle some time. your is 4/5 years old?. f dl means door lock system is bad but i don't think so. do you have other error code beside f dl if yes then i think your washer need new main control board.
May 24, 2009 | Kenmore HE4t 3.8 Cu. Ft. King Size...
My screen in showing code "dl" and then "f", please help?
The "dl" code is "doorlock" indicating a problem with the door locking mechanism or switch
Apr 19, 2009 | Kenmore Elite HE4 Electric Dryer
I am getting a dl w/an f error
"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
-> Door lid is not closed completely due to interference.
-> Wash media buildup is preventing the lock bolt from extending.
-> Machine/motor control detects open door lid switch when attempting to lock.
-> Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Jan 19, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he 4t washer
I have the he4t and everytime I wash I get an f02 error. The washer wont drain and spin unless you cancel and restart the washer. What can I do to fix this?
Feb 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
21 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
