Question about Dryers
I have a duracraft dual window fan that was disassembled for cleaning. When reassembling, the power wire became seperated at it's union with the leads to the switch. When re-wired, it runs at only one speed and the switch seems to have no effect. What have I done wrong?
  • Dryers Master
  • 3,287 Answers
Many times, a simple three speed fan motor has one wire for each speed - and a "common" wire, for a total of 4 wires. The common wire is connected to one of the wires of the 2 conductor cord that plugs into the wall outlet. Each of the other three wires from the motor is connected to a separate terminal of a a four position switch (Off, Low, Medium and High speed).
The other wire from the 2 conductor cord goes to the "shunt terminal" (or common terminal) of the switch. The switch directs the power to flow from the shunt terminal to either the off position or the low, medium or high speed terminals - which power the fan motor to run at the associated speed.
What you have done was connect the wire that came off to another wire. This means that the power from the 2 conductor cord is permanently connected to one of the speed terminals - and wires of the motor. You need to unplug the fan and remove the wire that you connected. Locate the shunt terminal of the switch - it should be the one without a wire on it. Reassemble and try again.
Be careful doing this work - I hope this helped!
Posted on Aug 25, 2010
I am. Trying to clean a duracraft 1997 but i. Cant get the blade to separate. From the motor
Some of them are not meant to be seperated, if it is, then it should have 2 slots opposite of eachother in the back of the blade where the plastic fan meets the steel rotating bar, or it could just be pressed on and you would have to pull it off with as much equal force all around the circumference of the back of the fan's main part, the entire round part, either way you need at least 3 hands to do the job, so have someone help you or just clean it as good as you can as it is, I don't think it really needs to be that clean aye'? LoL
Nov 16, 2016 | Duracraft Dryers
How to disassemble and clean
Greg,
FixYa does not repair or sell products. FixYa has a group of people that can help YOU fix your own products - or help you locate someone that can do it for you. In order to do that, we need brands & model numbers of the products you need help with. If you need to locate a shop that can do the work for you - then the name of your town (or closest major city) state or district and country would be needed.
Sep 10, 2015 | Duracraft Dryers
My dual zone wine cooler stopped cooling. Power is good and fan is working.
Fan is wired separately from the cooling unit. you may have a wire corrosion issue. take put the shelves, disassemble the back of the unit from the inside and observe the wiring to see if there are broken or corroded wires/connections. R/R if necessary.
Dec 14, 2014 | Magic Chef Dual Zone Wine and Beverage...
FAN Failure
You need to disassemble case to access the cooling fan inside.
Get a replacement fan from Brother.
If desperate.,peel off the fan label and oil (using sewing machine oil) the fan spindle bush or bearings.
Reassemble.
Jul 24, 2014 | Brother HL-2270DW Wireless Mono Laser...
Not getting power to the power windows. What are the possible problems?
There is generally a master switch on the driver side. Un hook the wiring harness and see if you are getting 12V there. If so find one used on eBay or at a junkyard, disassemble it, clean it, reassemble it, and swap it for yours. Too old to buy at the dealer.
Jun 15, 2011 | 1992 Toyota Pickup
Our duracraft portable fan is humming and not moving? what is the problem and can it be fixed?
Sounds like the armature needs to be cleaned. Dirt can build up on the ends of the motor shaft that operates the fan and where it is held in place, the dirt can actually stop the fan. I would spray both ends of the motor shaft with WD40 and rotate the fan by hand until it is free. This is the cheapest thing to do in order to try and get the fan running again. The problem may be worse than this, but it is a good place to start.
Sep 06, 2010 | Duracraft DB101 Floor / Box Fan
Replacing a hot surface igniter on a Coleman
Yes, you will need to turn off your gas supply, disconnect some wires on the gas valve and disassemble the union to the gas valve. Be very gentle when reassembling because the ignitor is brittle.
Feb 07, 2010 | Coleman Heating & Cooling
My laptop shut off when i picked it up. when i turn it on the fan runs for a few seconds then nothing.
overheating emergency power down.
use compressed air to clean dust and such from the air / fan inlet, remove battery pack, try again, if still the problem, disassemble, clean with compressed air all the parts, reassemble.
if still the prob, u will have to exchange the fan...
good luck
Sep 02, 2009 | Toshiba Satellite M35X-S311 Notebook
Replacement Blade Knob for Duracraft Table Fan Model No.DFT-218W
I thought the same thing. It was hiding in one of the stryfoam pieces.
May 01, 2009 | Duracraft DFT-218W Table Fan
Dryers Logo
138 people viewed this question
Top Dryers Experts
